Home » Eclipse Projects » JavaServer Faces » Exception when accessing JSP page
Exception when accessing JSP page [message #473668] |
Fri, 27 October 2006 08:52 |
Originally posted by: luong.ngo.gmail.com
I am trying to create a simple JSF project and I have the issue when
accessing a very simple jsp page. I created a Dynamic Web Project and
select the JSF configuration. I create a hello.jsp and left the page as it
is generated by eclipse with online 1 line "Hello World" added to the
body. However, when I deploy the project on JBOSS 4.0 and try accessing
the hello.jsp, I got a lot of messages in the console and it's an Stack
Overflow error. The messages seem to repeat infinitely which explains the
stack overflow error. I have no clues what is wrong as I followed steps in
the Help Content about creating an JSF project.
In the meantime, I created a similar JSF web project in Sun's Studio
Creator 2.0 and export it to a WAR and deploy it in JBOSS and it works
fine.
I should mention I got eclipse from lomboz.org website because I would
need to create J2EE project for the back end in my project. I am not sure
if there is anything different bewteen lombos's eclipse version and the
version from eclipse.org itself.
I don't know if this is a bug in eclipse or there is steps I missed. I am
totally out of idea why this does not work. I appreciate any help or clues
in how to resolve this problem.
Following is part of the output in consoles
[ConnectionFactoryBindingService] Bound ConnectionManager
'jboss.jca:service=ConnectionFactoryBinding,name=JmsXA' to JNDI name
'java:JmsXA'
01:09:57,158 INFO [TomcatDeployer] deploy, ctxPath=/MyJSF,
warUrl=.../tmp/deploy/tmp53162MyJSF-exp.war/
01:09:57,408 INFO [FacesConfigurator] Reading standard config
org/apache/myfaces/resource/standard-faces-config.xml
01:09:57,489 INFO [FacesConfigurator] Reading config
/WEB-INF/faces-config.xml
01:09:57,569 ERROR [LocaleUtils] Locale name null or empty, ignoring
01:09:57,769 INFO [StartupServletContextListener] ServletContext
'C:\jboss-4.0.4.GA\server\default\.\tmp\deploy\tmp53162MyJSF -exp.war\'
initialized.
01:09:57,849 INFO [TomcatDeployer] deploy, ctxPath=/jmx-console,
warUrl=.../deploy/jmx-console.war/
01:09:58,059 INFO [Http11BaseProtocol] Starting Coyote HTTP/1.1 on
http-0.0.0.0-8080
01:09:58,220 INFO [ChannelSocket] JK: ajp13 listening on /0.0.0.0:8009
01:09:58,220 INFO [JkMain] Jk running ID=0 time=0/81 config=null
01:09:58,240 INFO [Server] JBoss (MX MicroKernel) [4.0.4.GA (build:
CVSTag=JBoss_4_0_4_GA date=200605151000)] Started in 12s:248ms
01:11:02,582 INFO [[/MyJSF]] No state saving method defined, assuming
default server state saving
01:11:02,853 ERROR [[Faces Servlet]] Servlet.service() for servlet Faces
Servlet threw exception
java.lang.StackOverflowError
at
org.apache.catalina.connector.RequestFacade.getSession(Reque stFacade.java:822)
at
javax.servlet.http.HttpServletRequestWrapper.getSession(Http ServletRequestWrapper.java:215)
at
org.apache.catalina.core.ApplicationHttpRequest.getSession(A pplicationHttpRequest.java:544)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Exception when accessing JSP page [message #473672 is a reply to message #473671] |
Mon, 30 October 2006 07:29 |
Hi Cameron,
I tried with a JSP page and the same problem also occurs. So I already
posted on the webtools group though I still got no help yet. In the mean
time, I tried differently with the Apache Tomcat server, instead of JBOSS,
I get a different error this time. It looks to me something is missing but
I don't know what as I have followed everystep in the JSF user section in
the Help content of the Eclipse. I am curious Has anyone successfully
created a JSF web project with latest eclipse and if someone does I would
like to know the versions of all the packages required. Here is the
messages from Apache when I try to access the login.jsp in the eclipse
tutorial for JSF.
Thanks a lot,
Luong
Oct 29, 2006 11:20:40 PM org.apache.catalina.core.AprLifecycleListener
lifecycleEvent
INFO: The Apache Tomcat Native library which allows optimal performance in
production environments was not found on the java.library.path:
C:\jdk1.5.0_09\bin;.;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDO WS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\ATI Technologies\ATI Control
Panel;C:\j2sdk1.4.2_09\bin;C:\php;C:\Program Files\cvsnt;C:\Program
Files\QuickTime\QTSystem\;
Oct 29, 2006 11:20:40 PM org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Oct 29, 2006 11:20:40 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 711 ms
Oct 29, 2006 11:20:41 PM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Oct 29, 2006 11:20:41 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.20
Oct 29, 2006 11:20:41 PM org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
Oct 29, 2006 11:20:41 PM org.apache.catalina.core.ApplicationContext log
SEVERE: StandardWrapper.Throwable
at javax.faces.webapp.FacesServlet.init(FacesServlet.java:144)
at
org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:1105)
at org.apache.catalina.core.StandardWrapper.load(StandardWrappe r.java:932)
at
org.apache.catalina.core.StandardContext.loadOnStartup(Stand ardContext.java:3951)
at
org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4225)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1013)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:718)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:442)
at
org.apache.catalina.core.StandardService.start(StandardServi ce.java:450)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:709)
at org.apache.catalina.startup.Catalina.start(Catalina.java:551 )
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 94)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:43 2)
Oct 29, 2006 11:20:41 PM org.apache.catalina.core.StandardContext
loadOnStartup
SEVERE: Servlet /JSFTutorial threw load() exception
at
at
at
at
at
at
Oct 29, 2006 11:20:41 PM org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Oct 29, 2006 11:20:41 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Oct 29, 2006 11:20:41 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/140 config=null
Oct 29, 2006 11:20:41 PM org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
Oct 29, 2006 11:20:41 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 911 ms
Oct 29, 2006 11:20:42 PM org.apache.catalina.core.ApplicationContext log
at
at
org.apache.catalina.core.StandardWrapper.allocate(StandardWr apper.java:757)
at
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:130)
at
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:178)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:126)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:105)
at
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:107)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:148)
at
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:869)
at
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:664)
at
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:527)
at
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:80)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:595)
Oct 29, 2006 11:20:42 PM org.apache.catalina.core.StandardWrapperValve
invoke
SEVERE: Allocate exception for servlet Faces Servlet
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Exception when accessing JSP page [message #473698 is a reply to message #473675] |
Tue, 31 October 2006 06:54 |
Hi Cameron,
I tried using both Sun's implementation and Myfaces from apache. I will
try using eclipse and plugins from eclipse.org instead of the lomboz
bundles.
Luong
Re: Exception when accessing JSP page [message #473706 is a reply to message #473696] |
Mon, 13 November 2006 06:32 |
I remove everything and restart from scratch in hope that I did something
foolish in the first time. I still have problem but I guess this time I
kinda know what problem it is even though I don't know how to fix it.
Hopefully you or someone could help me out as our project is stuck right
here, getting nowhere.
This time a simple JSP file will be OK. But if I added the 2 lines:
<%@ taglib uri="http://java.sun.com/jsf/core" prefix="f" %>
<%@ taglib uri="http://java.sun.com/jsf/html" prefix="h" %>
then any tag with the prefix f or h, such as <f:view> or <h:form>
following the JSF example in eclipse. I will get this error message in
browser:
type Exception report
message
description The server encountered an internal error () that prevented it
from fulfilling this request.
exception
org.apache.jasper.JasperException: Exception in JSP: /hi.jsp:12
9: <title>Insert title here</title>
10: </head>
11: <body>
12: <h:form>
13: </h:form>
14: </body>
15: </html>
Stacktrace:
org.apache.jasper.servlet.JspServletWrapper.handleJspExcepti on(JspServletWrapper.java:506)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:395)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:314)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :264)
javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:96)
root cause
javax.faces.webapp.UIComponentTag.setupResponseWriter(UIComp onentTag.java:929)
javax.faces.webapp.UIComponentTag.doStartTag(UIComponentTag. java:310)
org.apache.jsp.hi_jsp._jspx_meth_h_form_0(hi_jsp.java:88)
org.apache.jsp.hi_jsp._jspService(hi_jsp.java:63)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:97)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:334)
and the following messages in eclipse console:
22:14:23,796 ERROR [UIComponentTag] Faces context not found.
getResponseWriter will fail. Check if the FacesServlet has been
initialized at all in your web.xml.
22:14:23,796 ERROR [[jsp]] Servlet.service() for servlet jsp threw
exception
at
at javax.faces.webapp.UIComponentTag.doStartTag(UIComponentTag. java:310)
at org.apache.jsp.hi_jsp._jspx_meth_h_form_0(hi_jsp.java:88)
at org.apache.jsp.hi_jsp._jspService(hi_jsp.java:63)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:97)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
at
at
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java :264)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:252)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:173)
at
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:202)
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
at
at
org.jboss.web.tomcat.security.SecurityAssociationValve.invok e(SecurityAssociationValve.java:175)
at
org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccCo ntextValve.java:74)
at
at
at
org.jboss.web.tomcat.tc5.jca.CachedConnectionValve.invoke(Ca chedConnectionValve.java:156)
at
at
at
at
at
at
org.apache.tomcat.util.net.MasterSlaveWorkerThread.run(Maste rSlaveWorkerThread.java:112)
at java.lang.Thread.run(Thread.java:534)
It seems to me that the servlet or whoever does not recognize the tag
<f:view> or <h:form>. I did set the JSF libraries to the MyFaces
implementation included in JBOSS2.0.5 and here is my web.xml:
<!DOCTYPE web-app PUBLIC "-//Sun Microsystems, Inc.//DTD Web Application
2.3//EN" "http://java.sun.com/dtd/web-app_2_3.dtd">
<web-app id="WebApp_ID">
<display-name>JSF</display-name>
<listener>
<listener-class>org.apache.myfaces.webapp.StartupServletContextListener </listener-class>
</listener>
<servlet>
<servlet-name>Faces Servlet</servlet-name>
<servlet-class>
javax.faces.webapp.FacesServlet</servlet-class>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>*.faces</url-pattern>
</servlet-mapping>
<welcome-file-list>
<welcome-file>index.html</welcome-file>
<welcome-file>index.htm</welcome-file>
<welcome-file>index.jsp</welcome-file>
<welcome-file>default.html</welcome-file>
<welcome-file>default.htm</welcome-file>
<welcome-file>default.jsp</welcome-file>
</welcome-file-list>
</web-app>
Please help as we are quite frustrated. We didn't know the set up and
configuration is such challenging just to try a hellp world JSF page. Tons
of thanks to you.
-L. Ngo
Re: Exception when accessing JSP page [message #608355 is a reply to message #473671] |
Luong Mising name Messages: 4 Registered: September 2009 |
Hi Cameron,
tutorial for JSF.
Thanks a lot,
Luong
lifecycleEvent
at
at
at
at
at
at
loadOnStartup
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
invoke
at
at
at
at
at
at
at
at
at
at
at
at
at
Current Time: Thu Apr 25 17:58:01 GMT 2024
Powered by FUDForum. Page generated in 5.05577 seconds
