Home » Modeling » UML2 » Re: proxy resolution problem
Re: proxy resolution problem [message #473101] |
Wed, 06 June 2007 13:28 |
Hi, Laurent,
Are these objects UML Properties? (the term "role" suggests so) The UML
metamodel made a change just prior to the 2.1 M7 milestone, in which the
ConnectorEnd::role <--> ConnectableElement::end association is no longer
bidirectional, but directed from ConnectorEnd to ConnectableElement.
I think the UML2 implementation should be using its inverse-referencing
CacheAdapter to make the resolved O1 know the same role as the proxy.
I have replied to UML2 newsgroup for somebody there to comment further ...
Christian
Laurent Le Goff wrote:
> We have found a strange thing related to EMF2.1 proxies and
> inter-resources references. We have two Objects O1 and O2. There is a
> bidir relation between these two.
> O1 <-role1--------role2-> O2
> Both objects are stored on different resource files R1 and R2. When O1 is
> loaded from R1, object O2 is not loaded but replaced by a proxy O2' which
> behaves like O2. Particularily, its role1 is O1. Later when the O2' proxy
> is resolved, it appears that the corresponding O2 element is effectively
> loaded from R2, but unfortunatelly, its role1 is null.
> Note that role1 is defined transient in O2 and thus is missing in R2.
> Is it normal for the resolved objet O2 to have a different role1 than
> its proxy O2' ?
> We have locally bugfixed this behavior by using a specific
> ModificationTrackingAdapter attached to our resources. Is that a good
> idea/use of the ResourceTracking mechanism ?
> Sam et Laurent
Re: proxy resolution problem [message #473102 is a reply to message #473101] |
Wed, 06 June 2007 15:31 |
Laurent LE GOFF Messages: 15 Registered: July 2009 |
Hi Christian,
this is a an ecore model not a UML2 model. I guess the name "role" can be
used IMHO in ECORE metamodel and UML2 metamodel.
On Wed, 06 Jun 2007 09:28:21 -0400, Christian W. Damus wrote:
> Hi, Laurent,
How can I do with an Adapter ? please
Laurent et Sam
further
> Cheers,
> Christian
>> is loaded from R1, object O2 is not loaded but replaced by a proxy O2'
>> which behaves like O2. Particularily, its role1 is O1. Later when the
>> O2' proxy is resolved, it appears that the corresponding O2 element is
>> effectively loaded from R2, but unfortunatelly, its role1 is null.
>> its proxy O2' ?
>> Sam et Laurent
Re: proxy resolution problem [message #473103 is a reply to message #473102] |
Wed, 06 June 2007 15:45 |
Hi, Laurent,
What a coincidence! The UML metamodel just happens to have a similar
situation with similar names. Therefore, it may provide you an example of
how to resolve your problem.
Have a look at how the
org.eclipse.uml2.uml.internal.operations.ConnectableElementO perations
class's getEnds(ConnectableElement) method uses an inverse-reference query
to add ConnectorEnds to the resultant list that are not actually
serialized. The ConnectableElementOperations::getEnds(ConnectableElement)
method is used, for example, by the
org.eclipse.uml2.uml.internal.impl.PropertyImpl::getEnds() method.
The UML2 2.1 API uses its CacheAdapter (which is an ECrossReferenceAdapter)
to perform this reverse-reference look-up to handle the fact that, in UML2
2.0, the ConnectorEnd <--> ConnectableElement association was bidirectional
and in UML2 2.1 it is directed (ConnectorEnd --> ConnectableElement).
Thus, the reverse direction is semi-derived (when migrating a UML model
from the 2.0 serial format, explicit values are loaded from disk, but they
are not saved out in the 2.1 format).
HTH,
Christian
> Hi Christian,
>> Hi, Laurent,
> Laurent et Sam
> further
>> Cheers,
>> Christian
>>> its proxy O2' ?
>>> Sam et Laurent
Re: proxy resolution problem [message #619757 is a reply to message #473101] |
Hi Christian,
> Hi, Laurent,
Laurent et Sam
further
> Cheers,
> Christian
>> its proxy O2' ?
>> Sam et Laurent
Re: proxy resolution problem [message #619760 is a reply to message #473102] |
Hi, Laurent,
HTH,
Christian
> Hi Christian,
>> Hi, Laurent,
> Laurent et Sam
> further
>> Cheers,
>> Christian
>>> its proxy O2' ?
>>> Sam et Laurent
Current Time: Thu Apr 25 23:39:30 GMT 2024
Powered by FUDForum. Page generated in 0.03096 seconds
