Home » Archived » AMW » An internal error occurred during: "Launching...
An internal error occurred during: "Launching... [message #469584] Wed, 18 February 2009 13:04 Go to next message
--------------070609040503030402010102
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
<small><big>Hi Marcos, I believe I'm close to success with using the
AOM use case with my models and rules, but I need
help once again.<br>
I've got the following code:<br>
</big></small><font face="Courier New, Courier, monospace"><small><br>
<font color="#33ccff">abstract rule newAction {<br>
&nbsp;&nbsp; &nbsp;from <br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;attr : AMW!Action
(attr.getReferredElement().oclIsKindOf(SecureUML!Action))<br >
&nbsp;&nbsp; &nbsp;to<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;out : iBuilder_plus_SecureUML_Flat_MM!Action (&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp; ...&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; <br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;)<br>
}<br>
&nbsp;<br>
rule newCompositeAction extends newAction {<br>
from<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; attr : AMW!Action (&nbsp;&nbsp;&nbsp;
attr.getReferredElement().oclIsKindOf(SecureUML!CompositeAct ion) and <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; not
SecureUML!CompositeAction.getInstanceById('advice',attr.elem ent.ref).subordinatedAction.oclIsUndefined()&nbsp;&n bsp;&nbsp;
&nbsp;&nbsp;&nbsp; )<br>
to<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;out : iBuilder_plus_SecureUML_Flat_MM!CompositeAction (&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;
&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp; --CompositeAction extends abstract
class 'Action'<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;subordinatedAction &lt;-
attr.getSubordinatedAction&nbsp;&nbsp;&nbsp;& ;nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;& ;nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;& ;nbsp;&nbsp;&nbsp;&nbsp; --THIS IS THE PROBLEMATIC
LINE, I GUESS<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;)&nbsp;&nbsp; &nbsp;<br>
}&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; <br>
<br>
helper context AMW!Action def: getSubordinatedAction :
Set(SecureUML!Action) =
self.getReferredElement().subordinatedAction;&nbsp; --CODE CAUSING THE ERROR</font></small></font><br>
<br>
which works perfectly well with a simple model.<br>
However, when feeding the transformation with a more elaborated model,
it throws the attached errors (console and error log).<br>
I've googled around and found nothing that helps me. Which should be
the reason for such errors?.<br>
The input models validate correctly, and the attributes are set and
check for not-null before referring to them.<br>
Any pointers would be greatly appreciated.<br>
Best regards,<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; Juan Pedro<br>
</body>
</html>
Content-Type: text/plain;
name="Error_Console.txt"
Content-Disposition: inline;
filename="Error_Console.txt"
GRAVE: ****** BEGIN Stack Trace
GRAVE: exception:
GRAVE: null
at org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:69)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.invok e(ASMEMFModelElement.java:683)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:335)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
at org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:167)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
at org.eclipse.gmt.weaver.transformation.util.TransformationUti l.executeTransfo(TransformationUtil.java:103)
at org.eclipse.gmt.weaver.transformation.panel.TransformationWe avingPanel$TAction.run(TransformationWeavingPanel.java:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.getMe taobject(ASMEMFModelElement.java:422)
at org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.<init >(ASMEMFModelElement.java:557)
at org.eclipse.gmt.weaver.amw4atl.ASMAMWModelElement.<init>(ASMAMWModelElement.java:43)
at org.eclipse.gmt.weaver.amw4atl.ASMAMWModel.getASMModelElemen t(ASMAMWModel.java:361)
at org.eclipse.gmt.weaver.amw4atl.ASMAMWModelElement.getModelEl ement(ASMAMWModelElement.java:159)
at org.eclipse.gmt.weaver.amw4atl.ASMAMWModelElement.getReferre dElement(ASMAMWModelElement.java:194)
... 52 more
GRAVE: A.main() : ??#22 null
GRAVE: local variables = {self=NameEqualitybyType : ASMModule}
GRAVE: local stack = []
GRAVE: A.__matcher__() : ??#1 null
GRAVE: A.__matchprClass() : ??#31 37:53-37:83
GRAVE: local variables = {left=left!UIComboBox, mmw=IN!UIComboBox_EAnnotation, self=NameEqualitybyType : ASMModule}
GRAVE: local stack = [TransientLinkSet {}, TransientLink {rule = 'prClass', sourceElements = {mmw = IN!UIComboBox_EAnnotation}, targetElements = {}, variables = {left = left!UIComboBox}}, TransientLink {rule = 'prClass', sourceElements = {mmw = IN!UIComboBox_EAnnotation}, targetElements = {}, variables = {left = left!UIComboBox}}, 'right']
GRAVE: NativeOperation public static org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny org.eclipse.gmt.weaver.amw4atl.ASMAMWModelElement.getReferre dElement(org.eclipse.m2m.atl.engine.vm.StackFrame,org.eclips e.m2m.atl.drivers.emf4atl.ASMEMFModelElement)
GRAVE: args = [IN!EAnnotation]
GRAVE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow continuation after errors).
GRAVE: null
java.lang.RuntimeException
at org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:195)
at org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:95)
at org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:87)
at org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:77)
Caused by: java.lang.reflect.InvocationTargetException
... 47 more
... 52 more
name="error_log.txt"
filename="error_log.txt"
An internal error occurred during: "Launching WeavingConCopy4_modelosViejos".
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eURIFragmentSegm ent(BasicEObjectImpl.java:294)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getURIFragm ent(ResourceImpl.java:671)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.getURIFragmen t(XMLResourceImpl.java:422)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getURIFragment( XMLHelperImpl.java:718)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getIDREF(XMLHel perImpl.java:753)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveIDRefMany(XML SaveImpl.java:1985)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1337)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2667)
at org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:90)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:592)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:256)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:205)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1344)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:986)
at org.eclipse.m2m.atl.engine.AtlEMFModelHandler.saveModel(AtlE MFModelHandler.java:148)
at org.eclipse.m2m.atl.engine.AtlEMFModelHandler.saveModel(AtlE MFModelHandler.java:67)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:372)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:463)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:435)
at org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:42)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:764)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:614)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:880)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1083)
--------------070609040503030402010102--
Re: An internal error occurred during: "Launching... [message #469851 is a reply to message #469584] Wed, 18 February 2009 13:31 Go to previous messageGo to next message
<html>
<head>
</head>
Just for the record, I also tried: <br>
<br>
<small><font color="#33ccff" face="Courier New, Courier, monospace">subordinatedAction
&lt;- attr.getSubordinatedAction.-&gt;collect(e |
thisModule.resolveTemp(e, 'out') )-&gt;flatten()</font></small><br>
<br>
(which I don't think it's neccesary here), and got a different error,
but an error anyhow.<br>
<br>
<br>
<br>
<br>
<br>
Juan Pedro Silva escribi&oacute;:
<blockquote cite="mid:gnhija$nba$1@build.eclipse.org" type="cite"><small><big>Hi
}<br>
&nbsp;<br>
from<br>
to<br>
class 'Action'<br>
LINE, I GUESS<br>
<br>
<br>
Best regards,<br>
</blockquote>
</body>
</html>
Re: An internal error occurred during: "Launching... [message #469852 is a reply to message #469851] Fri, 20 February 2009 11:17 Go to previous messageGo to next message
are you sure you sent the right error console? It seems the same as you
had when executing the NameSimilarityByType transformation.
The log files doesn't say too much to me: it seems there is an
incompatibility over the identifiers of the model elements. More
information about the models would help,
Marcos.
Re: An internal error occurred during: "Launching... [message #469853 is a reply to message #469852] Mon, 23 February 2009 08:57 Go to previous message
Marcos, the problem persists with the new clean metamodels (found out
how to properly define my datatypes). I've fixed that already.
Below you can see the console report.
Any ideas?.
Juan Pedro
Marcos Didonet Del Fabro escribió:
> you had when executing the NameSimilarityByType transformation.
> Marcos.
GRAVE: exception:
GRAVE: null
at sun.reflect.GeneratedMethodAccessor91.invoke(Unknown Source)
at
at
at
at
at
at
org.eclipse.m2m.atl.engine.vm.ASMExecEnv.getHelperValue(ASME xecEnv.java:322)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.getHelper( ASMOclAny.java:168)
at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.get(A SMEMFModelElement.java:138)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:298)
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:361)
at
at
at
at
at
at
at
at
at
at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel.getASMModelE lement(ASMEMFModel.java:76)
at
at
... 35 more
GRAVE: A.main() : ??#62 null
GRAVE: local variables = {self=WJP4 : ASMModule}
GRAVE: A.__exec__() : ??#28 null
GRAVE: local variables = {e=TransientLink {rule =
'newCompositeAction', sourceElements = {attr =
IN!SystemUsersFullControl}, targetElements = {out =
OUT!FuncionarioSystemUsersFullControl}, variables = {}}, self=WJP4 :
ASMModule}
GRAVE: A.__applynewCompositeAction(1 : NTransientLink;) : ??#29 28:39-28:58
GRAVE: local variables = {out=OUT!FuncionarioSystemUsersFullControl,
attr=IN!SystemUsersFullControl, link=TransientLink {rule =
ASMModule}
GRAVE: local stack = [OUT!FuncionarioSystemUsersFullControl,
OUT!FuncionarioSystemUsersFullControl, WJP4 : ASMModule]
GRAVE: MAMW!Action;.__initgetPermissions() : ??#1 16:77-16:102
GRAVE: local variables = {self=IN!SystemUsersFullControl}
GRAVE: args = [IN!SystemUsersFullControl]
GRAVE: null
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 31 more
at
at
at
at
at
... 35 more
Previous Topic:ERROR: could not find operation getReferredElement
Next Topic:cannot compile sources
Current Time: Mon Mar 17 15:02:29 EDT 2025
Powered by FUDForum. Page generated in 0.04229 seconds
