Home » Eclipse Projects » Platform - User Assistance (UA) » RCP application with remote help content only - can it avoid including jetty/jasper ?
RCP application with remote help content only - can it avoid including jetty/jasper ? [message #470144] Fri, 19 October 2007 06:09 Go to next message
Is it possible to avoid including jetty/jasper/servlet etc plugins in my
3.3-based RCP app
but still have a Help system for it - where all the content is obtained
from a remote infocenter?
All the resources I found show that including org.eclipse.help.base
will then require also the webserver/jsp compiler etc to be included as
well.
Edoardo
Re: RCP application with remote help content only - can it avoid including jetty/jasper ? [message #470148 is a reply to message #470144] Fri, 19 October 2007 11:53 Go to previous message
You will still need jetty/jasper, they are used to host the jsp files
which create the frames and manage the trees.
Re: RCP application with remote help content only - can it avoid including jetty/jasper ? [message #588990 is a reply to message #470144] Fri, 19 October 2007 11:53 Go to previous message
Previous Topic:Disable cheat sheet in dialog tray?
Next Topic:Problem with helpData.xml in Infocenter
Current Time: Sun Jun 22 17:45:35 EDT 2025
Powered by FUDForum. Page generated in 0.03435 seconds
