Home » Eclipse Projects » JavaServer Faces » Firefox working, but not with IE
Re: Firefox working, but not with IE [message #474185 is a reply to message #474184] |
Tue, 15 May 2007 20:56 |
Cameron Bateman Messages: 481 Registered: July 2009 |
Hi John,
Could you try the same test but with no JSF in the application? That is,
can you try creating a similar simple application that is just using JSPs
with no JSF? This will help us isolate whether this is a general problem
or one specific to JSF.
Cameron
John Smith wrote:
> My JSF application, a war packed with WTP and applied to JBoss
> jboss-4.2.0.CR2 (i tried v4.0.5, too), does well work when viewed with
> Firefox. However when viewed in Internet Explorer, the ".faces" files
> entered in the address bar seem to be not processed by the JSP or JSF
> processor, instead I get the pure contents from the mapped ".jsp" file,
> displayed as XML in the IE window.
> (I have deployed the Web application locally and e.g. access
> http://localhost:8080/login.faces. I have Windows XP).
> Any idea?
Re: Firefox working, but not with IE [message #474642 is a reply to message #474185] |
Mon, 18 June 2007 13:37 |
John Smith Messages: 137 Registered: July 2009 |
Cameron Bateman wrote:
> Hi John,
> is, can you try creating a similar simple application that is just using
> JSPs with no JSF? This will help us isolate whether this is a general
> problem or one specific to JSF.
> Cameron
>> file, displayed as XML in the IE window.
>> Any idea?
I figured out that using .jsf as files extension and not .faces in the
url (with changing the url-pattern in web.xml from *.faces to *.jsf,
too) solved the problem! The only question now is: WHY??
In the not-working case at Internet Explorer , Internet Explorer still
displays the correct HTML as I view the page source, but in the Browser
its not interpreted as HTML but as XML. So why is it interpreted as HTML
by IE when I use .jsf instead of .faces? Is there a fix list of
allowed extensions build into Internet Explorer ? (I would not wonder if
this is the case..)
Re: Firefox working, but not with IE [message #610960 is a reply to message #474184] |
Hi John,
Cameron
> http://localhost:8080/login.faces I have Windows XP).
> Any idea?
Re: Firefox working, but not with IE [message #612060 is a reply to message #474185] |
> Hi John,
> Cameron
>> Any idea?
this is the case..)
Current Time: Thu Apr 18 21:13:27 GMT 2024
Powered by FUDForum. Page generated in 0.02199 seconds
