Home » Eclipse Projects » Platform - User Assistance (UA) » Help Viewer Error
Help Viewer Error [message #470850] Thu, 08 November 2007 06:59 Go to next message
Originally posted by: wojtekmichalik.softtellco.com.pl
Help -> Help Contents
Opens browser window with title "Problems Viewing Page"
with contents:
Unable to connect
Firefox can't establish a connection to the server at 127.0.0.1:59233.
* The site could be temporarily unavailable or too busy. Try again
in a few moments.
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy,
make sure that Firefox is permitted to access the Web.
There are no problems viewing the same help from another user account.
I use eclipse Eclipse Platform
Version: 3.3.1.1
Build id: M20071023-1652
Linux with gtk.
It was installed in /usr/local/eclipse directory
This error does not appear when I set install directory access rights as
drwxrwxrwx
when directory access rights are drwxr-xr-x following exeption appears
ENTRY org.eclipse.help.base 4 0 2007-11-04 10:56:35.881
!MESSAGE An error occured while starting the help server
!STACK 0
java.lang.IllegalArgumentException: Bad temp directory: /usr/local/
eclipse/configuration/org.eclipse.osgi/bundles/600/data/jett ywork/
pid_2070971114
at org.mortbay.http.HttpContext.setTempDirectory
(HttpContext.java:975)
at
org.eclipse.equinox.http.jetty.internal.HttpServerManager.cr eateHttpContext
(HttpServerManager.java:247)
at
org.eclipse.equinox.http.jetty.internal.HttpServerManager.up dated
(HttpServerManager.java:103)
at org.eclipse.equinox.http.jetty.internal.Activator.startServe r
(Activator.java:208)
at org.eclipse.equinox.http.jetty.JettyConfigurator.startServer
(JettyConfigurator.java:60)
at org.eclipse.help.internal.server.WebappManager.start
(WebappManager.java:43)
at
org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning
(BaseHelpSystem.java:187)
at org.eclipse.help.internal.base.HelpDisplay.displayHelpURL
(HelpDisplay.java:152)
(HelpDisplay.java:42)
at org.eclipse.help.ui.internal.DefaultHelpUI.displayHelp
(DefaultHelpUI.java:125)
at org.eclipse.ui.internal.help.WorkbenchHelpSystem.displayHelp
(WorkbenchHelpSystem.java:833)
at org.eclipse.ui.internal.actions.HelpContentsAction$1.run
(HelpContentsAction.java:83)
at org.eclipse.swt.custom.BusyIndicator.showWhile
(BusyIndicator.java:67)
at org.eclipse.ui.internal.actions.HelpContentsAction.run
(HelpContentsAction.java:81)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection
(ActionContributionItem.java:546)
at org.eclipse.jface.action.ActionContributionItem.access$2
(ActionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t
(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent
(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents
(Display.java:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch
(Display.java:2971)
at org.eclipse.ui.internal.Workbench.runEventLoop
(Workbench.java:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at org.eclipse.core.databinding.observable.Realm.runWithDefault
(Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
(Workbench.java:461)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench
(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start
(IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run
(EclipseAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication
(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start
(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run
(EclipseStarter.java:363)
(EclipseStarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework
(Main.java:508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Re: Help Viewer Error [message #470851 is a reply to message #470850] Thu, 08 November 2007 11:55 Go to previous messageGo to next message
This looks like an error because Eclipse is unable to write to the
configuration area. Eclipse needs writable areas for its configuration
as well as for the workspace.
Try launching eclipse with a -configuration parameter set to a writable
directory and see if it makes a difference. Inability to write to the
configuration can have more bad side effects so it's important that it
points to a writable area.
See
http://help.eclipse.org/help33/topic/org.eclipse.platform.do c.user/tasks/running_eclipse.htm
Re: Help Viewer Error [message #470852 is a reply to message #470851] Thu, 08 November 2007 13:49 Go to previous message
> See
Everything works ok without -configuration parameter.
The problem was caused by changes in plugin directory access rights
part of files was owned by normal user - part by root.
After changing ownership of all files in install dir to root
and setting access rights to rwxr-xr-x everything works fine
Wojtek
Re: Help Viewer Error [message #593674 is a reply to message #470850] Thu, 08 November 2007 11:55 Go to previous message
See
Re: Help Viewer Error [message #593688 is a reply to message #470851] Thu, 08 November 2007 13:49 Go to previous message
> See
Wojtek
Previous Topic:Re: Help Viewer Error
Next Topic:Eclipse IDE Help Documentation
Current Time: Tue Jun 24 18:02:21 EDT 2025
Powered by FUDForum. Page generated in 0.27011 seconds
