Home » Eclipse Projects » EPF » WAR - Search - Weblogic 10
WAR - Search - Weblogic 10 [message #47710] Mon, 04 February 2008 07:21 Go to next message
danny foncke is currently offline danny fonckeFriend
Member
hi,
Search fails on Weblogic 10.
When you click the search button, nothing happens
No messages, no logs, nothing
all help appreciated
Danny
Re: WAR - Search - Weblogic 10 [message #47743 is a reply to message #47710] Mon, 04 February 2008 09:56 Go to previous messageGo to next message
Member
Same error as in previous posting
-> indexpath = null
questions : why ?
trace:
LD> searchString: doormat
convert doormat -> doormat
LD> _indexPath: null
LD> _currentSearchString: doormat
LD> unicodes: doormat
LD> analyzerName: null
LD> _hits: null
at
org.eclipse.epf.web.servlet.SearchServlet.runQuery(SearchSer vlet.java
:206)
danny wrote:
> hi,
> Danny
Re: WAR - Search - Weblogic 10 [message #48031 is a reply to message #47710] Wed, 13 February 2008 14:10 Go to previous messageGo to next message
Member
problem solved
getrealpath(..) is the cause
danny wrote:
> hi,
> Danny
Re: WAR - Search - Weblogic 10 [message #48061 is a reply to message #48031] Wed, 13 February 2008 21:00 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
more details please :)
If you did change EPF code, we would appreciate you creating bugzilla and
then attaching a patch so that we can send it across in next release to
rest of EPF community.
Thanks in advance.
Shilpa
Re: WAR - Search - Weblogic 10 [message #48089 is a reply to message #48061] Thu, 14 February 2008 06:54 Go to previous message
Member
no changes to EPF code
some investigation lead to the following line (in searchServlet) being
the cause :
_indexPath =
config.getServletContext().getRealPath(config.getInitParamet er( "searchIndex"));
some further investigation learned that getRealPath(...) doesn't work
well when the war is deployed as an archive (not exploded)
-> in WebLogic 10 there is a flag :
"Archived Real Path enabled" which you need to set to get
'getRealPath()' working correctly
-> problem solved :)
(I have no clue why that flag isn't set by default - which is a bit
worrying now)
> and then attaching a patch so that we can send it across in next release
> to rest of EPF community.
> Thanks in advance.
> Regards,
> Shilpa
Re: WAR - Search - Weblogic 10 [message #588352 is a reply to message #47710] Mon, 04 February 2008 09:56 Go to previous message
Member
-> indexpath = null
questions : why ?
trace:
LD> _hits: null
at
:206)
danny wrote:
> hi,
> Danny
Re: WAR - Search - Weblogic 10 [message #588440 is a reply to message #47710] Wed, 13 February 2008 14:10 Go to previous message
Member
problem solved
danny wrote:
> hi,
> Danny
Re: WAR - Search - Weblogic 10 [message #588449 is a reply to message #48031] Wed, 13 February 2008 21:00 Go to previous message
Shilpa Toraskar is currently offline Shilpa ToraskarFriend
Thanks in advance.
Shilpa
Re: WAR - Search - Weblogic 10 [message #588450 is a reply to message #48061] Thu, 14 February 2008 06:54 Go to previous message
Member
the cause :
_indexPath =
worrying now)
> Thanks in advance.
> Regards,
> Shilpa
Previous Topic:searchservlet source code
Next Topic:H2 Automatically Generate Feedback with contextual mailto ?
Current Time: Wed Jan 27 01:53:52 GMT 2021
Powered by FUDForum. Page generated in 0.01882 seconds
