Home » Archived » AMW » How to create atl file from amw
How to create atl file from amw [message #469868] Wed, 03 June 2009 02:26 Go to next message
I am new to AMW.I wanted to create atl file to do xmi to xmi
transformation.
Basically i have x.ecore and y.ecore .
out put of x.ecore is x.xmi.so i want to transform x.xmi to y.xmi.
I have created a weaving wizard with has prop as
mmw_match.km3,mmw_propagation.km3,mmw_compare.km3,mw_base_ex tension.km3.
From this i am able to create a weaving model(.amw file).Now from this amw
file i want to generate an atl file .
I refer this link
http://www.eclipse.org/gmt/amw/examples/Scade/Scade_doc.php
in this the have mentioned the following
Generating and extracting the ATL transformation
The AMW plug-in contains a higher-order transformation (HOT) that
interprets the weaving model and that produces an ATL transformation. To
execute this transformation, open the context menu of the weaving panel
(the middle panel) and select the "Transform" submenu. Then click on
"Generate transformation (HOT)". This action produces an ATL model
(ScadeCmp_cp_equal_thres_lr_hot.ecore).
The output transformation model is extracted to an ATL file by clicking in
the context menu "Extract ATL-0.2 model to ATL-0.2 file
but i'm not able to find the transform submenu .weaving panel have only
option called "Save weaving metamodel in Ecore format".even i have tried
to save in ecore format but after that how to proceed to get an atl file.
can you please help me.
thanks in advance
venky
Re: How to create atl file from amw [message #469870 is a reply to message #469868] Wed, 03 June 2009 16:29 Go to previous messageGo to next message
This menu is available in the
org.eclipse.gmt.weaver.transformation.extension extension.
Do you have it installed?
Marcos.
Re: How to create atl file from amw [message #1038203 is a reply to message #469870] Wed, 10 April 2013 10:43 Go to previous messageGo to next message
I have the same problem but I have the org.eclipse.gmt.weaver.transformation.extension installed.
So how can I have the match and transform icons!
thank you,
Samar
Re: How to create atl file from amw [message #1042624 is a reply to message #469868] Tue, 16 April 2013 13:11 Go to previous message
The transformation menu is available only if have installed the plugins "org.eclipse.gmt.weaver.transformation" and "org.eclipse.gmt.weaver.transformation.extension".
Is that the case?
Marcos
Previous Topic:AMW installation
Next Topic:weaving model
Current Time: Tue Apr 22 13:34:56 EDT 2025
Powered by FUDForum. Page generated in 0.15409 seconds
