Home » Modeling » UML2 Tools » OCL expression problem extending UML2 editor
Re: OCL expression problem extending UML2 editor [message #474439 is a reply to message #474438] |
Tue, 10 June 2008 19:56 |
Originally posted by: cdamus.zeligsoft.com
--=-H2IB3guNpr85iYI5d/Ri
Content-Type: text/plain
Hi, Joel,
If the context classifier of your OCL init expression isn't in the UML
metamodel namespace, then you will have to fully qualify your
enumeration:
uml::AggregationKind::composite
HTH,
Christian
On Tue, 2008-06-10 at 20:45 +0200, Joel Greenyer wrote:
> I'm trying to build a customized/extended composite structure editor for my middleweight-extension of UML.
> My model contains a specialized Port (in addition to the regular Port from UML) which shall be displayed differently.
> I copied the Port Node Mapping entry from the compositeStructures.gmfmap and adapted it to fit the new Port.
> While the editor works as expected with the regular UML Ports, I have a problem with the feature initializers of the new
> Port. For example, there is one OCL feature initializer saying that feature "aggregation" should be
> "AggregationKind::composite". When I create a new Port in the editor, I get the following error:
> Expression problem:Unknown type ([AggregationKind, composite])body:AggregationKind::composite
> Any ideas why that is?
> Thanks
> Joel
Content-Type: text/html; charset=utf-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.16.0">
</HEAD>
<BODY>
Hi, Joel,<BR>
<BR>
If the context classifier of your OCL init expression isn't in the UML metamodel namespace, then you will have to fully qualify your enumeration:<BR>
<BR>
uml::AggregationKind::composite<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
<FONT COLOR="#000000">Hi,</FONT>
<FONT COLOR="#000000">I'm trying to build a customized/extended composite structure editor for my middleweight-extension of UML.</FONT>
<FONT COLOR="#000000">My model contains a specialized Port (in addition to the regular Port from UML) which shall be displayed differently.</FONT>
<FONT COLOR="#000000">I copied the Port Node Mapping entry from the compositeStructures.gmfmap and adapted it to fit the new Port.</FONT>
<FONT COLOR="#000000">While the editor works as expected with the regular UML Ports, I have a problem with the feature initializers of the new </FONT>
<FONT COLOR="#000000">Port. For example, there is one OCL feature initializer saying that feature "aggregation" should be </FONT>
<FONT COLOR="#000000">"AggregationKind::composite". When I create a new Port in the editor, I get the following error:</FONT>
<FONT COLOR="#000000">Expression problem:Unknown type ([AggregationKind, composite])body:AggregationKind::composite</FONT>
<FONT COLOR="#000000">Any ideas why that is?</FONT>
<FONT COLOR="#000000">Thanks</FONT>
<FONT COLOR="#000000">Joel</FONT>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-H2IB3guNpr85iYI5d/Ri--
Re: OCL expression problem extending UML2 editor [message #474440 is a reply to message #474439] |
Tue, 10 June 2008 21:14 |
Joel Greenyer Messages: 170 Registered: July 2009 |
Hi Christian,
I already suspected it had to do with the metamodel namespace.
Now it works!
Thanks for the quick reply
Joel
Christian W. Damus wrote:
> Hi, Joel,
> HTH,
> Christian
>> Hi,
>> Thanks
>> Joel
Re: OCL expression problem extending UML2 editor [message #619990 is a reply to message #474438] |
Hi, Joel,
enumeration:
HTH,
Christian
> Thanks
> Joel
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Joel,<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: OCL expression problem extending UML2 editor [message #619991 is a reply to message #474439] |
Hi Christian,
Now it works!
Joel
> Hi, Joel,
> HTH,
> Christian
>> Hi,
>> Thanks
>> Joel
Current Time: Tue Apr 23 09:24:58 GMT 2024
Powered by FUDForum. Page generated in 0.03064 seconds
