Dynamic Help not working [message #474898] |
Tue, 09 December 2008 11:46 |
Originally posted by: victor.conesa.justinmind.com
Hi all,
I don't know if anyone has had this problem but just in case... Anyway, my
problem is that I have the help system working perfectly but the dynamic
help doesn't work completely. When I search something in the dynamic help
the results are ok but when I select one of them and the help system is
opened (inside the dynamic help view) the topic is not shown. In fact if I
select a topic from the help tree this topic isn't shown either, but if I
open the same topic on the help single view it shows correctly.
Any help please?
Re: Dynamic Help not working [message #474905 is a reply to message #474902] |
Thu, 11 December 2008 12:18 |
> Is this an RCP application?
Yes it is
> Can you open any documents and have them display in the help view?
The normal help system (the one that opens in its own window) works
perfectly. I've added an external reference in the dynamic help and it also
works. The only thing that doesn't work is when I select a topic in the help
if its inside the dynamic help
> What version of Eclipse are you using?
Version: 3.4.0
build id: I20080617-2000
> What OS are you running on?
Windows XP Professional
Version: 3.4.0
Build id: I20080617-2000
"Chris Goldthorpe" <cgold@us.ibm.com> escribi
Re: Dynamic Help not working [message #475077 is a reply to message #474907] |
Thu, 22 January 2009 09:17 |
I've been trying to make the help view work so long with no success. But I
discover something that maybe someone can help to point the problem. I've
added the Mylyn plugins to my run configuration. Then I open the "Search"
help view and then the "All topics" section. In the section appears our
product's help topics and the Mylyn ones. When I open a Mylyn topic, it is
shown in a different way than our product's topics. The Mylyn topic opens in
a single frame on the view but our topics appears in the classic two frames
help view (the left frame shows the topics tree and the right frame had to
show the topic but it is always blank). Then if I select the same Mylyn
topic than before but this time on the tree at the left frame the topic is
not shown.
Any help please??
Re: Dynamic Help not working [message #475082 is a reply to message #475079] |
Mon, 26 January 2009 08:10 |
Ok, while I found the way to post a bugzilla I send the images through this
mail.
The first image shows the standalone help working properly. The second one
shows the dynamic help and the list of topics working properly too. The
third one shows what happens if I click on a topic in the help view, as you
could see the contents are not displayed and the topics tree is visible, but
in a Mylyn topic (if I run the product adding this plugin), that tree doesnt
appears and the content is displayed correctly. So I supose is something
related to the help system configuration of my product but I can't see where
is the error.
Thanks.
Re: Dynamic Help not working [message #475097 is a reply to message #475096] |
Mon, 02 February 2009 08:33 |
Don't worry, looks like is not that easy. There must be some combination of
plugins/code that leads to this error. What I'm going to do is to create a
blank project and add it the dynamic help and see what happens.
Thanks for your help, I'll post the results of that test.
Re: Dynamic Help not working [message #475110 is a reply to message #475097] |
Tue, 10 February 2009 08:33 |
Hi all,
It's solved. The problem was some code in the html files. We are not really
sure why there was that piece of code in our help files but everything work
perfectly well without it. The piece of code was:
<script>if( self == top ){ window.location.replace(
" ../../../index.jsp?topic=/org.eclipse.help.base/doc/help_hom e.html ");}</script>
Thanks for your answers Chris,
"V
Re: Dynamic Help not working [message #622683 is a reply to message #474902] |
Yes it is
Version: 3.4.0
Version: 3.4.0
Re: Dynamic Help not working [message #622800 is a reply to message #474907] |
not shown.
Any help please??
Re: Dynamic Help not working [message #622802 is a reply to message #475079] |
mail.
is the error.
Thanks.
Re: Dynamic Help not working [message #622807 is a reply to message #475096] |
Re: Dynamic Help not working [message #623219 is a reply to message #475097] |
Hi all,
"V
FUDForum. Page generated in 0.04284 seconds
