Which UML2 "Diagram Element" should be selected for GMF [message #472721] |
Mon, 28 January 2008 12:01 |
Originally posted by: amsurana.in.ibm.com
This is a multipart message in MIME format.
--=_alternative 0041A39C652573DE_=
Content-Type: text/plain; charset="US-ASCII"
I am creating my own custom component model. I am using UML2
Superstructure and GMF. I went thru the UML2TOOLS Component Diagram. Still
i ve few doubts.
Doubt :
Which is the "diagram element" to be selected when creating *.gmfgraph,
*.gmftool, *.gmfmap. I am using the UML.ecore file present in
"org.eclipse.uml2.uml" plugin.
When I selected "package" as my "diagram element" and created the GMF
editor, I couldnt draw any component or any other tool on the screen ...
what should i do to able to draw components and other packages on the
screen.
please help,
Regards ,
Amit
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hi, </font>
<br><font size=2 face="sans-serif">I am creating my own custom component
model. I am using UML2 Superstructure and GMF. I went thru the UML2TOOLS
Component Diagram. Still i ve few doubts.</font>
<br>
<br><font size=2 face="sans-serif">Doubt : </font>
<br><font size=2 face="sans-serif"> Which is the "diagram element"
to be selected when creating *.gmfgraph, *.gmftool, *.gmfmap. I am using
the UML.ecore file present in "org.eclipse.uml2.uml" plugin.
</font>
<br>
<br><font size=2 face="sans-serif">When I selected "package"
as my "diagram element" and created the GMF editor, I couldnt
draw any component or any other tool on the screen ... what should i do
to able to draw components and other packages on the screen. </font>
<br>
<br><font size=2 face="sans-serif">please help,</font>
<br>
<br><font size=2 face="sans-serif">Regards ,</font>
<br><font size=2 face="sans-serif">Amit</font>
<br>
--=_alternative 0041A39C652573DE_=--
Re: Which UML2 "Diagram Element" should be selected for GMF [message #473263 is a reply to message #473254] |
Fri, 01 February 2008 07:27 |
--=_alternative 00290AF4652573E2_=
hi
I tried generating my customized GMF editor from the component* files in
diagram defintions for uml2 components.
But even with those files m unable to draw any packages or components..
All i did was followed wizard to generate the *.gmfgraph , *.gmftool using
UML.ecore file provided in org.eclipse.uml2.uml
In *.gmfmap I had to delete many irrelevent diagrams which I dont want on
the screen.. So even by using "default" GMF tools m unable to create any
diagrams on screen.
I dunno where am I going wrong.
<br><font size=2 face="sans-serif">hi </font>
<br><font size=2 face="sans-serif">I tried generating my customized GMF
editor from the component* files in diagram defintions for uml2 components.
</font>
<br><font size=2 face="sans-serif">But even with those files m unable to
draw any packages or components.. </font>
<br>
<br>
<br><font size=2 face="sans-serif">All i did was followed wizard to generate
the *.gmfgraph , *.gmftool using UML.ecore file provided in org.eclipse.uml2.uml</font>
<br><font size=2 face="sans-serif">In *.gmfmap I had to delete many irrelevent
diagrams which I dont want on the screen.. So even by using "default"
GMF tools m unable to create any diagrams on screen.</font>
<br><font size=2 face="sans-serif">I dunno where am I going wrong. </font>
--=_alternative 00290AF4652573E2_=--
Re: Which UML2 "Diagram Element" should be selected for GMF [message #473264 is a reply to message #473254] |
Fri, 01 February 2008 08:12 |
--=_alternative 002D33B9652573E2_=
It works now... The problem was tat UML2Tools Component Diagram uses their
own CustomLayout named "CenterLayout".
Thanks for the help...
Regards , Amit
<br><font size=2 face="sans-serif">It works now... The problem was tat
UML2Tools Component Diagram uses their own CustomLayout named "CenterLayout".
</font>
<br><font size=2 face="sans-serif">Thanks for the help... </font>
<br><font size=2 face="sans-serif">Regards , Amit </font>
--=_alternative 002D33B9652573E2_=--
Re: Which UML2 "Diagram Element" should be selected for GMF [message #618247 is a reply to message #473254] |
hi
diagrams on screen.
</font>
<br>
<br>
Re: Which UML2 "Diagram Element" should be selected for GMF [message #618248 is a reply to message #473254] |
Regards , Amit
</font>
FUDForum. Page generated in 0.02150 seconds
