Home » Eclipse Projects » Platform - User Assistance (UA) » Infocenter customization and WAR files
Infocenter customization and WAR files [message #474172] Fri, 08 August 2008 12:01 Go to next message
I have a help system that runs in a standalone infocenter. I customized
the banner and help home page using plugin_customization.ini in the
platform plug-in. This works fine.
However, for security reasons, I have deployed the same help system in a
WAR file where it runs in Apache Tomcat as is now possible in Ganymede
(*great* feature, BTW). This works well, except that I have lost all the
customizations. The infocenter runs with the stock Eclipse banner and help
home. I've tried various solutions to no avail. Does anyone know how to
make these customizations "stick"? Thanks in advance,
-Tom
Re: Infocenter customization and WAR files [message #474176 is a reply to message #474172] Tue, 12 August 2008 12:45 Go to previous messageGo to next message
Basically, what you have to do is create another plugin that contains all of
your customization setttings, banner, welcome page, etc. The plugin.xml
might look something like this
<plugin id="com.foo.bar" version="1.0.0" name="Doc Customization"
provider="%plugin.provider">
<extension id="foobarDoc" point="org.eclipse.core.runtime.products">
<product name="%plugin.name"
application="org.eclipse.help.base.helpApplication"
description="%plugin.description">
<property name="windowImages"
value="images/eclipse.gif,images/eclipse32.gif"/>
<property name="preferenceCustomization"
value="plugin_customization.ini"/>
</product>
</extension>
</plugin>
You then set the eclipse.product property of
eclipse/configuration/config.ini (inside the war) to the product name of
that plugin (e.g. eclipse.product=com.foo.bar.foobarDoc). Then create a
file called plugin_customization.ini inside your customization plugin. This
file contains all of the customization configurations. See this link for a
list of customization:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/ua_help_setup_preferences.htm
Hope this helps
Eric
"Thomas Proulx" <tproulx@tibco.com> wrote in message
news:61c823e7389520e4ada8e5a2d93565c0$1@www.eclipse.org...
> -Tom
Re: Infocenter customization and WAR files [message #474236 is a reply to message #474176] Fri, 15 August 2008 09:13 Go to previous message
Originally posted by: proulx.tibco.com
Eric,
I tried this and what you suggested worked. Thanks for you help.
-Tom
Re: Infocenter customization and WAR files [message #619320 is a reply to message #474172] Tue, 12 August 2008 12:45 Go to previous message
</product>
</extension>
</plugin>
Hope this helps
Eric
> -Tom
Re: Infocenter customization and WAR files [message #619390 is a reply to message #474176] Fri, 15 August 2008 09:13 Go to previous message
Eric,
-Tom
Previous Topic:Re: Regarding Extending the Universal Intro
Next Topic:Infocenter as war file - dynamic plugin update
Current Time: Tue Jun 24 19:47:03 EDT 2025
Powered by FUDForum. Page generated in 0.25134 seconds
