Home » Eclipse Projects » Platform - User Assistance (UA) » First time help loads..
First time help loads.. [message #470165] Fri, 26 October 2007 07:29 Go to next message
The first time the help is loaded it takes an fairly long time to load and
typically it does not go to the correct section of the document when
initiating displyaHelp (aContextId). All access after the first access is
fine, but the first one is slow and inaccurate. Is there something I can do
to preload the help (I assume it is building indices or caching the images
from the html pages) during startup so that the first access is correct?
Re: First time help loads.. [message #470579 is a reply to message #470165] Thu, 01 November 2007 11:12 Go to previous messageGo to next message
Originally posted by: nospam_kowalskilee.gmail.com
Hi Drew,
Would you please provide some more information about the situational
context in which you are seeing the slow loading?
I mean the exact steps you take up to where the help is taking a long
time to load. Are you in the IDE Workbench and then clicking
Help->Contents for the separate help window? Or are you pressing F1 to
get the help view?
By 'first access', do you mean loading within the help view, that's
usually on the right hand side of the Workbench itself?
Lee Anne
Re: First time help loads.. [message #470582 is a reply to message #470579] Thu, 01 November 2007 14:31 Go to previous message
RCP application call to :
IWorkbenchHelpSystem theHelp = PlatformUI.getWorkbench().getHelpSystem();
theHelp.displayHelp(sAnyContextId);
By first access I mean the first time the help UI is launched by the user in
the RCP app.
"Lee Anne" <nospam_kowalskilee@gmail.com> wrote in message
news:fgcqb9$id0$2@build.eclipse.org...
> Hi Drew,
> I mean the exact steps you take up to where the help is taking a long time
> to load. Are you in the IDE Workbench and then clicking Help->Contents for
> the separate help window? Or are you pressing F1 to get the help view?
> Lee Anne
>> and typically it does not go to the correct section of the document when
>> do to preload the help (I assume it is building indices or caching the
>> images from the html pages) during startup so that the first access is
>> correct?
Re: First time help loads.. [message #592767 is a reply to message #470165] Thu, 01 November 2007 11:12 Go to previous message
Hi Drew,
get the help view?
Lee Anne
Re: First time help loads.. [message #592806 is a reply to message #470579] Thu, 01 November 2007 14:31 Go to previous message
the RCP app.
> Hi Drew,
> Lee Anne
>> correct?
Previous Topic:Re: How to Show the standalone Help at a specific contextid topic.
Next Topic:Questions about context help
Current Time: Thu Jun 19 22:21:32 EDT 2025
Powered by FUDForum. Page generated in 0.04721 seconds
