Home » Eclipse Projects » Platform - User Assistance (UA) » General help documentation development question
General help documentation development question [message #472302] |
Wed, 06 February 2008 10:57  |
Hello all,
We are looking to integrate help documentation into our Eclipse based tool.
We are searching for an efficient means of doing this that allows us to:
a) Develop and maintain our documentation in an efficient way (i.e., a
traditional word processor)
b) Obtain the HTML files at the level of granularity necessary to populate
the built-in Eclipse help services, including infopop content, and
c) Publish traditional paper documentation (in the form of manuals) that we
would optionally make available to our customers
As we are currently an MS Word house, that was my first area of
investigation... however it appears that MS Word has no native means of
breaking up a documents content into individual HTML files. Thus, a 100
page reference manual would be exported to a single giant HTML file, which
is of much less use in the Eclipse help environment.
So my questions are:
1) What techniques/products do others use to accomplish these goals?
2) What mechanism does the Eclipse organization use to author and deploy
its own help content?
Many thanks,
-Pete
Re: General help documentation development question [message #472308 is a reply to message #472302] |
Fri, 08 February 2008 03:32   |
I have similar goals, and all of my documentation source is in DocBook.
With docbook you can generate just about anything (including Eclipse
help files). It has worked very well for me, and I have had my
documentation there for years, even before I migrated to eclipse, I used
to generate Java help from the docbook.
Pete Ellis wrote:
> Hello all,
> Many thanks,
> -Pete
Re: General help documentation development question [message #472429 is a reply to message #472426] |
Wed, 02 April 2008 11:41   |
Originally posted by: nospam_kowalskilee.gmail.com
Hi Marcus,
You wrote "traditional word processors". Would you list which ones you
are focused on? I mean, is it Word or FrameMaker or what else?
In general, it will not be easy to convert from an unstructured document
environment to a structured document environment. However, if you are
using FrameMaker, there is a product called "Mif2Go" that people are
using today to go from their FrameMaker mif files to generate the
Eclipse help files.
If your traditional word processor is Word, there might be some
conversion tools available to go from Word to DITA XML (which is an XML
format comparable to DocBook). From DITA XML, you can go to Eclipse help
like you do from DocBook.
One thing to think about is whether you mean to do a one-time conversion
and take all your traditional-created files to DocBook, and then
continue from that point in time with DocBook *or* do you mean to
continue authoring in the traditional word processor and generate the
Eclipse help files at build times. The answer to that will guide what
tools will best suit your need.
Lee Anne
Marcus Storre wrote:
> Hello,
> Currently we try to convert our documentation in DocBook as well, cause
> we like the possibility to generate easily any format we want to,
> especially the eclipse help files. We already tested it, and it really
> worked fine.
> Unfortunatly its not as easy to convert our current documentation
> (written with tradtional word processors) to DocBook, as it is to
> convert from DocBook to everything else.
> How do you generate your DocBook files? Do you write your documentation
> already in DocBook? If so, which Software can you recommend? Are there
> any effective alternatives to DocBook to get the Eclipse Help System
> files out of a traditional word processor?
> Thanks in advance,
> Marcus
Re: General help documentation development question [message #472431 is a reply to message #472429] |
Thu, 03 April 2008 07:08   |
Hi Lee Anne,
thank you for your fast reply. We started to evaluate a process to
generate DocBooks from .odt files, since OpenOffice 2.3.1 already has an
implemented DocBook Filter. Unfortunately we did not really receive the
results we hoped for. We also successful converted sxw files, but we try
to avoid this format.
Our support is documenting in Word and MindManager, so we are looking for
a persistent solution to generate Eclipse Help Files (or other formats)
out of a .doc document. MindManager is able to export in .doc so a
suitable solution for Word would be as fine as it would be for
MindManager. If there is no pleasant way to handle this, a one
time-conversion and working with DocBook - Editors might be an
alternative, but so far we try to avoid this as well.
DITA seems to be a decent alternative to DocBook, and we will consider
this format to replace DocBook, if it is easier to generate a structured
document environment from it that fits our needs.
Do you might have any suggestions, what a decent way could look like for
generating DocBook/DITA from .doc or .odt?
Sincerely,
Marcus
Lee Anne wrote:
> Hi Marcus,
> Eclipse help files.
> Best regards,
> Lee Anne
Re: General help documentation development question [message #472512 is a reply to message #472431] |
Fri, 04 April 2008 10:56   |
Hi Marcus,
I did some sleuthing on the DITA YahooGroup and I found this company's
tool: Information Mapping's Content Mapper tool mentioned:
http://www.infomap.com/index.cfm/Software/ContentMapper
That page says it is a "Microsoft Word-based XML authoring tool" *and*
that it has been configured with both DocBook and DITA.
I also found this company's products mentioned related to Word and XML
and Word and DITA:
http://www.invisionresearch.com/products.html
It has two products that look promising for a goal of authoring in Word
and then getting DITA and/or DocBook output:
Xpress Author http://www.invisionresearch.com/xpress.html
XPress Author sounds like it is an add-on to Word, where you work in
Word and it maps to an XML DTD or Schema. From the page, it sounds like
it might work with either DocBook or DITA.
Xpress DITA Studio http://www.invisionresearch.com/dita.html
Xpress DITA Studio seems to be a combo of Xpress Author (Word + their
XML add-on) *and* the tooling oriented to DITA concepts (DITA maps, DITA
DTD/schema, etc)
Then I found this company's tool: Information Mapping's Content Mapper
tool: http://www.infomap.com/index.cfm/Software/ContentMapper
That page says it is a "Microsoft Word-based XML authoring tool".
FYI, there's an active group of DITA exploiters on a YahooGroup named
dita-users. The group's home is here:
http://tech.groups.yahoo.com/group/dita-users/
There are folks who are interested in a Word->DITA solution that
participate on that list, as well as people who are experienced in
DocBook also--so you'd benefit from tapping them as a resource.
This posting at the dita-users group mentions the pricing for both
In.vision products and Information Mapping's Content Mapper product:
http://tech.groups.yahoo.com/group/dita-users/message/9051
I don't have experience with MindManager, so I cannot speak to that one.
Hope this helps!
Lee Anne
> Hi Lee Anne,
> results we hoped for. We also �successful� converted sxw files, but we
> try to avoid this format.
> for a persistent solution to generate Eclipse Help Files (or other
> formats) out of a .doc document. MindManager is able to export in .doc
> so a suitable solution for Word would be as fine as it would be for
> Sincerely,
> Marcus
> Lee Anne wrote:
>> Hi Marcus,
>> document environment to a structured document environment. However, if
>> you are using FrameMaker, there is a product called "Mif2Go" that
>> people are using today to go from their FrameMaker mif files to
>> generate the Eclipse help files.
>> XML format comparable to DocBook). From DITA XML, you can go to
>> Eclipse help like you do from DocBook.
>> conversion and take all your traditional-created files to DocBook, and
>> then continue from that point in time with DocBook *or* do you mean to
>> Best regards,
>> Lee Anne
Re: General help documentation development question [message #609395 is a reply to message #472302] |
Thu, 07 February 2008 19:42  |
The Eclipse team just edits the files as HTML - we don't have a separate
documentation team so each of the development teams is responsible for
creating its own content. Having developers create the content has the
benefit that it is usually pretty accurate but the drawback is that the
documentation ends up getting written by a lot of different people who
have varied writing skills and limited time and the style is not always
consistent.
In Eclipse 3.4 there is a new TOC file editor which makes editing TOC
files very fast. File/New/User Assistance/Help Table of Contents will
create a new TOC and open the editor.
If you have a relatively small amount of documentation then any tool
that can edit HTML can work. If you have a lot of documentation to write
and you have dedicated tech writers you may want to consider a more
specialized tool such as DITA. I haven't used DITA much myself but I
know of tech writers who seem to like it.
Re: General help documentation development question [message #609399 is a reply to message #472302] |
Pete Ellis wrote:
> Hello all,
> Many thanks,
> -Pete
Re: General help documentation development question [message #611100 is a reply to message #472308] |
Wed, 02 April 2008 06:38  |
Currently we try to convert our documentation in DocBook as well, cause we
like the possibility to generate easily any format we want to, especially
the eclipse help files. We already tested it, and it really worked fine.
Unfortunatly its not as easy to convert our current documentation (written
with tradtional word processors) to DocBook, as it is to convert from
Are there any effective alternatives to DocBook to get the Eclipse Help
System files out of a traditional word processor?
Thanks in advance,
Marcus
Re: General help documentation development question [message #611102 is a reply to message #472426] |
Hi Marcus,
Eclipse help files.
Lee Anne
> Hello,
> worked fine.
> Thanks in advance,
> Marcus
Re: General help documentation development question [message #611104 is a reply to message #472429] |
Hi Lee Anne,
Sincerely,
Marcus
Lee Anne wrote:
> Hi Marcus,
> Eclipse help files.
> Best regards,
> Lee Anne
Re: General help documentation development question [message #611123 is a reply to message #472431] |
Hi Marcus,
and Word and DITA:
DTD/schema, etc)
Hope this helps!
Lee Anne
> Hi Lee Anne,
> Sincerely,
> Marcus
> Lee Anne wrote:
>> Hi Marcus,
>> Best regards,
>> Lee Anne
Current Time: Fri Jun 13 13:00:15 EDT 2025
Powered by FUDForum. Page generated in 0.07784 seconds
