jsp Hello World [message #473724] |
Thu, 14 December 2006 12:59 |
Originally posted by: nospam.nowhere.nowhere
I am asp.net developer and as my third attempt I am trying to give java/jsp
another go. In the past I tried Netbeans and Sun Java Studio creator, but to
my experience they were to slow to compile and run (50+ seconds to
recompile/run a jsp page!)
I have downloded and installed the followings:
Eclipse 3.2
Tomcat 5.5.20
Sysdeo plugin
Sun JDK
j2re1.4.2_03
all running on Win Xp Pro
I can create a Dynamic Web Project and run it under Tomcat server from
Eclipse IDE, however what I am after is to have similar "Code Behind"
methodology available in ASP.NET (C#) to write java codes for my jsp web
form controls (ie. Buttons, textboxes etc).
Can someone put me in the right direction. Does Eclipse have this kind of
functionality?
My other question is that why the main Tomcat service running on XP Pro must
be stopped to run the Tomcat server inside Eclipse IDE?
Med
Re: jsp Hello World [message #473799 is a reply to message #473797] |
Thu, 14 December 2006 23:41 |
Thanks for the suggestion Cameron,
I think you are right about the port conflict.
Med
"Cameron Bateman" <cameron.bateman@oracle.com> wrote in message
news:48be88b14b9c7f5feb123c9abed37b27$1@www.eclipse.org...
> JSF has a similar concept known as "backing beans". You can do this by
> using the 'binding' attribute on many components. JSF tooling doesn't
> currently have too much in the way of automating this right now, but if
> you look it up in any JSF docs you can see how to do it by hand. For
> example:
> http://java.sun.com/j2ee/1.4/docs/tutorial/doc/JSFIntro8.htm l
>> must be stopped to run the Tomcat server inside Eclipse IDE?
> This question is better asked on the eclipse.webtools but I suspect it is
> due to default port conflicts. If you change the default ports used by
> one of the tomcat servers this should solve it.
Re: jsp Hello World [message #608384 is a reply to message #473797] |
Med
> example:
FUDForum. Page generated in 0.02859 seconds
