Re: Could not open the editor: Editor could not be initialized. [message #47592 is a reply to message #47558] |
Wed, 23 July 2008 13:19 |
Originally posted by: brianf.sybase.com
Can you provide a series of steps to reproduce this issue from a clean
environment?
"Lee Kon Keong" <konkeong@uberfusion.com> wrote in message
news:g6603q$faf$1@build.eclipse.org...
> Dear All,
> Does anyone encountered this problem?
> I am using Ganymede (3.4) on windows xp sp 3 with JDK 1.5.0_09.
> The Data Tools Platform Connectivity is
> 1.6.0.v200805151245-7_70Dn-QXuj8_GoX7JfPiBEG.
> When I open a file of extension "*.sql", it open in the "SQL File
> Editor" but with the error message and stack trace below.
> java.lang.NoClassDefFoundError
> at javax.crypto.SecretKeyFactory.getInstance(DashoA12275)
> at
> org.eclipse.datatools.connectivity.internal.security.Default CipherProvider.loadKey(DefaultCipherProvider.java:66)
> at
> org.eclipse.datatools.connectivity.internal.security.Default CipherProvider.createDecryptionCipher(DefaultCipherProvider. java:48)
> at
> org.eclipse.datatools.connectivity.internal.ConnectionProfil eMgmt.loadCPs(ConnectionProfileMgmt.java:749)
> at
> org.eclipse.datatools.connectivity.internal.ConnectionProfil eMgmt.loadCPs(ConnectionProfileMgmt.java:489)
> at
> org.eclipse.datatools.connectivity.internal.InternalProfileM anager.loadProfiles(InternalProfileManager.java:936)
> at
> org.eclipse.datatools.connectivity.internal.InternalProfileM anager.getProfiles(InternalProfileManager.java:135)
> at
> org.eclipse.datatools.connectivity.internal.InternalProfileM anager.getProfileByName(InternalProfileManager.java:210)
> at
> org.eclipse.datatools.connectivity.ProfileManager.getProfile ByName(ProfileManager.java:96)
> at
> org.eclipse.datatools.sqltools.sqleditor.SQLEditorConnection Info.getConnectionProfile(SQLEditorConnectionInfo.java:106)
> at
> org.eclipse.datatools.sqltools.sqleditor.SQLEditorConnection Info.getSharedConnection(SQLEditorConnectionInfo.java:229)
> at
> org.eclipse.datatools.sqltools.sqleditor.SQLEditorConnection Info.isConnected(SQLEditorConnectionInfo.java:252)
> at
> org.eclipse.datatools.sqltools.sqleditor.SQLEditorConnection Info.getName(SQLEditorConnectionInfo.java:214)
> at
> org.eclipse.datatools.sqltools.sqleditor.SQLEditor.refreshCo nnectionStatus(SQLEditor.java:1726)
> at
> org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor.refreshConnectionStatus(SQLScrapbookEdito r.java:264)
> at
> org.eclipse.datatools.sqltools.sqleditor.SQLEditor.doSetInpu t(SQLEditor.java:919)
> at
> org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor.doSetInput(SQLScrapbookEditor.java:173)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3025)
> at
> org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:446)
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:354)
> at
> org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
> at
> org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
> at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2483)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3043)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3070)
> at
> org.eclipse.datatools.sqltools.sqleditor.SQLEditor.init(SQLE ditor.java:544)
> at
> org.eclipse.datatools.sqltools.internal.sqlscrapbook.editor. SQLScrapbookEditor.init(SQLScrapbookEditor.java:128)
> at
> org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:799)
> at
> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
> at
> org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
> at
> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
> at
> org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
> at
> org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1410)
> at
> org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:944)
> at
> org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
> at
> org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
> at
> org.eclipse.ui.internal.Workbench$27.runWithException(Workbe nch.java:1361)
> at
> at
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> Thanks
> konkeong
Re: Could not open the editor: Editor could not be initialized. [message #47717 is a reply to message #47650] |
Thu, 24 July 2008 13:53 |
Glad it was an easy fix! :)
news:g68kkg$tn0$1@build.eclipse.org...
> My mistake.
> I was trying to overwrite the "local_policy.jar" and
> "US_export_policy.jar" in my
> "C:\Program Files\Java\jre1.5.0_09\lib\security" directory with "enhanced"
> copy, so that I can do AES more than 128 bit encryption.
> Apparently, I just rename the above 2 jar files to something else, and
> forgot to copy the new jar files in.
> Essentially, my JRE is missing those 2 jar files.
> After I put back in those 2 jar files, there is no more error message.
> Everything works fine.
>> environment?
>>> Dear All,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>> Thanks
>>> konkeong
FUDForum. Page generated in 0.03412 seconds
