Home » Modeling » UML2 » Re: Generating code with stereotypes
Re: Generating code with stereotypes [message #474205] |
Fri, 13 July 2007 15:21 |
Ed Merks Messages: 33140 Registered: July 2009 |
Jose,
Probably it's best to start with the UML newsgroup with this question,
so I've added that to the "to" list of my reply. I'm not sure what it
does with arbitrary stereotypes, but I think it throws them away. The
closest equivalent concept in Ecore would be an EAnnotation, so you
might need to use that.
Jose wrote:
> How can I generate code with EMF from a UML Diagram that uses
> stereotypes? With OCL? EAnnotation from EMF?
> What have I to do for not lost the stereotypes and generate code
> correctly?
> Thanks.
> (Sorry for my English).
Ed Merks
Re: Generating code with stereotypes [message #474391 is a reply to message #474217] |
Fri, 20 July 2007 11:38 |
Jose Messages: 51 Registered: July 2009 |
Member |
Thanks James-Bruck,
But Omondo's group can generate code using UML2 and EMF, so that I could
not do it?
Excuse me if the question is very stupid.
Thanks.
James Bruck escribió:
> Hi Jose,
> Information from arbitrary stereotypes is not used in the conversion from
> uml to ecore.
> There is some facility to generate code from OCL when it is used in the
> original model but not when it is in an applied stereotype ( check out the
> new and noteworthy section for some details. ).
> UML also now has the means to use static profile definition ( also see new
> and noteworthy ), but this might not be what you are interested in.
> There does seem to be an outstanding defect that might be similar to what
> you are looking for https://bugs.eclipse.org/bugs/show_bug.cgi?id=101404.
> You might want to state your exact needs in a bugzilla or add to the one I
> just mentioned and it will be looked into.
> - James.
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:f785au$g6s$1@build.eclipse.org...
>> Jose,
>> Jose wrote:
>>> Hi,
>>> correctly?
>>> Thanks.
Re: Generating code with stereotypes [message #474394 is a reply to message #474392] |
Fri, 20 July 2007 14:54 |
Member |
Thank you very much, James
James Bruck wrote:
> Hi Jose,
> I'm not sure I'm interpreting your question correctly.
> Are you saying that Omondo can generate code from applied stereotypes from
> some specific profile?
> or are you saying that Omondo can generate code from UML2 in general?
> If it's the first case: I'm not familiar with Omondo but they might be
> extending the uml to ecore converter in some way. The existing
> UML2EcoreConverter does for example take the Ecore profile into account in
> the conversion process. Perhaps Omondo does something special with another
> profile?
> If it's the second case: You can generate code using UML2 by converting to
> ecore and then generating code from the ecore representation.
> By adding a stereotype you are introducing a new item at the meta model
> level. I'm not sure how the general uml to ecore converter can interpret
> this new meta level property. Ultimately, code generation from uml happens
> by first mapping the uml representation to an ecore representation and then
> code generation occurrs from ecore. There would have to be some agreed
> upon mapping from these newly introduced values within the stereotype to an
> - James.
> "Jose" <ja.navarro.a@alumnos.urjc.es> wrote in message
> news:f7q6sj$d5s$1@build.eclipse.org...
>> Thanks James-Bruck,
>> not do it?
>> Thanks.
>> James Bruck wrote:
>>> Hi Jose,
> from
>>> uml to ecore.
> the
> new
> what
>>> you are looking for
> I
>>> - James.
>>>> Jose,
>>>> Jose wrote:
>>>>> Hi,
>>>>> correctly?
>>>>> Thanks.
Re: Generating code with stereotypes [message #623917 is a reply to message #474217] |
Member |
Thanks James-Bruck,
not do it?
Thanks.
> Hi Jose,
> uml to ecore.
> - James.
>> Jose,
>> Jose wrote:
>>> Hi,
>>> correctly?
>>> Thanks.
Re: Generating code with stereotypes [message #623925 is a reply to message #474392] |
Member |
James Bruck wrote:
> Hi Jose,
> profile?
> - James.
>> Thanks James-Bruck,
>> not do it?
>> Thanks.
>> James Bruck wrote:
>>> Hi Jose,
> from
>>> uml to ecore.
> the
> new
> what
>>> you are looking for
> I
>>> - James.
>>>> Jose,
>>>> Jose wrote:
>>>>> Hi,
>>>>> correctly?
>>>>> Thanks.
Current Time: Thu Apr 25 03:49:47 GMT 2024
Powered by FUDForum. Page generated in 0.03717 seconds
