Home » Modeling » UML2 Tools » Installing UML2 Tools
Re: Installing UML2 Tools [message #472174 is a reply to message #472143] |
Mon, 31 December 2007 23:41 |
Originally posted by: ayman_java.yahoo.com
Iam trying to install UMLTools over windows with eclipse Version: 3.3.1.1.
I tried first to download all dependencies it doesn't work, I tried
install manager, it also didn't work. I can see the org.eclipse.uml2tools
in the feature details, seems nothing wrong. but I can't see New/Other/UML
2.1 Diagrams in the new project, any help?!!
Re: Installing UML2 Tools [message #472711 is a reply to message #472176] |
Fri, 25 January 2008 13:18 |
Originally posted by: regnstrom.flowtech.se
Tatiana Fesenko wrote:
> Hello ayman,
> Do you mean you succesfully installed all the required plugins and after
> that you cannot find 'New/Other/UML 2.1 Diagrams' menu item?
> Do you have anything in your Error Log? If yes, please send us its content.
> Probably it will help us to solve the problem.
Hello Tatiana,
The above exactly describes my problem. The file .metadata/.log shows
nothing, are there any other log files? Does uml2tools require Java5?
Bjorn
Re: Installing UML2 Tools [message #472714 is a reply to message #472711] |
Fri, 25 January 2008 14:56 |
Ed Merks Messages: 33140 Registered: July 2009 |
Bjorn,
Yes because EMF requires Java 5.0. It's quite useful to clear the error
log (either the view or remove <workspace>/.metadata/.log) run Eclipse
with -clean -debug, and look closely at the logged messages. If plugins
are disabled, it will explain what dependencies are missing, or if Java
5.0 is needed but isn't available, it will give messages about that.
>> Hello ayman,
>> after that you cannot find 'New/Other/UML 2.1 Diagrams' menu item? Do
>> content. Probably it will help us to solve the problem.
> Hello Tatiana,
> Best regards,
> Bjorn
Ed Merks
Re: Installing UML2 Tools [message #614539 is a reply to message #472143] |
Re: Installing UML2 Tools [message #617567 is a reply to message #472176] |
> Hello ayman,
Hello Tatiana,
Bjorn
Re: Installing UML2 Tools [message #617571 is a reply to message #472711] |
Bjorn,
>> Hello ayman,
> Hello Tatiana,
> Best regards,
> Bjorn
Ed Merks
Current Time: Thu Apr 25 00:13:28 GMT 2024
Powered by FUDForum. Page generated in 0.05534 seconds
