Re: Generate models from existing source [message #472164 is a reply to message #472158] |
Fri, 21 December 2007 13:05 |
Ed Merks Messages: 33137 Registered: July 2009 |
--------------030505020403080409000507
Andreas,
I don't think the tools support this. I don't recall if the GMT project
has any reverse engineering tools like what you want. EMF does
something similar but that requires you annotate the source code (with
@model annotations in the Javadoc) to indicate which things are part of
the model and how methods in the Java code correspond to operations
verses features in the model:
< http://help.eclipse.org/help33/topic/org.eclipse.emf.doc/tut orials/clibmod/clibmod.html#step1b>
From an Ecore model, it's possible to export it to a UML model; it's
also possible, with the Ecore tools component of EMFT, to create a
UML-style class diagram directly for the Ecore model.
Andreas wrote:
> Hi. I've been trying out uml2 tools for a couple of hours now trying
> to find a way to generate class diagrams from my existing source (a
> java project). I cant find a way to do it yet.
> Anyone using uml2 tools for this purpose and can point me in the right
> direction to accomplish this or does the tool not support this?
> Thanks
> /Andreas
<html>
<head>
http-equiv="Content-Type">
</head>
Andreas,<br>
<br>
Ed Merks
Re: Generate models from existing source [message #614529 is a reply to message #472158] |
Andreas,
> Thanks
> /Andreas
<html>
<head>
</head>
Andreas,<br>
<br>
Ed Merks
FUDForum. Page generated in 0.02869 seconds
