Home » Modeling » UML2 » strange behavior when defining a profile
strange behavior when defining a profile [message #469706] Mon, 29 January 2007 07:21 Go to next message
Rafael Chaves is currently offline Rafael ChavesFriend
When I define the following profile named 'sample_profile':
<uml:Profile xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
xmi:id="_O3cisK9mEduaoJ8VsHbaPQ" name="sample_profile">
<packagedElement xmi:type="uml:Stereotype"
xmi:id="_P7ic8K9mEduaoJ8VsHbaPQ" name="sample_stereotype">
<ownedAttribute xmi:id="_Xjqr8K9mEduaoJ8VsHbaPQ" name="myProperty">
<type xmi:type="uml:PrimitiveType"
href="pathmap://UML_METAMODELS/UML.metamodel.uml#Integer"/>
</ownedAttribute>
</packagedElement>
</uml:Profile>
It results in a EPackage instance that describes the UML metamodel.
Also, if I try to apply this profile to any models I build, the model is
persisted in a way that stereotype applications are lost. The reason
seems to be that the XMI for such a model refers to stereotypes coming
from 'sample_profile' as if they were coming from 'uml':
<xmi:XMI xmi:version="2.1" (...)>
<uml:Model xmi:id="_2YHtEK9lEdu8D5FNufO7zw" name="sample_model">
</uml:Model>
<uml:sample_stereotype (...) />
</xmi:XMI>
Instead, I would expect the stereotype applications to appear as:
<sample_profile:sample_stereotype (...) />
The trigger to this problem seems to be that I am referring to a type
from the uml package (integer). If I remove the reference, the problem
goes away.
Am I doing anything wrong to cause this, or is this a bug?
Rafael
Re: strange behavior when defining a profile [message #469712 is a reply to message #469706] Mon, 29 January 2007 16:46 Go to previous messageGo to next message
Kenn Hussey is currently offline Kenn HusseyFriend
Rafael,
The reason for this behavior is that you have directly referenced a
primitive type (Integer) from the metamodel instead of from the primitive
types library (only metaclasses from the metamodel should be directly
referenced). With the current profile definition algorithm, metadata from
packages other than the profile being defined are copied into the definition
of the profile. This won't necessarily be the case once we fix
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163556. Please update that bug
or open a new one so that we'll remember to cover your use case. Thanks!
Kenn
"Rafael Chaves" <chaves@inf.ufsc.nospam.br> wrote in message
news:epk79s$ith$1@utils.eclipse.org...
> </ownedAttribute>
> </packagedElement>
> </uml:Profile>
> It results in a EPackage instance that describes the UML metamodel. Also,
> persisted in a way that stereotype applications are lost. The reason seems
> to be that the XMI for such a model refers to stereotypes coming from
> </uml:Model>
> </xmi:XMI>
> The trigger to this problem seems to be that I am referring to a type from
> the uml package (integer). If I remove the reference, the problem goes
> away.
> Rafael
Re: strange behavior when defining a profile [message #469714 is a reply to message #469712] Mon, 29 January 2007 18:44 Go to previous messageGo to next message
Thanks, Kenn, I opened bug 172030:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=172030
> primitive types library (only metaclasses from the metamodel
> should be directly referenced)
Is there a place where one can learn about rules like that?
In the specific case, should my profile be importing UMLPrimitiveTypes
instead (and references to uml::Integer be changed to
UMLPrimitiveTypes::Integer)?
Rafael
Kenn Hussey wrote:
> Rafael,
> Kenn
>> <?xml version="1.0" encoding="UTF-8"?>
>> </ownedAttribute>
>> </packagedElement>
>> </uml:Profile>
>> </uml:Model>
>> </xmi:XMI>
>> away.
>> Thanks,
>> Rafael
Re: strange behavior when defining a profile [message #470059 is a reply to message #469714] Mon, 05 February 2007 19:54 Go to previous messageGo to next message
Rafael,
The "expected" way to use primitive types is described in the articles
available at http://wiki.eclipse.org/index.php/MDT-UML2#Articles. Strictly
speaking, there's nothing wrong with a profile referencing a primitive type
defined in another model or profile...
Kenn
news:eplf98$bv0$1@utils.eclipse.org...
> Rafael
> Kenn Hussey wrote:
>> Rafael,
>> definition of the profile. This won't necessarily be the case once we fix
>> bug or open a new one so that we'll remember to cover your use case.
>> Thanks!
>> Kenn
>>> </ownedAttribute>
>>> </packagedElement>
>>> </uml:Profile>
>>> </uml:Model>
>>> </xmi:XMI>
>>> goes away.
>>> Thanks,
>>> Rafael
Re: strange behavior when defining a profile [message #470088 is a reply to message #470059] Mon, 05 February 2007 23:36 Go to previous message
It seems I am doing it properly now.
> Strictly
> type defined in another model or profile...
Yes, I understand that. The problem in this specific case was that the
primitive types in "uml" were private and I hadn't noticed it.
Thanks!
Rafael
Kenn Hussey wrote:
> Rafael,
> Kenn
>> Thanks,
>> Rafael
>> Kenn Hussey wrote:
>>> Rafael,
>>> Thanks!
>>> Kenn
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </uml:Profile>
>>>> </uml:Model>
>>>> </xmi:XMI>
>>>> goes away.
>>>> Thanks,
>>>> Rafael
Re: strange behavior when defining a profile [message #576673 is a reply to message #469706] Mon, 29 January 2007 16:46 Go to previous message
Rafael,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163556 Please update that bug
Kenn
> </ownedAttribute>
> </packagedElement>
> </uml:Profile>
> </uml:Model>
> </xmi:XMI>
> away.
> Rafael
Re: strange behavior when defining a profile [message #576764 is a reply to message #469712] Mon, 29 January 2007 18:44 Go to previous message
Rafael
Kenn Hussey wrote:
> Rafael,
> Kenn
>> </ownedAttribute>
>> </packagedElement>
>> </uml:Profile>
>> </uml:Model>
>> </xmi:XMI>
>> away.
>> Thanks,
>> Rafael
Re: strange behavior when defining a profile [message #582027 is a reply to message #469714] Mon, 05 February 2007 19:54 Go to previous message
Rafael,
available at http://wiki.eclipse.org/index.php/MDT-UML2#Articles Strictly
Kenn
> Rafael
> Kenn Hussey wrote:
>> Rafael,
>> Thanks!
>> Kenn
>>> </ownedAttribute>
>>> </packagedElement>
>>> </uml:Profile>
>>> </uml:Model>
>>> </xmi:XMI>
>>> goes away.
>>> Thanks,
>>> Rafael
Re: strange behavior when defining a profile [message #582231 is a reply to message #470059] Mon, 05 February 2007 23:36 Go to previous message
> Strictly
Thanks!
Rafael
Kenn Hussey wrote:
> Rafael,
> Kenn
>> Thanks,
>> Rafael
>> Kenn Hussey wrote:
>>> Rafael,
>>> Thanks!
>>> Kenn
>>>> </ownedAttribute>
>>>> </packagedElement>
>>>> </uml:Profile>
>>>> </uml:Model>
>>>> </xmi:XMI>
>>>> goes away.
>>>> Thanks,
>>>> Rafael
Previous Topic:private package imports
Next Topic:Custom class [1..*] stereotype attribute saved as foo="/-1"
Current Time: Wed Jul 08 09:11:57 GMT 2020
Powered by FUDForum. Page generated in 0.02456 seconds
