Home » Modeling » UML2 » UML2 installation question
UML2 installation question [message #470066] Mon, 05 February 2007 20:29 Go to next message
Originally posted by: swt.stanford.edu
Forgive me if this is a newbie question that has been answered elsewhere.
I am trying to import an Enterprise Architect XMI file into Eclipse UML2
format. I've installed
Eclipse 3.2.1
EMF 2.2.0v200604200629
UML2 2.1.0v200701040816
According to
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Getti ng_Started_with_UML2/article.html,
I should be able to create a UML model through File>New>Others...
"Example EMF Model Creation Wizards> UML Model. HOwever, I don't see
"UML Model" as a choice under "Example EMF Model Creation Wizards"
In the File/New/Project wizard, I select EMF project, but I don't see
the UML importer, as michael.giroux@bull.com was able to do in a
separate thread (Creating EMF project from xmi file).
I'd appreciate any help. Thanks.
Samson Tu
Re: UML2 installation question [message #470072 is a reply to message #470066] Mon, 05 February 2007 21:10 Go to previous messageGo to next message
james bruck is currently offline james bruckFriend
Hi Samson,
Your configuration seems to be a bit off. UML2 2.1 requires EMF 2.3 and
Eclipse 3.3. Have a look at the build dependencies here ...
http://www.eclipse.org/modeling/mdt/downloads/index.php?proj ect=uml2&showAll=0&showMax=5
I think what you are looking for is ..
1. File>New>Other...>Eclipse Modeling Framework>EMF Model>Next..> then
from the list of model importers select "UML model".
Then select "Browse File System".
The extension types supported are *.uml, *.uml2, *.xmi.
- James.
"Samson Tu" <swt@stanford.edu> wrote in message
news:eq842p$jji$1@utils.eclipse.org...
> Eclipse 3.2.1
> According to
> Samson Tu
Import from Enterprise Architect (was Re: UML2 installation question) [message #470085 is a reply to message #470072] Mon, 05 February 2007 23:13 Go to previous messageGo to next message
Many thanks for the quick response. Yes, after installing the right
versions, I was able to access the UML2 plugin features.
However, importing an Enterprise Architect UML XMI file resulted in a
"String index out of range: -1" error. Does anyone know whether
Enterprise Architect UML 2.1/XMI 2.1 export (or any other EA export
versions) can be read into Eclipse UML2 plugin?
Thanks.
Samson
James Bruck wrote:
> Hi Samson,
> Regards,
> - James.
>> Hi,
>> Eclipse 3.2.1
>> According to
>> Samson Tu
Re: Import from Enterprise Architect (was Re: UML2 installation question) [message #470100 is a reply to message #470085] Tue, 06 February 2007 15:39 Go to previous messageGo to next message
Hi Samson,
Please raise a defect and that will be taken care of soon.
- James.
news:eq8dmi$91u$1@utils.eclipse.org...
> Thanks.
> Samson
> James Bruck wrote:
> > Hi Samson,
and
> > Regards,
> > - James.
> >> Hi,
elsewhere.
UML2
> >> Eclipse 3.2.1
> >> According to
> >> Samson Tu
Re: Import from Enterprise Architect (was Re: UML2 installation question) [message #470103 is a reply to message #470100] Tue, 06 February 2007 18:29 Go to previous messageGo to next message
Thanks, I've added an entry to the Eclipse Buszilla (Bug 173137). A
sample file for testing is available at
http://www.stanford.edu/~swt/EASample.xmi
Samson
James Bruck wrote:
> Hi Samson,
> Regards,
> - James.
>> Thanks.
>> Samson
>> James Bruck wrote:
>>> Hi Samson,
> and
>>> Regards,
>>> - James.
>>>> Hi,
> elsewhere.
> UML2
>>>> Eclipse 3.2.1
>>>> According to
>>>> Samson Tu
Re: Import from Enterprise Architect (was Re: UML2 installation question) [message #470105 is a reply to message #470103] Tue, 06 February 2007 21:34 Go to previous message
Kenn Hussey is currently offline Kenn HusseyFriend
Samson,
I took a look at your sample file, and I see several problems with it,
including the following:
1. There are a number of package import references to the UML metamodel
whose URIs do not specify a fragment, i.e. they look like
http://schema.omg.org/spec/UML/2.1/uml.xml when something like
http://schema.omg.org/spec/UML/2.1/uml.xml#_0 was expected. We can probably
address this in response to the bug report.
2. There are a number of references to metaclasses in the standard metamodel
whose URIs use the wrong case, e.g. they look like
http://schema.omg.org/spec/UML/2.1/uml.xml#association when
http://schema.omg.org/spec/UML/2.1/uml.xml#Association was expected. The
exporter you used should produce URIs in the expected format. Note that I
also noticed references to "associationEnd" and "attribute" metaclasses - no
such metaclasses exists in UML 2.x.
3. There are a number of XMI extension elements which in turn contain UML
elements with attributes that don't exist in UML - these can't be handled by
the parser unless they are also embedded in extension elements.
Kenn
news:eqahf3$1j7$1@utils.eclipse.org...
> Thanks, I've added an entry to the Eclipse Buszilla (Bug 173137). A sample
> file for testing is available at http://www.stanford.edu/~swt/EASample.xmi
> Samson
> James Bruck wrote:
>> Hi Samson,
>> Regards,
>> - James.
>>> Thanks.
>>> Samson
>>> James Bruck wrote:
>>>> Hi Samson,
>> and
>>>> then
>>>> Regards,
>>>> - James.
>>>>> Hi,
>> elsewhere.
>> UML2
>>>>> Eclipse 3.2.1
>>>>> According to
>>>>> Samson Tu
Re: UML2 installation question [message #582145 is a reply to message #470066] Mon, 05 February 2007 21:10 Go to previous message
Hi Samson,
- James.
> Eclipse 3.2.1
> According to
> Samson Tu
Import from Enterprise Architect (was Re: UML2 installation question) [message #582206 is a reply to message #470072] Mon, 05 February 2007 23:13 Go to previous message
Thanks.
Samson
James Bruck wrote:
> Hi Samson,
> Regards,
> - James.
>> Hi,
>> Eclipse 3.2.1
>> According to
>> Samson Tu
Re: Import from Enterprise Architect (was Re: UML2 installation question) [message #582311 is a reply to message #470085] Tue, 06 February 2007 15:39 Go to previous message
Hi Samson,
- James.
> Thanks.
> Samson
> James Bruck wrote:
> > Hi Samson,
and
> > Regards,
> > - James.
> >> Hi,
elsewhere.
UML2
> >> Eclipse 3.2.1
> >> According to
> >> Samson Tu
Re: Import from Enterprise Architect (was Re: UML2 installation question) [message #582326 is a reply to message #470100] Tue, 06 February 2007 18:29 Go to previous message
Samson
James Bruck wrote:
> Hi Samson,
> Regards,
> - James.
>> Thanks.
>> Samson
>> James Bruck wrote:
>>> Hi Samson,
> and
>>> Regards,
>>> - James.
>>>> Hi,
> elsewhere.
> UML2
>>>> Eclipse 3.2.1
>>>> According to
>>>> Samson Tu
Re: Import from Enterprise Architect (was Re: UML2 installation question) [message #582347 is a reply to message #470103] Tue, 06 February 2007 21:34 Go to previous message
Samson,
Kenn
> Samson
> James Bruck wrote:
>> Hi Samson,
>> Regards,
>> - James.
>>> Thanks.
>>> Samson
>>> James Bruck wrote:
>>>> Hi Samson,
>> and
>>>> then
>>>> Regards,
>>>> - James.
>>>>> Hi,
>> elsewhere.
>> UML2
>>>>> Eclipse 3.2.1
>>>>> According to
>>>>> Samson Tu
Previous Topic:Source Control File Merging
Next Topic:Re: [Announce] MDT UML2TOOLS 1.0.0M4 is available
Current Time: Sun May 16 18:29:56 GMT 2021
Powered by FUDForum. Page generated in 0.02447 seconds
