Re: Stereotype tagged values mapping [message #470174 is a reply to message #469869] |
Wed, 03 June 2009 20:42 |
Marcos Didonet Del Fabro Messages: 84 Registered: July 2009 |
Member |
For questions 1, 2 and 3:
Check the use case about Dually.
http://www.eclipse.org/gmt/amw/usecases/dually/ Dually is a nice extension
to AMW that enables the production of ATL transformation between a
metamodel (Acme) and a Stereotype (Darwin).
You can create an extension like this one, or reuse it directly if it is
adapted to your problem.
Once the weaving models are created, the tool executes a HOT that produces
an ATL transformation from profile to metamodel, and vice versa.
For 4:
Associations are relations between links. Typically, most part of weaving
models have only extensions to "Links". However, there may be cases where
creating associations are useful (complicated cases :) ). For instance, to
implement an adapted version of a matching algorithm (called Similarity
Flooding), it was necessary to create associations between links. These
associations stored a pre-calculated propagation value between links.
Marcos.
FUDForum. Page generated in 0.02810 seconds
