Re: Problem with Help system in Eclipse 3.3.1.1 [message #471460] |
Sun, 20 January 2008 00:06  |
Originally posted by: nospam_kowalskilee.gmail.com
Anand Narasimhan wrote:
> I am seeing a strange problem in the help system in 3.3.1.1. In our RCP
> application, we have online help. If I click on a topic in the contents
> window, the help for the wrong topic is shown. For example if I have the
> following topics
> Main Topic
> - Sub Topic 1
> - Sub Topic 2
> - Sub Topic 3
> - Sub Topic 4
> If I click on Sub Topic 1, I see a document with just a title that says
> "What's New"
> If I click on Sub Topic 3, I see the contents for Sub Topic 1
> If I click on Sub Topic 4, I see the contents for Sub Topic 2
> and so on.
> The same help plug-ins seems to work fine in 3.2 and 3.4.
> Is there a bug in 3.3 in the help system that would cause this problem?
> Thanks
> Anand
I'm adding the eclipse.platform.ua newsgroup to this thread, as that
newsgroup covers the help system.
Anand, can you provide here the portion of your toc.xml file that has
the contents that is related to the "Main Topic" and "Sub Topics" that
are showing this behavior?
I'm not aware of any bug in 3.3 that would cause this particular
problem. Do you have a document with a title that is "What's New"? Did
the toc.xml file get changed somehow without shutting down and
restarting the application? Are you starting up with the the osgi
parameter -clean to refresh the Eclipse configuration state between
startups/shutdowns?
--Lee Anne
Re: Problem with Help system in Eclipse 3.3.1.1 [message #471462 is a reply to message #471460] |
Sun, 20 January 2008 13:53   |
Hi Lee Anne,
Thanks for the reply. The documentation plugins are written by another
team. I am trying to debug for them. I am still trying to understand the
problem myself.
Here is the information you wanted.
There are two plugins where the contents are distributed. The base
plugins defines primary TOC like this.
<?xml version="1.0"?>
<plugin
name = "%pluginName"
id = "com.cisco.nm.cmp.client.doc.base"
version = "1.0.0"
provider-name="%providerName">
<!-- Define the main book -->
<extension point="org.eclipse.help.toc">
<toc file="book.xml" primary="true" />
</extension>
<!-- Link the sections into the book -->
<toc file="book-isdk.xml" />
<toc file="book-vsdk.xml" />
</extension>
</plugin>
The book.xml has the following:
<toc label="Cisco Active Network Abstraction (ANA) Help" topic="book.html">
<!-- What's New -->
<topic label="What's New">
<anchor id="Base-new" />
<anchor id="anchor-new" />
</topic>
<!-- Overview -->
<topic label="Overview">
<anchor id="Base-over" />
<anchor id="anchor-over" />
</topic>
<!-- Getting Started -->
<topic label="Getting Started">
<anchor id="Base-getstart" />
<anchor id="anchor-getstart" />
</topic>
<!-- Device and Network Management -->
<topic label="Device and Network Management">
<anchor id="Base-devmgmt" />
<anchor id="anchor-devmgmt" />
</topic>
<!-- Configuration Management -->
<topic label="Configuration Management">
<anchor id="Base-config" />
<anchor id="anchor-config" />
</topic>
</toc>
They don't have the "What's new" and "Getting Started" contents yet.
According to the documentation team, if a topic listed in the book.xml
is not installed, eclipse 3.2 or 3.4, would ignore those, but in 3.3 it
seems work differently.
In this case, since "What's new" is not installed, clicking on
"Overview" seems to be looking for "What's New" topic.
Anand
>> Hi,
>> RCP application, we have online help. If I click on a topic in the
>> contents window, the help for the wrong topic is shown. For example if
>> I have the following topics
>> Main Topic
>> - Sub Topic 1
>> - Sub Topic 2
>> - Sub Topic 3
>> - Sub Topic 4
>> says "What's New"
>> and so on.
>> Thanks
>> Anand
> startups/shutdowns?
> --Lee Anne
____________________________________________________________ _____________________
Anand Narasimhan
anandn@cisco.com
Re: Problem with Help system in Eclipse 3.3.1.1 [message #471530 is a reply to message #471529] |
Mon, 21 January 2008 22:12  |
The problem seems to be in TocFragmentServlet.Serializer class.
In serializeChildTopics the href is being constructed using the index of
the child topic in the topics array.
In 3.3 the child topics returned is only the enabled topics (ITopic[]
subtopics = EnabledTopicUtils.getEnabled(topic.getSubtopics());)
So this already returns the only the enabled topic, so the child topic
index is wrong.
In 3.4, child topics are obtained using topic.getSubTopics and in the
loop, if a child topic is not enabled, it is skipped. so the index in
addSuffix method is correct.
This is a critical problem for us. We cannot migrate to 3.4 yet. Is
there a way to get a patch fix for this problem?
Anand
> Filed a bug agains UA. Bug ID: 216064
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=216064
> Anand
> Chris Goldthorpe wrote:
>> In that case can you file a bug report and attach a plugin which shows
>> the problem?
Anand Narasimhan
anandn@cisco.com
Re: Problem with Help system in Eclipse 3.3.1.1 [message #606955 is a reply to message #471460] |
Hi Lee Anne,
problem myself.
<plugin
version = "1.0.0"
</extension>
</extension>
</plugin>
<!-- What's New -->
</topic>
<!-- Overview -->
</topic>
</topic>
</topic>
</topic>
</toc>
Anand
>> Hi,
>> Main Topic
>> - Sub Topic 1
>> - Sub Topic 2
>> - Sub Topic 3
>> - Sub Topic 4
>> says "What's New"
>> and so on.
>> Thanks
>> Anand
> startups/shutdowns?
> --Lee Anne
Anand Narasimhan
anandn@cisco.com
Re: Problem with Help system in Eclipse 3.3.1.1 [message #607657 is a reply to message #471522] |
Mon, 21 January 2008 15:20  |
Chris,
Thanks. The reply. The description of the bug seems to be like the
problem I am having. Is 3.3.1.1 a maintenance stream. The bug talks
about being fixed in a 3.3 maintenance stream (just like you said) and
also in 3.3.2.
I am using 3.3.1.1
Anand
> This might be the same problem as was described in Bug 205189. If you
> can download the latest 3.3 maintenance build you will be able to see if
> it is fixed.
Anand Narasimhan
anandn@cisco.com
Re: Problem with Help system in Eclipse 3.3.1.1 [message #607659 is a reply to message #471525] |
Mon, 21 January 2008 15:43  |
I applied the patch mentioned in this bug to the 3.3.1.1 source. It did
not fix the problem.
BTW: Can I attach screen shots to this posting, so it is easy to see the
problem I am seeing.
Anand
> Chris,
> also in 3.3.2.
> I am using 3.3.1.1
> Thanks
> Anand
>> if it is fixed.
Anand Narasimhan
anandn@cisco.com
Re: Problem with Help system in Eclipse 3.3.1.1 [message #607660 is a reply to message #471526] |
Mon, 21 January 2008 15:53  |
One more thing. I tried to run it thru debugger.
The call ITopic[] subtopics = topic.getSubtopics(); in NavServlet is
returning an empty array, so the the loop that contains the patched code
is not even executed.
Anand
> Thanks
> Anand
>> Chris,
>> also in 3.3.2.
>> I am using 3.3.1.1
>> Thanks
>> Anand
>>> if it is fixed.
Anand Narasimhan
anandn@cisco.com
Re: Problem with Help system in Eclipse 3.3.1.1 [message #607667 is a reply to message #471529] |
index is wrong.
Anand
> Anand
>> the problem?
Anand Narasimhan
anandn@cisco.com
FUDForum. Page generated in 0.49138 seconds
