Re: PDF support needed in eclipse help doc [message #474073 is a reply to message #474069] |
Tue, 17 June 2008 15:42 |
Originally posted by: nospam_kowalskilee.gmail.com
I'm really not sure what you mean about "a pdf support inside the
eclipse help doc".
I went to the URL that you list below and looked for "PDF" in that
topic. The only mention of PDF is the following text:
"To view PDF documents within the help system, you must have Adobe
Acrobat Reader Version 4.05 or higher installed, and the Acrobat Web
plug-in properly installed in your browser."
That IBM doc for WebSphere is actually running the Eclipse-based
infocenter, and the Eclipse help documentation also runs in an
Eclipse-based infocenter here:
http://help.eclipse.org/stable/index.jsp
And the Eclipse-based infocenter is running in your normal machine's
browser, so if you can normally view PDFs on the Web inside your IE or
Firefox browser, then you'll be able to view PDFs that are in the
content that's in an Eclipse-based help system or infocenter.
So, are you asking for the URL to the Eclipse help documentation running
in the same infocenter type of system as the IBM WebSphere infocenter so
you can read the Eclipse help docs?
Or do you mean that you want the Eclipse help documentation files to be
in PDF format, and you are looking for PDFs of the Eclipse help
documentation?
Or are you asking for a way that you can have a PDF file inside your
content that you provide inside an Eclipse-based help system?
It is that last item ('how do I have support for PDFs inside my help
content') that I thought you meant by asking for "pdf support". I don't
see an actual PDF inside the IBM URL that you posted, so I don't
understand the connection between your question and the URL that you posted.
Lee Anne
HariBabu wrote:
> I am looking for a pdf support inside the eclipse help doc. How can i
> achieve this. Any inputs/links will be appreciated. I have seen IBM's
> doc support but it seems its only for IBM Product i.e. websphere (see
> the below link).
> http://publib.boulder.ibm.com/infocenter/tivihelp/v2r1/index .jsp?topic=/com.ibm.IBMDI.doc_6.1.1/installing_and_managing. html
Re: PDF support needed in eclipse help doc [message #615287 is a reply to message #474069] |
eclipse help doc".
documentation?
Lee Anne
HariBabu wrote:
> the below link).
FUDForum. Page generated in 0.02724 seconds
