Home » Archived » AMW » Problem in Hot generation
Problem in Hot generation [message #470304] Wed, 01 July 2009 07:09 Go to next message
venkatesh  is currently offline venkatesh Friend
Member
Hi marcos,
I want to do transformation from ecore to ecore.
when i generate Hot transformation i'm getting my ATL file like this
module T_In2Out;
create PdmModelModel : PdmModel from LdmMetaModelModel : LdmMetaModel;
rule LDMModel_2_PDMModel2 {
from
v_left : LdmMetaModel!LDMModel
to
v_right : LdmMetaModel!PDMModel (
coreModel <- v_left.coreModel
but i'm expected rule is
from
to
v_right : PdmMetaModel!PDMModel (
can u tell me in the v.right element why i'm getting
instead of PdmMetaModel!PDMModel.
thanks
venky.
Re: Problem in Hot generation [message #470307 is a reply to message #470304] Wed, 01 July 2009 20:50 Go to previous message
Marcos Didonet Del Fabro is currently offline Marcos Didonet Del FabroFriend
Member
it is a problem related with the identification of the model elements. The
rule is not recognizing the good metamodel.
This may occurs if you do some modifications in the metamodel in parallel:
the weaving model will have the wrong IDs. A second possibility may be
conflicting URIs/paths between the metamodels.
Marcos.
Previous Topic:Any Build for Galileo?
Next Topic:[AMW] weaving "n" metamodels and ATL transformation
Current Time: Mon Aug 10 17:21:20 GMT 2020
Powered by FUDForum. Page generated in 0.02122 seconds
