Home » Modeling » UML2 » basic question: how to load a uml model?
basic question: how to load a uml model? [message #473203] |
Fri, 15 June 2007 01:56 |
Leila Naslavsky Messages: 13 Registered: July 2009 |
Hi All,
I'm trying to load a uml file programmatically, running a standalone Java
application.
I'm running Eclipse SDK 3.3.0 build I20070601-1539
I'm using the example in the "UML2Article" (I call
registerResourceFactories(), and registerPathmaps(URI uri), and load(URI
uri)).
My uml model has only one 'Model' and one 'Class'.
The resources are loaded, because when I call resource.getAllContents()
and print it, I get:
org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl@a3aa2c (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@f95165 (name: Model)
(instanceClassName: null) (abstract: false, interface: false)) (mixed:
[ecore.xml.type:text=
, packagedElement=org.eclipse.emf.ecore.xml.type.impl.AnyTypeImpl@ed1dbe
(eClass: org.eclipse.emf.ecore.impl.EClassImpl@3bc1a1 (name: Class)
(instanceClassName: null) (abstract: false, interface: false)) (mixed: [],
anyAttribute: [name=Minha Classe]), ecore.xml.type:text=
], anyAttribute: [name=Meu Modelo])
but when I call
package_ = (org.eclipse.uml2.uml.Package)
EcoreUtil.getObjectByType(resource.getContents(),UMLPackage. Literals.PACKAGE);
The package_ is null.
I understand the resources are not UML (type) resources. But I don't know
how to fix this.
I've seen the posts in this newsgroup, and (apparently) I'm doing what I
should...
Could anyone help me with this?
- Leila
Re: basic question: how to load a uml model? [message #473205 is a reply to message #473203] |
Fri, 15 June 2007 13:55 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Leila,
By the "UML2Article" ... I assume you mean the migration guide?
Having AnyTypes left over would lead me to suspect there is some
unrecognized content in your original model. Are you migrating an older
model? How did you create your model? With the UML editor or some other
tool? Does your model have a package at the root.
I would suggest...
1. Try getting the latest RC3 build ( this should be the final build of
UML ). Verify you have all the correct depencies.
2. Follow the instructions in the migration guide to create stand alone
application ( you probably have done this already ).
3. Try to open your model with the UML editor, does it open? are there
errors?
4. Try to open your model programmatically.
5. If that still doesn't work, post your model and I can take a look at it.
- James.
"Leila" <lnaslavsky@hotmail.com> wrote in message
news:16885e849e2549a5604d49f755529c50$1@www.eclipse.org...
> Hi All,
> application.
> uri)).
> but when I call
> how to fix this.
> should...
> - Leila
Re: basic question: how to load a uml model? [message #473207 is a reply to message #473205] |
Fri, 15 June 2007 15:56 |
Hi James,
Yes, thats the migration article.
I created the model with the editor, so I'm not trying to migrate (just
using that example because it is an example :). It opens with the editor
and it has a package in the root.
I realized I wasn't registering the package
(RESOURCE_SET.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE)) , however, since this line of code is nowhere in
the example, I thought I wouldn't need it.
(My Bad, sorry!).
Now it loads the model programmatically, but I still don't fully
understand how the example works without registering the package and my
code didn't.
Thanks again!
- Leila
Re: basic question: how to load a uml model? [message #473209 is a reply to message #473207] |
Fri, 15 June 2007 17:03 |
Hi Leila,
That code does appear in the article ...have a look at the function
registerPackages(...) ... the very last line by "tag 2".
Can you find it? You should be able to cut and paste verbatim from that
aricle. If there is still an issue, please let me know.
- James.
news:c19feba9988a0a0a75d6b2643ea31456$1@www.eclipse.org...
> Hi James,
> (My Bad, sorry!).
> code didn't.
> Thanks again!
> - Leila
Re: basic question: how to load a uml model? [message #621683 is a reply to message #473203] |
Hi Leila,
I would suggest...
errors?
- James.
> Hi All,
> application.
> uri)).
> but when I call
> how to fix this.
> should...
> - Leila
Re: basic question: how to load a uml model? [message #621685 is a reply to message #473205] |
Hi James,
(My Bad, sorry!).
code didn't.
Thanks again!
- Leila
Re: basic question: how to load a uml model? [message #621690 is a reply to message #473207] |
Hi Leila,
- James.
> Hi James,
> (My Bad, sorry!).
> code didn't.
> Thanks again!
> - Leila
Current Time: Thu Apr 25 21:18:11 GMT 2024
Powered by FUDForum. Page generated in 0.03428 seconds
