Home » Modeling » UML2 Tools » n-ary associations, association classes
Re: n-ary associations, association classes [message #472253 is a reply to message #472187] |
Fri, 11 January 2008 13:23 |
Michael Golubev Messages: 383 Registered: July 2009 |
Hello Felix,
Hope you have found a way to create association classes in M4 :).
We are actually supporting binary associations only, it is possible to model
N-ary associations with corresponding (empty) association class only.
We can probably add support for them in the same sense as for generalization
sets.
That is, when user initially connects 2 classifiers with association tool,
the default "line" notation is used for binary case (as it is done now),
but drawing the connection with the same tool from 3rd classifier to existing
association replaces it with rhomb-no-class n-ary notation. If you feel it
is what you need, please submit bugzilla for this.
Michael
> I _think_ I managed to create an eclipse 3.4 setup that includes the
> latest eclipse 3.4 builds from any of the depending projects. At least
> I get no suspect errors.
> Did you manage to create an association class diagramatically
> with the rc3 release? I can create the class, but don't figure how to
> connect it to an association. I did not yet try to init a diagram from
> a model file.
> I also do not figure how to create n-ary associations that are
> connected through the standard rhombus notation. How did you do it?
> Felix
>> Felix,
>> According to the schedule, M4 stable build is due on Wed this week.
>> Although this date is suspect due to the very low volume of CVS
>> commits in the past few weeks...
>> Also, I have successfully used a build from the latest CVS head
>> installed in Eclipse 3.3. So you may not need a 3.4 platform to use
>> the diagrams.
Re: n-ary associations, association classes [message #615752 is a reply to message #472187] |
Hello Felix,
sets.
Michael
> a model file.
> Felix
>> Felix,
>> the diagrams.
Current Time: Fri Apr 19 16:09:26 GMT 2024
Powered by FUDForum. Page generated in 0.02089 seconds
