Home » Archived » AMW » [AMW] Status for Galileo
[AMW] Status for Galileo [message #470335] Sun, 19 July 2009 00:56 Go to next message
Ioan Salau is currently offline Ioan SalauFriend
Member
I would like to play around with AMW plugin but the latest version I
could find for download is dated back in 2007. Is there any new versions,
I am interested specially to have a version for Eclipse Galileo. If there
is no version for Galileo, does AMW team have any plan for to release AMW
for Galileo?
Re: [AMW] Status for Galileo [message #470337 is a reply to message #470335] Mon, 20 July 2009 21:39 Go to previous messageGo to next message
Marcos Didonet Del Fabro is currently offline Marcos Didonet Del FabroFriend
Member
the latest binary release is compatible with Eclipse 3.3. In order to have
the lastest version, it is necessary to check out the sources from SVN.
Marcos.
Re: [AMW] Status for Galileo [message #478928 is a reply to message #470335] Fri, 07 August 2009 14:28 Go to previous message
Member
I have recently committed a new version that corrects some dependency
problems with ATL and AM3 (I replace two problematic static references
with dynamic class loading).
I have tested with the following versions:
Eclipse 3.4.2
ATL 2_1_0_dev :
http://wiki.eclipse.org/ATL/How_Install_ATL_(Dev)_From_CVS
AM3 dev : http://wiki.eclipse.org/AM3/How_Install_AM3_From_SVN
Marcos.
Previous Topic:Problem in Transfromation
Next Topic:Using AMW
Current Time: Mon Jan 25 00:25:59 GMT 2021
Powered by FUDForum. Page generated in 0.02320 seconds
