org.eclipse.emf.query (1.0.1) - where is it? [message #472134] |
Tue, 18 December 2007 19:51 |
Gary Messages: 10 Registered: July 2009 |
All:
I have been trying to install the UML2 Tools Component. I have been
painfully searching for and downloading the necessary plugins, with their
necessary prerequisites, according to the installation instructions found
at: http://wiki.eclipse.org/MDT-UML2Tools, (topic: "How can I start with
UML2Tools?"). I have been using the Eclipse download manager to complete
these tasks.
I have gotten to the point where each time I use the update manager and
select the "MDT UMLTOOLS SDK (Incubation) 0.7.1", I keep getting this
error message when I select certain features to install:
" UML2 Diagramming (Incubation) (0.7.1.v200710010534) requires feature
"org.eclipse.emf.query (1.0.1)", or compatible."
I'm thinking that because I have yet to include this plugin in my eclipse
environment I do not see the " 'org.eclipse.uml2tools' " in my Feature
Details when I click on Help/About Eclipse SDK, again as per the
instructions found on the same web page.
Now, I don't know if this makes any difference or not, but I do see a
org.eclipse.emf.query_1.1.0.v200706071712.jar in my \eclipse\plugins
directory.
Anyway, can anybody assist? Does anybody know where on the Eclipse site I
can find this exact feature and version that the update manager keeps
telling me I need in order to successfully install and use the UML2 Tools
Component?
Thx to all for your response and happy holidays.
Gary
Re: org.eclipse.emf.query (1.0.1) - where is it? [message #472137 is a reply to message #472134] |
Tue, 18 December 2007 21:43 |
Dave Carlson Messages: 402 Registered: July 2009 |
Gary,
The easiest (and much less painful) way to use update manager is to just
click the Select Required button. However, for that to work, you must
expand the top-level category containing the dependencies. So, if
installing in a 3.3 workbench, select UML2Tools, expand Europa category,
then click Select Required. Should get everything you need that is not
already in your config.
For the update manager to work, the *features* are needed in your workbench
config, not only the plugins. So even if you have the query plugin (as you
indicated), also check that you have the query feature present. But "Select
Required" should get it if not already installed.
Hope this helps,
Dave Carlson
> directory.
> Component?
> Gary
Re: org.eclipse.emf.query (1.0.1) - where is it? [message #611649 is a reply to message #472134] |
Gary,
Hope this helps,
Dave Carlson
> directory.
> Component?
> Gary
FUDForum. Page generated in 0.02768 seconds
