Home » Eclipse Projects » Platform - User Assistance (UA) » Problems with RCP Help in 3.3
Problems with RCP Help in 3.3 [message #469650] |
Sun, 30 September 2007 22:27 |
J. Michael Dean, M.D. Messages: 218 Registered: July 2009 |
Migrated to 3.3 and my RCP help system continues to work on OSX platform but
breaks on Win32 with an error involving index.jsp. I noted the previous
thread about this, and my old help plugin requested Tomcat, etc. so I
changed this to only depend on org.eclipse.help.webapp and
org.eclipse.help.ui and I have my run configuration check for optional
dependencies. However, my error persists, and is an HTTP ERROR: 500 unable
to compile class for JSP, RequestURI=/help/index.jsp (and says powered by
Jetty, etc.)
When I examine the plugins in the exported product, Tomcat is still present,
which is disturbing since it is not checked off as a required plugin in my
run configuration, and I wonder if this is part of my problem.
Interestingly, if I select dynamic help, the entire system works inside that
window, with full access to all content, etc. Just does not work when I
select "Help Contents" and an external browser is invoked.
The documentation about Help continues to indicate the need to add the
larger number of plugin dependencies and I am working off the paper from
September by Goldthorpe and Archer.
Thanks in advance for any help you might be able to provide.
- Mike
Re: Problems with RCP Help in 3.3 [message #469652 is a reply to message #469650] |
Mon, 01 October 2007 18:11 |
Originally posted by: nospam_kowalskilee.gmail.com
I use a subset of the help system plug-ins to make a standalone help
system running on Windows XP. I know that my situation is not strictly
an RCP situation, but maybe you can use this to compare.
The subset of plug-ins I find that is needed to run the standalone help
system on Windows XP is:
org.eclipse.core.runtime.compatibility.registry
org.eclipse.equinox.launcher.win32.win32.x86
com.ibm.icu
javax.servlet.jsp
javax.servlet
org.apache.commons.el
org.apache.commons.logging
org.apache.jasper
org.apache.lucene.analysis
org.apache.lucene
org.eclipse.core.contenttype
org.eclipse.core.expressions
org.eclipse.core.jobs
org.eclipse.core.runtime.compatibility.auth
org.eclipse.equinox.app
org.eclipse.equinox.common
org.eclipse.equinox.http.jetty
org.eclipse.equinox.http.registry
org.eclipse.equinox.http.servlet
org.eclipse.equinox.jsp.jasper.registry
org.eclipse.equinox.preferences
org.eclipse.equinox.registry
org.eclipse.help.base
org.eclipse.help
org.eclipse.osgi.services
org.eclipse.osgi
org.eclipse.update.configurator
org.mortbay.jetty
I have some older version doc plug-ins, so I keep the
runtime.compatibility plug-in to handle those.
--Lee Anne
(for email, remove the "nospam_" portion)
> Jetty, etc.)
> - Mike
Re: Problems with RCP Help in 3.3 [message #472415 is a reply to message #469651] |
Mon, 31 March 2008 10:43 |
Originally posted by: hiteshn.mail.gmail.com
Even I face the same problem as mentioned by Michael. Following is the list
of answers to Chris's qeustions:
When you start Help/Contents do you see multiple frames in the browser
or just one frame with the message about being unable to compile index.jsp?
I can see only one frame which says "HTTP ERROR: 500
Class org.apache.jasper.servlet.JspServlet does not implement the requested
interface javax.servlet.ServletRequestURI=/help/index.jspPowered by
Jetty://"> Are you able to perform a Help/Search and find results when you
perform
> a search?
Yes, it works well while performing a search, the problem comes only when I
click Help contents under Help menu
> Are there any errors written to the log?
It is as follows:
Mar 31, 2008 4:10:48 PM org.mortbay.jetty.servlet.ServletHandler handle
WARNING: Error for /help/index.jsp
java.lang.IncompatibleClassChangeError: Class
at org.eclipse.equinox.jsp.jasper.JspServlet.init(JspServlet.ja va:81)
at
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.initializeDelegate(ServletManager.java:195)
at
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:179)
at
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:75)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:288)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
at
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
at org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
Please help me in solving this problem.
Hitesh...
"Chris Goldthorpe" <cgold@us.ibm.com> wrote in message
news:fdr8au$c6l$1@build.eclipse.org...
> Nice to see that someone is reading our article.
> If the help view is working but not the browser then this indicates that
> the help server is starting OK but there seems to be a problem loading
> the jsps which form the webapp. The help view does not use any jsps.
> I can think of a couple of possibilities, one is the jasper compiler is
> not being included in your RCP, the other is that the jsp file is not
> found.
> When you start Help/Contents do you see multiple frames in the browser or
> Are you able to perform a Help/Search and find results when you perform a
> search?
> As for the tomcat plugin if you remove it from the list of plugins in your
> product configuration I would not expect it to get pulled in as a
> dependency of any other plugin. I'm not sure why you are seeing this.
Re: Problems with RCP Help in 3.3 [message #473576 is a reply to message #469652] |
Fri, 18 April 2008 06:47 |
I used the same set of plug-ins but still couldnt find any luck. I face the
same problem even now :(
Thanks in advance for the help.
~ Hitesh
"Lee Anne" <nospam_kowalskilee@gmail.com> wrote in message
news:fdrd7d$9la$1@build.eclipse.org...
>I use a subset of the help system plug-ins to make a standalone help system
>running on Windows XP. I know that my situation is not strictly an RCP
> com.ibm.icu
> javax.servlet.jsp
> javax.servlet
> org.apache.jasper
> org.apache.lucene
> org.eclipse.help
> org.eclipse.osgi
> org.mortbay.jetty
> --Lee Anne
>> but
>> unable
>> Jetty, etc.)
>> present,
>> my
>> that
>> - Mike
Re: Problems with RCP Help in 3.3 [message #586114 is a reply to message #469650] |
com.ibm.icu
javax.servlet.jsp
javax.servlet
org.apache.jasper
org.apache.lucene
org.eclipse.help
org.eclipse.osgi
org.mortbay.jetty
--Lee Anne
> Jetty, etc.)
> - Mike
Re: Problems with RCP Help in 3.3 [message #611078 is a reply to message #469651] |
perform
> a search?
It is as follows:
at
at
at
at
at
at
at
Hitesh...
> found.
> search?
Re: Problems with RCP Help in 3.3 [message #611999 is a reply to message #469652] |
~ Hitesh
> com.ibm.icu
> javax.servlet.jsp
> javax.servlet
> org.apache.jasper
> org.apache.lucene
> org.eclipse.help
> org.eclipse.osgi
> org.mortbay.jetty
> --Lee Anne
>> but
>> unable
>> Jetty, etc.)
>> present,
>> my
>> that
>> - Mike
Current Time: Wed Apr 24 21:18:40 GMT 2024
Powered by FUDForum. Page generated in 0.03608 seconds
