Home » Eclipse Projects » Platform - User Assistance (UA) » In what Eclipse source plug-in/file is default "ButtonFace" color set?
In what Eclipse source plug-in/file is default "ButtonFace" color set? [message #473749] |
Fri, 16 May 2008 12:52  |
Originally posted by: nospam_kowalskilee.gmail.com
In the help preferences, there is the following preference:
advanced.toolbarBackground
And the help file says that the Default = ButtonFace
In what Eclipse source plugin or file can I see what this default
"ButtonFace" gets set to?
I've looked into the source files for the help system's plug-ins, and
did a search of the eclipse.* newsgroups, and am stuck on how best to
search further.
Actually, if there's a general way to search Eclipse source for
particular strings using the Workbench/SDK, I'd appreciate pointers
about that also. :-)
Lee Anne
Re: In what Eclipse source plug-in/file is default "ButtonFace" color set? [message #473750 is a reply to message #473749] |
Fri, 16 May 2008 13:39   |
Hi Lee Anne,
ButtonFace is a color value defined in the CSS 2 specification:
http://www.w3.org/TR/REC-CSS2/ui.html#system-colors
It will be set to whatever value the user has specified for this UI item
in the OS control panel.
Hope this helps,
Pierre
Lee Anne wrote:
> search further.
> Lee Anne
Perfect, thanks! (was Re: In what Eclipse source plug-in/file is default "ButtonFace" colo [message #473751 is a reply to message #473750] |
Fri, 16 May 2008 14:23  |
Hi Pierre,
Thanks so much for this, it's spot on! I changed my Windows display
settings to use "Pumpkin", and applied, and when Windows refreshed, the
infocenter webapp frame coloring changed to reflect it.
Thanks again!
Lee Anne
Pierre Candela wrote:
> Hi Lee Anne,
> Hope this helps,
> Pierre
> Lee Anne wrote:
>> Hi,
>> search further.
>> Thanks,
>> Lee Anne
Re: In what Eclipse source plug-in/file is default "ButtonFace" color set? [message #614233 is a reply to message #473749] |
Hi Lee Anne,
Hope this helps,
Pierre
Lee Anne wrote:
> search further.
> Lee Anne
Perfect, thanks! (was Re: In what Eclipse source plug-in/file is default "ButtonFace" colo [message #614239 is a reply to message #473750] |
Hi Pierre,
Thanks again!
Lee Anne
> Hi Lee Anne,
> Hope this helps,
> Pierre
> Lee Anne wrote:
>> Hi,
>> search further.
>> Thanks,
>> Lee Anne
Current Time: Thu Jun 19 00:31:16 EDT 2025
Powered by FUDForum. Page generated in 0.06569 seconds
