Home » Eclipse Projects » Nebula » Auto-resize a column?
Re: Auto-resize a column? [message #48168 is a reply to message #48149] |
Wed, 30 January 2008 11:08 |
Grant Slender Messages: 36 Registered: July 2009 |
Member |
Tom,
I guess porting TableColumnLayout to Grid might be the right approach,
but I'm looking for quick fix that won't take a large amount of effort.
As it turns out, I'm not getting any flicker - in fact it seems to work
fine when being controlled by the user. The only issue with my approach
is that at initial layout, when the size is determined, the code that
decides if the scroll bars should/shouldn't be shown is probably not
being called when I call setWidth on the column
Is there something I can call to programamtically make the grid check
its scroll bars properly after I setWidth on the column?
Grant
Tom Schindl wrote:
> I don't know if using a control-adapter is the right thing. At least we
> abondoned the solution for SWT-Table/SWT-Tree and use a layout-solution
> (because we had massive flicker problems).
> Did you tried to port the TableColumnLayout to Grid? Example can be
> found at (http://wiki.eclipse.org/JFaceSnippets).
> Tom
> Grant Slender schrieb:
>> Ok, my solution is not 100%
>> I think a bug might exist in grid - but I'm not sure??
>> When the grid is place inside a SashForm, and the sash is set to a %
>> such that the vertical scroll bar would show (ie the grid has not
>> enough space to show all rows) the start-up layout still shows the
>> horizontal scroll bar even though the resize events fired and the
>> table columns got reduced correctly. In fact, just touching the column
>> width again seems to fire the right event to realise that the
>> horizontal scroll bar does not need to be visible.
>> This behaviour does not occur when the shell is fully open - its a
>> problem that occurs only when building the initial displayed view.
>> Is this a bug in how Grid is responding to resize events before its
>> actually visible?
>> Cheers,
>> Grant
>> Grant Slender wrote:
>>> I developed a solution - not as elegant as something inbuilt, but it
>>> works...!!
>>> mainGrid.addControlListener(new ControlAdapter() {
>>> public void controlResized(ControlEvent e) {
>>> Grid g = (Grid)e.getSource();
>>> int size = (g.getSize().x - (otherColsWidth)) - g.getBorderWidth()*2;
>>> if (g.getVerticalBar().getVisible())
>>> size -= g.getVerticalBar().getSize().x;
>>> descColumn.setWidth(size < descColumnWidth ? descColumnWidth : size);
>>>> Hi,
>>>> Is there an option to have a column auto-resize to fill any gaps in
>>>> the layout of the grid (ie the user resizes the grid to bigger than
>>>> the needed column space and one column grows to this size leaving
>>>> the other columns at fixed widths) ??
>>>> Cheers,
>>>> Grant
Re: Auto-resize a column? [message #48195 is a reply to message #48168] |
Wed, 30 January 2008 11:18 |
Member |
It gets even more strange....???
This fixes it - but the 6 sec delay and approach is not a solution.
I can't understand why???
Thread t = new Thread()
public void run()
try
Thread.sleep(6000);
descColumn.setWidth(100); // any value
catch (InterruptedException e)
e.printStackTrace();
mainGrid.getDisplay().asyncExec(t);
> Tom,
> Grant
> Tom Schindl wrote:
>> Hi,
>> we abondoned the solution for SWT-Table/SWT-Tree and use a
>> layout-solution (because we had massive flicker problems).
>> Tom
>>> column width again seems to fire the right event to realise that the
>>> actually visible?
>>> Cheers,
>>> Grant
>>>> works...!!
>>>>> Hi,
>>>>> Cheers,
>>>>> Grant
Re: Auto-resize a column? [message #48225 is a reply to message #48195] |
Wed, 30 January 2008 11:29 |
Member |
Adding this seems to have fixed it for good. No flicker, perfect
behaviour so far. Would still like to know why its needed.
mainGrid.getDisplay().asyncExec(new Thread() {
public void run(){
descColumn.setWidth(descColumn.getWidth());
> public void run()
> try
> Thread.sleep(6000);
>> Tom,
>> work fine when being controlled by the user. The only issue with my
>> approach is that at initial layout, when the size is determined, the
>> code that decides if the scroll bars should/shouldn't be shown is
>> probably not being called when I call setWidth on the column
>> Thanks,
>> Grant
>> Tom Schindl wrote:
>>> Hi,
>>> Tom
>>>> actually visible?
>>>> Cheers,
>>>> Grant
>>>>> it works...!!
>>>>> size);
>>>>>> Hi,
>>>>>> in the layout of the grid (ie the user resizes the grid to bigger
>>>>>> than the needed column space and one column grows to this size
>>>>>> leaving the other columns at fixed widths) ??
>>>>>> Cheers,
>>>>>> Grant
Re: Auto-resize a column? [message #48376 is a reply to message #48225] |
Fri, 01 February 2008 17:19 |
Chris Gross Messages: 253 Registered: July 2009 |
Hi Grant,
The Grid does do some tricky stuff related to recalculating the
scrollbars. Can you write a quick snippet that demonstrates the problem
you're seeing? Something I can run as a test case?
-Chris
> public void run(){
>> public void run()
>> try
>> Thread.sleep(6000);
>> { // TODO Auto-generated catch block
>>> Tom,
>>> approach, but I'm looking for quick fix that won't take a large
>>> amount of effort.
>>> Thanks,
>>> Grant
>>> Tom Schindl wrote:
>>>> Hi,
>>>> Tom
>>>>> % such that the vertical scroll bar would show (ie the grid has not
>>>>> the horizontal scroll bar does not need to be visible.
>>>>> actually visible?
>>>>> Cheers,
>>>>> Grant
>>>>>> it works...!!
>>>>>> size);
>>>>>>> Hi,
>>>>>>> Cheers,
>>>>>>> Grant
Re: Auto-resize a column? [message #48484 is a reply to message #48376] |
Sat, 02 February 2008 09:52 |
Member |
Give me a day and I'll post a snippet that actually solves the problem
mostly for me, and a snippet that has the problem I identified with Grid
Grant
Chris Gross wrote:
> Hi Grant,
> -Chris
>> public void run(){
>> descColumn.setWidth(descColumn.getWidth()); }
>>> public void run()
>>> try
>>> Thread.sleep(6000);
>>>> Tom,
>>>> amount of effort.
>>>> check its scroll bars properly after I setWidth on the column?
>>>> Thanks,
>>>> Grant
>>>> Tom Schindl wrote:
>>>>> Hi,
>>>>> least we abondoned the solution for SWT-Table/SWT-Tree and use a
>>>>> Tom
>>>>>> not enough space to show all rows) the start-up layout still shows
>>>>>> the horizontal scroll bar even though the resize events fired and
>>>>>> the table columns got reduced correctly. In fact, just touching
>>>>>> the column width again seems to fire the right event to realise
>>>>>> that the horizontal scroll bar does not need to be visible.
>>>>>> its actually visible?
>>>>>> Cheers,
>>>>>> Grant
>>>>>>> it works...!!
>>>>>>> size);
>>>>>>>> Hi,
>>>>>>>> bigger than the needed column space and one column grows to this
>>>>>>>> size leaving the other columns at fixed widths) ??
>>>>>>>> Cheers,
>>>>>>>> Grant
Re: Auto-resize a column? [message #48514 is a reply to message #48376] |
Sat, 02 February 2008 22:01 |
Member |
--------------030606060903000506040800
Included here and as an attachment...
import org.eclipse.nebula.widgets.grid.*;
import org.eclipse.swt.*;
import org.eclipse.swt.custom.*;
import org.eclipse.swt.events.*;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
public class GridSashSnippet {
final Display display = new Display ();
final Shell shell = new Shell (display);
shell.setLayout(new FormLayout());
SashForm sashForm = new SashForm(shell,SWT.VERTICAL);
FormData formData = new FormData();
formData.top = new FormAttachment(0,0);
formData.left = new FormAttachment(0,0);
formData.right = new FormAttachment(100,0);
formData.bottom = new FormAttachment(100,0);
sashForm.setLayoutData(formData);
final int nameColumnWidth = 150;
final int descColumnWidth = 250;
final int amtColumnWidth = 100;
final int freqColumnWidth = 120;
final Grid mainGrid= new Grid(sashForm,SWT.BORDER | SWT.V_SCROLL |
SWT.H_SCROLL);
mainGrid.setHeaderVisible(true);
final GridColumn nameColumn = new GridColumn(mainGrid,SWT.NONE);
nameColumn.setText("Name");
nameColumn.setTree(true);
nameColumn.setWidth(nameColumnWidth);
final GridColumn descColumn = new GridColumn(mainGrid,SWT.NONE);
descColumn.setText("Description / Notes");
final GridColumn amtColumn = new GridColumn(mainGrid,SWT.RIGHT);
amtColumn.setText("Amount");
amtColumn.setWidth(amtColumnWidth);
final GridColumn freqColumn = new GridColumn(mainGrid,SWT.CENTER);
freqColumn.setText("Frequency");
freqColumn.setWidth(freqColumnWidth);
int othercolumns = nameColumn.getWidth() + amtColumn.getWidth() +
freqColumn.getWidth();
int size = (g.getSize().x - othercolumns) - g.getBorderWidth()*2;
if (g.getVerticalBar().getVisible()) {
size -= (g.getVerticalBar().getSize().x);
/** without a call to update, the grid opens showing an unneeded bottom
scroll bar
* that when you move the sash up or down, will go away as it is
supposed to
* the problem is that it should open not showing the bottom scroll bar !!
* a call to update here fixes the initial open display problem
// g.getDisplay().update();
//add some items to the grid
for (int bc =0; bc < 5;bc++) {
GridItem item1 = new GridItem(mainGrid,SWT.NONE);
item1.setText(0,"name"+bc);
item1.setText(1,"description"+bc);
for (int bi =0; bi < 3;bi++) {
GridItem item2 = new GridItem(item1,SWT.NONE);
item2.setText(0,"biname"+bi);
item2.setText(1,"bidescription"+bi);
item2.setText(2,bi+"");
item2.setText(3,"every day");
item1.setExpanded(true);
// add something to the lower part of the shell sashform
ScrolledComposite sc = new ScrolledComposite(sashForm,SWT.H_SCROLL |
SWT.V_SCROLL);
sc.setExpandHorizontal(true);
sc.setExpandVertical(true);
sc.setMinSize(450,200);
sashForm.setWeights(new int[] {60,40});
/** in this snippet, calling pack fixes problem and doesn't require a
call to update.
* in a larger application (where the grid might be on a tabfolder or
not just on a simple shell)
* this does not fix the problem and the call to update is the only
fix above...
// shell.pack ();
shell.open ();
shell.setSize(700,600);
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Chris Gross wrote:
> Hi Grant,
> -Chris
name="GridSashSnippet.java"
Content-Disposition: inline;
filename="GridSashSnippet.java"
final Grid mainGrid= new Grid(sashForm,SWT.BORDER | SWT.V_SCROLL | SWT.H_SCROLL);
int othercolumns = nameColumn.getWidth() + amtColumn.getWidth() + freqColumn.getWidth();
/** without a call to update, the grid opens showing an unneeded bottom scroll bar
* that when you move the sash up or down, will go away as it is supposed to
ScrolledComposite sc = new ScrolledComposite(sashForm,SWT.H_SCROLL | SWT.V_SCROLL);
/** in this snippet, calling pack fixes problem and doesn't require a call to update.
* in a larger application (where the grid might be on a tabfolder or not just on a simple shell)
* this does not fix the problem and the call to update is the only fix above...
// shell.pack ();
shell.open ();
display.dispose ();
--------------030606060903000506040800--
Re: Auto-resize a column? [message #50054 is a reply to message #48514] |
Wed, 27 February 2008 15:59 |
This is really confusing me. The Grid code seems correct but the events
are getting fired strangely. As far as I can tell the resize event is
getting processed _during_ the paint event?! Its almost as if there are
multiple threads going on here but there should not be.
Regardless, adding Display.update will trigger a new paint event and as
you've seen causes a recalculation of the scrollbars. There's no harm
in that update() call.
regards,
-Chris
> public static void main(String[] args) {
> | SWT.H_SCROLL);
> bottom scroll bar
> supposed to
> bar !!
> a call to update.
> fix above...
> // shell.pack ();
> shell.open ();
> display.dispose ();
> Chris Gross wrote:
>> Hi Grant,
>> problem you're seeing? Something I can run as a test case?
>> Thanks,
>> -Chris
Re: Auto-resize a column? [message #588185 is a reply to message #48149] |
Member |
Tom,
Grant
Tom Schindl wrote:
> Tom
>> actually visible?
>> Cheers,
>> Grant
>>> works...!!
>>>> Hi,
>>>> Cheers,
>>>> Grant
Re: Auto-resize a column? [message #588195 is a reply to message #48168] |
Member |
public void run()
try
Thread.sleep(6000);
> Tom,
> Grant
> Tom Schindl wrote:
>> Hi,
>> Tom
>>> actually visible?
>>> Cheers,
>>> Grant
>>>> works...!!
>>>>> Hi,
>>>>> Cheers,
>>>>> Grant
Re: Auto-resize a column? [message #588203 is a reply to message #48195] |
Member |
public void run(){
> public void run()
> try
> Thread.sleep(6000);
>> Tom,
>> Thanks,
>> Grant
>> Tom Schindl wrote:
>>> Hi,
>>> Tom
>>>> actually visible?
>>>> Cheers,
>>>> Grant
>>>>> it works...!!
>>>>> size);
>>>>>> Hi,
>>>>>> Cheers,
>>>>>> Grant
Re: Auto-resize a column? [message #588249 is a reply to message #48225] |
Chris Gross Messages: 471 Registered: July 2009 |
Hi Grant,
-Chris
> public void run(){
>> public void run()
>> try
>> Thread.sleep(6000);
>>> Tom,
>>> amount of effort.
>>> Thanks,
>>> Grant
>>> Tom Schindl wrote:
>>>> Hi,
>>>> Tom
>>>>> actually visible?
>>>>> Cheers,
>>>>> Grant
>>>>>> it works...!!
>>>>>> size);
>>>>>>> Hi,
>>>>>>> Cheers,
>>>>>>> Grant
Re: Auto-resize a column? [message #588293 is a reply to message #48376] |
Member |
Grant
Chris Gross wrote:
> Hi Grant,
> -Chris
>> public void run(){
>>> public void run()
>>> try
>>> Thread.sleep(6000);
>>>> Tom,
>>>> amount of effort.
>>>> Thanks,
>>>> Grant
>>>> Tom Schindl wrote:
>>>>> Hi,
>>>>> Tom
>>>>>> Cheers,
>>>>>> Grant
>>>>>>> it works...!!
>>>>>>> size);
>>>>>>>> Hi,
>>>>>>>> Cheers,
>>>>>>>> Grant
Re: Auto-resize a column? [message #588301 is a reply to message #48376] |
Member |
SWT.H_SCROLL);
scroll bar
supposed to
SWT.V_SCROLL);
call to update.
fix above...
// shell.pack ();
shell.open ();
display.dispose ();
Chris Gross wrote:
> Hi Grant,
> -Chris
// shell.pack ();
shell.open ();
display.dispose ();
Re: Auto-resize a column? [message #588808 is a reply to message #48514] |
regards,
-Chris
> | SWT.H_SCROLL);
> bottom scroll bar
> supposed to
> bar !!
> a call to update.
> fix above...
> // shell.pack ();
> shell.open ();
> display.dispose ();
> Chris Gross wrote:
>> Hi Grant,
>> Thanks,
>> -Chris
Current Time: Fri Apr 19 18:21:57 GMT 2024
Powered by FUDForum. Page generated in 0.04970 seconds
