Home » Modeling » UML2 » Compatibility of models from 2.0.3 and 2.1
Compatibility of models from 2.0.3 and 2.1 [message #473449] |
Thu, 28 June 2007 17:04 |
Dave Carlson Messages: 402 Registered: July 2009 |
I saved a model using UML2 2.1 (created using the UML2Tools editor), then
attempted to open it in an older workspace using UML2 2.0.3. I got lots of
ClassCastException and NullPointerException, resulting from EMF
deserializing everything to AnyType. Opening in the UML2 tree editor for
2.0.3, it defaulted to the EMF generic reflective edit providers.
I discovered that this is because UML2.2.1 saves models using the URI
http://www.eclipse.org/uml2/2.1.0/UML, whereas
http://www.eclipse.org/uml2/2.0.0/UML is used in the 2.0.3 release. I found
a note about this in the New and Noteworthy. However, a specific note about
lack of backward compatibility should be added.
In the 2.1 release of org.eclipse.uml2.uml, the following extension points
allow both new and old models to be opened:
<extension point="org.eclipse.emf.ecore.generated_package">
<package
uri = "http://www.eclipse.org/uml2/2.0.0/UML"
class = "org.eclipse.uml2.uml.UMLPackage"
genModel = "model/UML.genmodel" />
</extension>
<package
uri = "http://www.eclipse.org/uml2/2.1.0/UML"
</extension>
If I add the 2.1.0 URI declaration to my plugin used with UML2 2.0.3, then
new models are opened there without error. Although, I realize that some
Activity models created using the new release will not open successfully in
the 2.0.3 tools.
Any other workarounds to allow new models to be opened in 2.0.3 release
tools?
Dave Carlson
Re: Compatibility of models from 2.0.3 and 2.1 [message #473451 is a reply to message #473449] |
Thu, 28 June 2007 17:51 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Dave,
There is a 2.0.4 maintenance release that you should upgrade your 2.0.3
users that will allow them to open up 2.1 models in the older version.
There is a minor issue that was discovered just the other day so a new build
of 2.0.4 will be produced.
There is also a draft version of a migration document that will be published
explaining all of this and why the metamodel was changed.
I will attach the draft version of the migration doc on bugzilla 77413 later
today.
- James.
"Dave Carlson" <dcarlson@xmlmodeling.com> wrote in message
news:f60pn3$215$1@build.eclipse.org...
of
found
about
> <package
> </extension>
> <package
> </extension>
in
> the 2.0.3 tools.
> tools?
> Dave Carlson
Re: Compatibility of models from 2.0.3 and 2.1 [message #473765 is a reply to message #473453] |
Thu, 05 July 2007 14:17 |
Hi Dave,
I would recommend picking up the latest M build of 2.0.4 to test migration.
It can be found here:
http://www.eclipse.org/modeling/mdt/news/relnotes.php?projec t=uml2&version=M200707041607
http://www.eclipse.org/modeling/mdt/downloads/?project=uml2& amp;showAll=1&hlbuild=M200707041607#M200707041607
The format of the plugin specification has changed slightly. Try using the
following in a debug envirionment
-Dorg.eclipse.uml2.common.util.CacheAdapter.INSTANCE=org.ecl ipse.uml2.uml:or
g.eclipse.uml2.uml.util.UMLCacheAdapter
Without setting that variable, you will not be able to open up 2.1 models in
2.0.4 environment.
An updated migration document will be posted soon.
- James.
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:f612nd$lln$2@build.eclipse.org...
> Hi Dave,
> Kenn mentioned it in the newsgroup in a posting entitled "Namespace URI
for
> UML2 2.1" . I agree that this might be a little obscure :) The "new &
> noteworthy" link is probably the best way to keep on top of new features
or
> important bug fixes.
> I just attached a draft document to bugzilla 77413. Let me know if that
> answers all the issues you had.
> Cheers,
> - James.
> news:f61233$k77$1@build.eclipse.org...
> > Hi James,
> > Great, thanks for the details. I was surprised not to see this
mentioned
> > before, but am not surprised by the thoroughness of your team's response
> in
> > resolving it :-)
> > Dave
> > news:f60sed$7ra$2@build.eclipse.org...
> > > Hi Dave,
2.0.3
> > > build
> > > published
> > > later
> > > today.
Re: Compatibility of models from 2.0.3 and 2.1 [message #473767 is a reply to message #473765] |
Thu, 05 July 2007 14:19 |
Kenn Hussey Messages: 1620 Registered: July 2009 |
James,
Without that system property, you'll be able to open 2.1 models in 2.0.4,
but models containing transitions and/or connectors will be incomplete.
Kenn
news:f6iui5$3qb$2@build.eclipse.org...
> Hi Dave,
> migration.
> the
> in
> 2.0.4 environment.
> Regards,
> - James.
>> Hi Dave,
> for
> or
>> Cheers,
>> - James.
>> > Hi James,
> mentioned
>> > response
>> in
>> > resolving it :-)
>> > Dave
>> > > Hi Dave,
> 2.0.3
>> > > version.
>> > > new
>> > > build
>> > > published
>> > > 77413
>> > > later
>> > > today.
Re: Compatibility of models from 2.0.3 and 2.1 [message #473770 is a reply to message #473767] |
Thu, 05 July 2007 15:24 |
.... that's what I meant ;-)
Thanks for clarifying Kenn.
- James.
"Kenn Hussey" <khussey@ca.ibm.com> wrote in message
news:f6iulj$43f$1@build.eclipse.org...
> James,
> Kenn
> > Hi Dave,
> > migration.
> > the
or
models
> > in
> > 2.0.4 environment.
> > Regards,
> > - James.
> >> Hi Dave,
> > for
"new
features
> > or
that
> >> Cheers,
> >> - James.
> >> > Hi James,
> > mentioned
> >> > response
> >> in
> >> > resolving it :-)
> >> > Dave
> >> > > Hi Dave,
> > 2.0.3
> >> > > version.
> >> > > new
> >> > > build
> >> > > published
> >> > > 77413
> >> > > later
> >> > > today.
Re: Compatibility of models from 2.0.3 and 2.1 [message #622664 is a reply to message #473449] |
Hi Dave,
today.
- James.
of
found
about
> <package
> </extension>
> <package
> </extension>
in
> the 2.0.3 tools.
> tools?
> Dave Carlson
Re: Compatibility of models from 2.0.3 and 2.1 [message #622823 is a reply to message #473453] |
Hi Dave,
2.0.4 environment.
- James.
> Hi Dave,
for
or
> Cheers,
> - James.
> > Hi James,
mentioned
> in
> > resolving it :-)
> > Dave
> > > Hi Dave,
2.0.3
> > > build
> > > published
> > > later
> > > today.
Re: Compatibility of models from 2.0.3 and 2.1 [message #622829 is a reply to message #473765] |
James,
Kenn
> Hi Dave,
> migration.
> the
> in
> 2.0.4 environment.
> Regards,
> - James.
>> Hi Dave,
> for
> or
>> Cheers,
>> - James.
>> > Hi James,
> mentioned
>> > response
>> in
>> > resolving it :-)
>> > Dave
>> > > Hi Dave,
> 2.0.3
>> > > version.
>> > > new
>> > > build
>> > > published
>> > > 77413
>> > > later
>> > > today.
Re: Compatibility of models from 2.0.3 and 2.1 [message #622836 is a reply to message #473767] |
- James.
> James,
> Kenn
> > Hi Dave,
> > migration.
> > the
or
models
> > in
> > 2.0.4 environment.
> > Regards,
> > - James.
> >> Hi Dave,
> > for
"new
features
> > or
that
> >> Cheers,
> >> - James.
> >> > Hi James,
> > mentioned
> >> > response
> >> in
> >> > resolving it :-)
> >> > Dave
> >> > > Hi Dave,
> > 2.0.3
> >> > > version.
> >> > > new
> >> > > build
> >> > > published
> >> > > 77413
> >> > > later
> >> > > today.
Current Time: Fri Apr 19 22:34:17 GMT 2024
Powered by FUDForum. Page generated in 0.03711 seconds
