Home » Modeling » UML2 Tools » Reuse UML New Diagram wizards
Reuse UML New Diagram wizards [message #474690] Thu, 17 July 2008 02:19 Go to next message
Leandro is currently offline LeandroFriend
How can I call a UMLCreationWizard to create new diagrams on my RCP
application?
I've put the code:
UMLCreationWizard wizard = new UMLCreationWizard();
WizardDialog dialog = new WizardDialog(wizard.getShell(), wizard);
dialog.open();
But it didn't work.
Thanks in advance,
Nogueira.
Re: Reuse UML New Diagram wizards [message #474691 is a reply to message #474690] Thu, 17 July 2008 10:58 Go to previous messageGo to next message
Tatiana Fesenko is currently offline Tatiana FesenkoFriend
Hello Nogueira,
I created a test with the code you produced. NPE is thrown:
at org.eclipse.ui.dialogs.WizardNewFileCreationPage.initialPopu lateContainerNameField(WizardNewFileCreationPage.java:568)
at org.eclipse.ui.dialogs.WizardNewFileCreationPage.createContr ol(WizardNewFileCreationPage.java:216)
at org.eclipse.uml2.diagram.clazz.part.UMLCreationWizardPage.cr eateControl(UMLCreationWizardPage.java:65)
Do you have the same excection in your log?
If yes, the problem is that wizard should be initialized:
// init wizard
wizard.init(PlatformUI.getWorkbench(), new StructuredSelection());
dialog.open();
The second paramer (selection) is used to calculate parentPath. In my example
it's empty, but it should be filled with IResource. See WizardNewFileCreationPage#initialPopulateContainerNameField( )
for details.
Best wishes,
Tatiana.
> Hello,
> application?
> I've put the code:
> dialog.open();
> But it didn't work.
> Thanks in advance,
> Nogueira.
Re: Reuse UML New Diagram wizards [message #474692 is a reply to message #474691] Thu, 17 July 2008 16:09 Go to previous messageGo to next message
Tatiana,
Thank you so much!!!!!! The wizard was created successfuly :D
No, there is no exception in my log. The wizard just didn't appear.
But the "init" method works fine! :)
Thank you again!
P.S.: Are you brazilian? If yes, could you give me your e-mail (msn or
google talk) to keep contact?
Nogueira.
Re: Reuse UML New Diagram wizards [message #474693 is a reply to message #474691] Fri, 18 July 2008 18:58 Go to previous messageGo to next message
One more question...
In my RCP application, when I select a wizard to create a new diagram,
it's needed to select the parent folder where will be created the file.
But the names of the project folders and its subdirectories are invisible
to me.
It's possible to select a folder, but in blinding. In the new file wizard
is shown the tree items ('+' to expand the tree) but any title is visible.
How to solve it?
Thank you in advance,
Nogueira.
Re: Reuse UML New Diagram wizards [message #474699 is a reply to message #474693] Tue, 22 July 2008 21:22 Go to previous messageGo to next message
Any ideias? =/
> to me.
> How to solve it?
> Best regards,
> Nogueira.
Re: Reuse UML New Diagram wizards [message #474927 is a reply to message #474699] Wed, 23 July 2008 16:20 Go to previous message
Solved!
Just put the code below in method 'initialize(IWorkbenchConfigurer
configurer)' from class 'ApplicationWorkbenchAdvisor':
WorkbenchAdapterBuilder.registerAdapters();
Re: Reuse UML New Diagram wizards [message #621271 is a reply to message #474690] Thu, 17 July 2008 10:58 Go to previous message
Hello Nogueira,
// init wizard
dialog.open();
for details.
Best wishes,
Tatiana.
> Hello,
> application?
> I've put the code:
> dialog.open();
> But it didn't work.
> Thanks in advance,
> Nogueira.
Re: Reuse UML New Diagram wizards [message #621274 is a reply to message #474691] Thu, 17 July 2008 16:09 Go to previous message
Tatiana,
Thank you again!
Nogueira.
Re: Reuse UML New Diagram wizards [message #621275 is a reply to message #474691] Fri, 18 July 2008 18:58 Go to previous message
to me.
How to solve it?
Nogueira.
Re: Reuse UML New Diagram wizards [message #621713 is a reply to message #474693] Tue, 22 July 2008 21:22 Go to previous message
Any ideias? =/
> to me.
> How to solve it?
> Best regards,
> Nogueira.
Re: Reuse UML New Diagram wizards [message #621730 is a reply to message #474699] Wed, 23 July 2008 16:20 Go to previous message
Solved!
Previous Topic:Assocation and subpackage
Next Topic:Multiplicities and names in an Association
Current Time: Wed Jul 15 11:58:36 GMT 2020
Powered by FUDForum. Page generated in 0.02686 seconds
