Add Managed Bean From Config Editor [message #474951] |
Tue, 31 July 2007 08:39 |
Originally posted by: gurkanerdogdu.yahoo.com
Hi;
When I want to add written managed bean from JSF config editor, I get the
following exception when I hit the Next button;
Scenario:
I used the option "Using an existing Java Class" and browse my class and
Exception : Unhandled Event Loop Exception
java.lang.ClassCastException:
org.eclipse.jst.j2ee.webapplication.internal.impl.WebAppReso urceImpl
at
org.eclipse.jst.jee.model.internal.Web25ModelProvider.getMod elObject(Web25ModelProvider.java:35)
at
org.eclipse.jst.jee.model.internal.JEE5ModelProvider.getMode lObject(JEE5ModelProvider.java:113)
at
org.eclipse.jst.jsf.core.jsfappconfig.JSFAppConfigUtils.getC onfigFilesFromContextParam(JSFAppConfigUtils.java:220)
at
org.eclipse.jst.jsf.core.jsfappconfig.ContextParamSpecifiedJ SFAppConfigLocater.getFilenames(ContextParamSpecifiedJSFAppC onfigLocater.java:154)
at
org.eclipse.jst.jsf.core.jsfappconfig.WebContentRelativeJSFA ppConfigLocater.locateProviders(WebContentRelativeJSFAppConf igLocater.java:45)
at
org.eclipse.jst.jsf.core.jsfappconfig.ContextParamSpecifiedJ SFAppConfigLocater.startLocating(ContextParamSpecifiedJSFApp ConfigLocater.java:47)
at
org.eclipse.jst.jsf.core.jsfappconfig.JSFAppConfigManager.st artConfigLocaters(JSFAppConfigManager.java:240)
at
org.eclipse.jst.jsf.core.jsfappconfig.JSFAppConfigManager.in itialize(JSFAppConfigManager.java:201)
at
org.eclipse.jst.jsf.core.jsfappconfig.JSFAppConfigManager.<init >(JSFAppConfigManager.java:170)
at
org.eclipse.jst.jsf.core.jsfappconfig.JSFAppConfigManager.ge tInstance(JSFAppConfigManager.java:102)
at
org.eclipse.jst.jsf.facesconfig.ui.util.ManagedBeanUtil.isBe anDuplicate(ManagedBeanUtil.java:41)
at
org.eclipse.jst.jsf.facesconfig.ui.util.ManagedBeanUtil.getD efaultManagedBeanName(ManagedBeanUtil.java:81)
at
org.eclipse.jst.jsf.facesconfig.ui.wizard.ManagedBeanPropert yPage.initialize(ManagedBeanPropertyPage.java:244)
at
org.eclipse.jst.jsf.facesconfig.ui.wizard.ManagedBeanPropert yPage.setPreviousPage(ManagedBeanPropertyPage.java:217)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1112)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:820)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.eclipse.jst.jsf.facesconfig.ui.section.ManagedBeanMaster Section.addButtonSelected(ManagedBeanMasterSection.java:123)
at
org.eclipse.jst.jsf.facesconfig.ui.section.FacesConfigMaster Section$1.widgetSelected(FacesConfigMasterSection.java:150)
at
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Re: Add Managed Bean From Config Editor [message #474954 is a reply to message #474952] |
Wed, 01 August 2007 06:52 |
Hi Jessler;
I have created the project using Dynamic Web Project with JSF Facet
"1.2". But I did not select the JSF implementation library used in the
project, just selected check box "Server Supplied JSF Implementation", and
adding some component libraries.
In fact the problem(exception) also appears when using the other choice
of managed bean creation; ie "Create a new Java Class" option.
I am using the Eclipse JEE Europa.
But if I added the managed bean descriptions into the faces-config.xml
"Source" tab by hand written, then these beans appeared in "ManagedBean"
tag; but this is very time consuming as you created this editor for easy
manage configuration;
Your help is very appreciated, otherwise I will abondon the use of plugin
and swtich to another options.
Thanks for advance;
Gurkan
Re: Add Managed Bean From Config Editor [message #613260 is a reply to message #474952] |
Hi Jessler;
Thanks for advance;
Gurkan
FUDForum. Page generated in 0.03325 seconds
