Removing default plug-ins from Infocenter [message #474704] |
Wed, 22 October 2008 13:52 |
Mike Melton Messages: 50 Registered: July 2009 |
Member |
I've downloaded Ganymede (Eclipse Classic), generated documentation
plugins, and have been successful making them available through Infocenter.
Now, I'd like to do further customizations.
The first is to remove the default documentation plug-ins that came with
my download. The Infocenter is displaying help for the workbench, Java
development, JDT plug-n development, and plug-in development environment.
I've manually removed the JDT plug-ins, but its help remains in my
Infocenter. Can anyone point me in the right direction on how to remove
these plug-ins?
The second is that my script to start Infocenter is pointing to my own
plugin_customization.ini, but setting HELP_DATA to my toc has no effect.
I really appreciate some help or being pointed in the right direction. The
documentation I've been reading has been interesting, but hasn't helped in
these areas.
Re: Removing default plug-ins from Infocenter [message #474708 is a reply to message #474707] |
Wed, 22 October 2008 20:54 |
Originally posted by: nospam_kowalskilee.gmail.com
Hi Mike, it's good to hear that you got something to work for this.
Would you please clarify about what you did to remove the entries?
I mean, did you edit the bundles.info file and take out the unwanted doc
plugin entries from there, and saving the edited bundles.info file in
the directory?
Or did you delete the bundles.info file altogether?
Thanks in advance!
Lee Anne
Mike Melton wrote:
> I realize this is probably a hack, but it will work for my prototype.
> Something that Lee Anne wrote about cache data in Ganymede led me to
> removed unwanted doc plugin entries from
> configuration/org.eclipse.equinox.simpleconfigurator. This did the
> trick. My Infocenter now only show the plugins I've added.
> Thanks Lee Anne!
Re: Removing default plug-ins from Infocenter [message #474710 is a reply to message #474709] |
Thu, 23 October 2008 14:45 |
Hi Mike, thanks for this info!
This sounds like a straightforward fix to address the 'caching' effects
for either the standalone help or infocenter scenarios using Eclipse
3.4. Thank you for trying it out and also for posting your success here.
It's so helpful when someone writes about what works for them.
If you find that you run into future buggy behavior using this
procedure, I hope that you will post again here, so that we can all learn.
Thanks again,
Lee Anne
Mike Melton wrote:
> Sorry, I meant to write add this. I used a text editor to remove the
> entries for unwanted bundles from bundles.info and saved it back to
> I determined which bundles to remove by looking at the properties of
> content pages of unwanted documents displayed in Infocenter.
Re: Removing default plug-ins from Infocenter [message #621652 is a reply to message #474707] |
the directory?
Thanks in advance!
Lee Anne
> Thanks Lee Anne!
Re: Removing default plug-ins from Infocenter [message #621654 is a reply to message #474709] |
Thanks again,
Lee Anne
FUDForum. Page generated in 0.02082 seconds
