Re: Use Case Diagrams in M4? [message #472265 is a reply to message #472263] |
Tue, 15 January 2008 12:52 |
Tatiana Fesenko Messages: 530 Registered: July 2009 |
Hello Sam,
Welcome to UML2Tools newsgroup.
Yes, UseCase diagram editor is a part of UML2Tools now.
It would be helpfull to get familiar with GMF. Moreover, we have our little
wiki page - http://wiki.eclipse.org/MDT-UML2Tools. There is some usefull
infomation on it.
To realize which elements are already supported and how do they look like
in UML2Tools I recommend to look through diagram examples. They are figures
from UML 2 specification made with UML2Tools. You can check them out from
our CVS:
cvs -d pserver:dev.eclipse.org:/cvsroot/modeling co org.eclipse.mdt/org.eclipse.uml2tools/examples/
'org.eclipse.uml2.diagram.examples.clazz' project, 'diagram/07-02-03/16 Use
Cases' folder
God luck,
Tatiana.
> Good day,
> I'm new to EMF, GEF, GMF and UMLTools. I'm a university student doing
> my
> honours project which involves in part the visualization of a domain
> model and use case model read from a custom XML file (perhaps even a
> standard XMI file). Have use case diagrams actually been implemented
> in M4 (bug #199725)? If so, what would I need to get started. I've
> manually installed UMLTools 0.8.0 and all its dependencies listed on
> http://www.eclipse.org/modeling/mdt/downloads/?project=uml2t ools
> There seems to be lot to learn. Any recommendations on where to start
> and how to proceed? I plan to go through the four part GMF tutorial
> (http://wiki.eclipse.org/index.php/GMF_Tutorial).
> Thank you.
> Regards,
> Sam Sabra
Re: Use Case Diagrams in M4? [message #472344 is a reply to message #472265] |
Wed, 16 January 2008 07:09 |
Sam Sabra Messages: 10 Registered: July 2009 |
Thank you Tatiana, I will look into the wiki and examples.
Kind Regards,
Sam
Tatiana Fesenko wrote:
> Hello Sam,
> little wiki page - http://wiki.eclipse.org/MDT-UML2Tools. There is some
> usefull infomation on it.
> like in UML2Tools I recommend to look through diagram examples. They are
> figures from UML 2 specification made with UML2Tools. You can check them
> out from our CVS: cvs -d pserver:dev.eclipse.org:/cvsroot/modeling co
> Use Cases' folder
> God luck,
> Tatiana.
>> Good day,
>> my
>> Thank you.
>> Regards,
>> Sam Sabra
Re: Use Case Diagrams in M4? [message #615764 is a reply to message #472263] |
Hello Sam,
wiki page - http://wiki.eclipse.org/MDT-UML2Tools There is some usefull
infomation on it.
our CVS:
Cases' folder
God luck,
Tatiana.
> Good day,
> my
> Thank you.
> Regards,
> Sam Sabra
Re: Use Case Diagrams in M4? [message #615778 is a reply to message #472265] |
Kind Regards,
Sam
> Hello Sam,
> little wiki page - http://wiki.eclipse.org/MDT-UML2Tools There is some
> Use Cases' folder
> God luck,
> Tatiana.
>> Good day,
>> my
>> Thank you.
>> Regards,
>> Sam Sabra
FUDForum. Page generated in 0.03774 seconds
