Re: Installing UML2-tools [message #474570 is a reply to message #474568] |
Wed, 09 July 2008 11:31 |
Michael Golubev Messages: 383 Registered: July 2009 |
Hello W.F.,
Yes, its a known problem at windows platform covered by https://bugs.eclipse.org/bugs/show_bug.cgi?id=238098.
We are sorry for that.
But there are plenty of workarounds, even if you want to stay with Windows
:). Personally I would recommend options 3) or 4) listed below.
1. You can just ignore missed example file, diagramming itself does not depends
on it and should work the same way.
2. Even more, I believe that you can completely remove the whole samples
plugin and (except a logged error message on startup) diagramming still should
work.
3. You can install U2T from update manager pointing it to http://download.eclipse.org/modeling/mdt/updates/milestones/ ,
it is verified to work on any platform
4. You can also switch to 0.8.1 maintenance stream builds, which is available
for download as zips at the http://www.eclipse.org/modeling/mdt/downloads/?project=uml2t ools
and as an update manager at http://download.eclipse.org/modeling/mdt/updates/interim/.
The latest M-stream build was compiled against the release versions of our
dependencies (so it is fully compatible with Ganymede, you don't need to
switch any other plugins/features to maintenance stream) and it has this
and a couple of more bugs fixed. Right now the latest M-build available is
M200807071308, but we are probably going to build one more hot-fixes M build
in a couple of days.
Just in case, I am going to crosspost the list of workaround above into the
bug #238098
Once again, we are sorry for inconvenience,
Michael
> I'm trying to extract and install the UML2-tools plugin, but some
> paths are longer than 260 characters. It's practically impossible to
> install. Is there a workaround?
> I'm not sure it's such a great idea to have file names such as this:
> Figure 9.11 - The internal structure of the Observer collaboration
> shown inside the collaboration icon.uml
Re: Installing UML2-tools [message #474573 is a reply to message #474568] |
Wed, 09 July 2008 15:17 |
Marco Mosconi Messages: 63 Registered: July 2009 |
Member |
I had the same issue some times with different plugins, because plugin
content hierarchies tend to get very deep.
One workaround is to use 7-Zip (7-zip.org) for unpacking. This works for me.
Marco
W.F. schrieb:
> I'm trying to extract and install the UML2-tools plugin, but some paths
> are longer than 260 characters. It's practically impossible to install.
> Figure 9.11 - The internal structure of the Observer collaboration shown
Re: Installing UML2-tools [message #620482 is a reply to message #474568] |
Hello W.F.,
work.
bug #238098
Michael
Re: Installing UML2-tools [message #620485 is a reply to message #474568] |
Member |
Marco
FUDForum. Page generated in 0.03573 seconds
