Home » Modeling » UML2 » No value in upperValue/lowerValue - meaning?
No value in upperValue/lowerValue - meaning? [message #474721] Wed, 25 July 2007 13:57 Go to next message
Originally posted by: user.domain.invalid
Dear All,
I am just finishing off my XSLT for the compare tool & wrt
cardinalities/multiplicities I am stuck for some exact wording.
Basically is I run into a change etc in a multiplicity e.g.
<upperValue xmi:type="uml:LiteralUnlimitedNatural"
xmi:id="_WC4sUTqoEdyMeJ3mr5tnmg" value="1"/>
Then I can grab the value attribute & say "value =".
However if the value is the default it is not put in e.g.
<lowerValue xmi:type="uml:LiteralInteger"
xmi:id="_WC4sUDqoEdyMeJ3mr5tnmg"/>
So what would the the "UML correct" wording for when an upper or lower
value has no value?
Default? No Value?
TIA
Adam
Re: No value in upperValue/lowerValue - meaning? [message #474723 is a reply to message #474721] Wed, 25 July 2007 20:42 Go to previous messageGo to next message
james bruck is currently offline james bruckFriend
When the value of LiteralInteger is not serialized it would assume the
default value.
It appears that the default value for LiteralInteger is 0.
See section 7.3.27 of the UML spec and the implementation at
LiteralIntegerImpl VALUE_EDEFAULT.
- James.
"AdamF" <user@domain.invalid> wrote in message
news:f87kt1$nf5$1@build.eclipse.org...
> Dear All,
> value has no value?
> Default? No Value?
> TIA
> Adam
Re: No value in upperValue/lowerValue - meaning? [message #474725 is a reply to message #474723] Thu, 26 July 2007 10:07 Go to previous message
> default value.
> - James.
Thanks.
I will use "default value".
Adam
Re: No value in upperValue/lowerValue - meaning? [message #624058 is a reply to message #474721] Wed, 25 July 2007 20:42 Go to previous message
default value.
- James.
> Dear All,
> value has no value?
> Default? No Value?
> TIA
> Adam
Re: No value in upperValue/lowerValue - meaning? [message #624060 is a reply to message #474723] Thu, 26 July 2007 10:07 Go to previous message
> default value.
> - James.
Thanks.
Adam
Previous Topic:preconditions / postconditions of a use case
Next Topic:How to add a SendOperationEvent to a Package?
Current Time: Sat Jul 24 15:21:49 GMT 2021
Powered by FUDForum. Page generated in 0.02646 seconds
