Validation Problem [message #473446] |
Thu, 28 June 2007 10:50 |
Originally posted by: antti.evesti.vtt.fi
When I validate an ecore profile which I get after profile definition I get
'Validation Problems' warning that says 'Reason: Diagnosis of
<<Package>><Profile> Ecore Profile', and details view shows 'Not all the
members of namespace <Profile> Ecore Profile are distinguishable within it.'
If I validate my profile validation ends succesfully.
This doesn't cause any further problems, but it would be nice to know if I
have constructed my profile in a wrong way.
Antti
Re: Validation Problem [message #473454 is a reply to message #473448] |
Fri, 29 June 2007 05:58 |
Hi James,
I noticed this issue with many profiles as well as this simple profile that
contains only one stereotype applicable to component element.
Below is the content of the profile, I used filename SampleToNews.uml while
constructing this profile. I suppose it is illegal to attach files to this
newsgroup.
Antti
<uml:Profile xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
xmi:id="_ETNtoCYEEdyaa53nuWYv-g" name="sampleProfile"
metaclassReference="_KoWqwCYEEdyaa53nuWYv-g">
<eAnnotations xmi:id="_TndTwSYEEdyaa53nuWYv-g"
source="http://www.eclipse.org/uml2/2.0.0/UML">
<contents xmi:type="ecore:EPackage" xmi:id="_TndTwiYEEdyaa53nuWYv-g"
nsURI="http:///schemas/sampleProfile/_TndTwCYEEdyaa53nuWYv-g/0"
nsPrefix="sampleProfile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_TndTwyYEEdyaa53nuWYv-g"
name="sampleStereotype">
<eAnnotations xmi:id="_TndTxCYEEdyaa53nuWYv-g"
references="_MDOtUCYEEdyaa53nuWYv-g"/>
<eStructuralFeatures xmi:type="ecore:EReference"
xmi:id="_TndTxSYEEdyaa53nuWYv-g" name="base_Component" ordered="false"
lowerBound="1">
<eType xmi:type="ecore:EClass"
href="http://www.eclipse.org/uml2/2.0.0/UML#//Component"/>
</eStructuralFeatures>
</eClassifiers>
</contents>
</eAnnotations>
<elementImport xmi:id="_KoWqwCYEEdyaa53nuWYv-g">
<importedElement xmi:type="uml:Class"
href="pathmap://UML_METAMODELS/UML.metamodel.uml#Component"/>
</elementImport>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_MDOtUCYEEdyaa53nuWYv-g"
<ownedAttribute xmi:id="_RBYCUiYEEdyaa53nuWYv-g" name="base_Component"
association="_RBYCUCYEEdyaa53nuWYv-g">
<type xmi:type="uml:Class"
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_RBYCUCYEEdyaa53nuWYv-g"
name="Component_sampleStereotype" memberEnd="_RBYCUSYEEdyaa53nuWYv-g
_RBYCUiYEEdyaa53nuWYv-g">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_RBYCUSYEEdyaa53nuWYv-g"
name="extension_sampleStereotype" type="_MDOtUCYEEdyaa53nuWYv-g"
aggregation="composite" association="_RBYCUCYEEdyaa53nuWYv-g"/>
</packagedElement>
</uml:Profile>
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:f60cqt$pm9$2@build.eclipse.org...
> Hi Antti,
> Are there any obvious items with the same name within your profile? If
> not, would it be possible to post your profile.
> Not all the validation rules have been implemented in UML.
> EMF validation rules are different so you might get a UML model that
> passes
> UML validation but the resulting .ecore representation having warnings or
> errors.
> - James
> "Antti Evesti" <antti.evesti@vtt.fi> wrote in message
> news:f603pr$3mi$1@build.eclipse.org...
>> Hi,
> get
> it.'
>> I
>> Antti
Re: Validation Problem [message #473939 is a reply to message #473756] |
Tue, 10 July 2007 12:39 |
Thanks Kenn,
This relieve me of.
Antti
"Kenn Hussey" <khussey@ca.ibm.com> wrote in message
news:f6h1j3$qs1$1@build.eclipse.org...
> Antti,
> You can safely ignore this warning. It's complaining about the fact that
> the Ecore profile imports type named 'String' and 'Boolean' but also
> imports the UML metamodel package which in turn contains types named
> 'String' and 'Boolean'.
> Kenn
>> Hi,
>> get 'Validation Problems' warning that says 'Reason: Diagnosis of
>> it.'
>> I have constructed my profile in a wrong way.
>> Antti
Re: Validation Problem [message #622667 is a reply to message #473448] |
Hi James,
newsgroup.
Antti
lowerBound="1">
</eClassifiers>
</contents>
</eAnnotations>
</elementImport>
</ownedAttribute>
</packagedElement>
</packagedElement>
</uml:Profile>
> Hi Antti,
> passes
> errors.
> - James
>> Hi,
> get
> it.'
>> I
>> Antti
Re: Validation Problem [message #623315 is a reply to message #473756] |
Thanks Kenn,
This relieve me of.
Antti
> Antti,
> Kenn
>> Hi,
>> it.'
>> Antti
FUDForum. Page generated in 0.03630 seconds
