Re: Model-To-Text-Language (MTL) Implementation [message #47908 is a reply to message #47878] |
Thu, 17 July 2008 13:12 |
Jonathan MUSSET Messages: 43 Registered: July 2009 |
Member |
Of course, it will be a public version
Timothy Marc a écrit :
> Dear Jonathan,
> thank you for your answer. I think, i will have the time to wait for the
> build of the first version. Is that early version available for anyone, or
> just for project members?
> Thx
> --Timothy
> "Jonathan MUSSET" <jonathan.musset@obeo.fr> schrieb im Newsbeitrag
> news:487E0D1B.3060504@obeo.fr...
>> Hi,
>> We will build a first version in the next few weeks (august)
>> but you can try to checkout the following projects
>> " org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.engi ne "
>> " org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.ide. ui "
>> " org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.mode l "
>> " org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.pars er "
>> " org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.comm on "
>> " org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl-feat ure "
>> Host : dev.eclipse.org
>> Repository Path : /cvsroot/modeling
>> You need to install MDT OCL plugin
>> You have examples in "*.tests" projects
>> You can search "*.mtl" files
>> A Java File, and 2 ANT files are automatically created when you compile a
>> template that contains a "[file...]" block
>> You just have to rename the "*.sample" file (-> "generate.xml" for
>> example)
>> Put it in the target project and call it with "External Tools > Run As >
>> Ant Build"
>> You have to change the "MODEL" and the "TARGET" values
>> At the moment, you need to refresh the workspace at the end of the
>> generation
>> Regards,
>> Jonathan Musset
>>> Hi all,
>>> yesterday, i've read the MTL-Spec from the OMG, which seems to be a good
>>> try for a one-in-all solution for code generation. According to the
>>> roadmap of the M2T-Project and complete implementation of the spec will
>>> be published in June 2009. Is it possible to volunteer myself for testing
>>> an early alpha version of the project, when it is released? I'm very
>>> interesting in this implementation.
>>> Greetings
>>> Timothy
Re: Model-To-Text-Language (MTL) Implementation [message #48496 is a reply to message #47908] |
Mon, 11 August 2008 07:58 |
Member |
You can get the last build on the website (I200808081155) :
http://www.eclipse.org/modeling/m2t/downloads/?project=mtl
Jonathan
>> Dear Jonathan,
>> the build of the first version. Is that early version available for
>> anyone, or just for project members?
>> Thx
>> --Timothy
>>> Hi,
>>> compile a template that contains a "[file...]" block
>>> example)
>>> As > Ant Build"
>>> generation
>>> Regards,
>>> Jonathan Musset
>>>> Hi all,
>>>> good try for a one-in-all solution for code generation. According to
>>>> the roadmap of the M2T-Project and complete implementation of the
>>>> spec will be published in June 2009. Is it possible to volunteer
>>>> myself for testing an early alpha version of the project, when it is
>>>> released? I'm very interesting in this implementation.
>>>> Greetings
>>>> Timothy
FUDForum. Page generated in 0.02399 seconds
