Home » Archived » AMW » Class WlinkEnd - Error
Class WlinkEnd - Error [message #469102] Fri, 21 November 2008 13:44 Go to next message
Tim Brömme is currently offline Tim BrömmeFriend
I always get an "CLass WlinkEnd is not extended" error, when using
the weaver wizard. It occurs right after choosing any metamodel extension
and then pressing the 'next' button.
I use ganymede with the newest ATL release (2.0.1).
Here is the console output:
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at
org.eclipse.gmt.tcs.injector.wrappers.antlr3.ParserWrapper.p arse(ParserWrapper.java:45)
at
org.eclipse.gmt.tcs.injector.TCSInjector.performImportation( TCSInjector.java:258)
at
org.eclipse.gmt.tcs.injector.TCSInjector.performImportation( TCSInjector.java:218)
at org.eclipse.gmt.tcs.injector.TCSInjector.inject(TCSInjector. java:99)
at
org.eclipse.gmt.weaver.plugin.util.WeaverResourceUtil.km3Str eam2EcoreResource(WeaverResourceUtil.java:304)
at
org.eclipse.gmt.weaver.core.WeaverModelManager.getWeavingMet amodelRS(WeaverModelManager.java:314)
at
org.eclipse.gmt.weaver.core.WeaverModelManager.getWeavingMet amodelRS(WeaverModelManager.java:253)
at
org.eclipse.gmt.weaver.core.WeaverModelManager.getWeavingMet amodel(WeaverModelManager.java:340)
at
org.eclipse.gmt.weaver.core.WeaverModelManager.initWeavingMe taModel(WeaverModelManager.java:147)
at
org.eclipse.gmt.weaver.core.WeaverModelManager.<init>(WeaverModelManager.java:128)
at
org.eclipse.gmt.weaver.wizards.WeaverWizard.initializeWeavin gResource(WeaverWizard.java:453)
at
org.eclipse.gmt.weaver.wizards.WeaverFirstWizardPage$8.run(W eaverFirstWizardPage.java:490)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:446)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:354)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 934)
at
org.eclipse.gmt.weaver.wizards.WeaverFirstWizardPage.dialogC hanged(WeaverFirstWizardPage.java:510)
at
org.eclipse.gmt.weaver.wizards.WeaverFirstWizardPage.getNext Page(WeaverFirstWizardPage.java:633)
at
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:813)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at
org.eclipse.ui.internal.handlers.WizardHandler$New.executeHa ndler(WizardHandler.java:253)
at
org.eclipse.ui.internal.handlers.WizardHandler.execute(Wizar dHandler.java:273)
at
org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:281)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at
org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at
org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at
org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:247)
at
org.eclipse.ui.internal.actions.CommandAction.runWithEvent(C ommandAction.java:157)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: java.lang.Error: Unresolved compilation problems:
org.eclipse.gmt.tcs.injector.TCSRuntime cannot be resolved to a type
at
org.eclipse.gmt.tcs.injector.KM3_ANTLR3Lexer.<init>(KM3_ANTLR3Lexer.java:83)
... 67 more
at
org.eclipse.gmt.weaver.wizards.WeaverFirstWizardPage$8.run(W eaverFirstWizardPage.java:494)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: org.eclipse.gmt.weaver.exception.WeaverException: Class
WLinkEnd is not extended
at
org.eclipse.gmt.weaver.plugin.util.WeaverResourceUtil.valida teWeavingMetamodelSemantic(WeaverResourceUtil.java:389)
at
org.eclipse.gmt.weaver.core.WeaverModelManager.getWeavingMet amodelRS(WeaverModelManager.java:321)
at
at
at
at
at
at
... 51 more
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 67 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 51 more
Re: Class WlinkEnd - Error [message #469106 is a reply to message #469102] Mon, 24 November 2008 10:02 Go to previous messageGo to next message
Marcos Didonet Del Fabro is currently offline Marcos Didonet Del FabroFriend
Member
you should also check out the "org.eclipse.gmt.am3.dsls.km3", which is
available in the AM3 SVN.
Marcos.
Tim Brömme wrote:
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 67 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 51 more
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 67 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 51 more
Re: Class WlinkEnd - Error [message #469108 is a reply to message #469106] Mon, 01 December 2008 16:08 Go to previous messageGo to next message
Juan Pedro Silva is currently offline Juan Pedro SilvaFriend
Hi everybody.
Marcos, I also get this error: "org.eclipse.gmt.tcs.injector.TCSRuntime
cannot be resolved to a type", although having checked out
org.eclipse.gmt.am3.dsls.km3 (version 0.2.0).
Both classes in org.eclipse.gmt.weaver/parser_src (KM3_ANTLR3Lexer and
KM3_ANTLR3Parser in package org.eclipse.gmt.tcs.injector) have
dependencies on it.
How should I fix this?.
Thanks again.
Marcos Didonet Del Fabro escribió:
> Marcos.
> Tim Brömme wrote:
>> Hi,
>> extension
>> Method)
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> ... 67 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 51 more
>> Method)
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 67 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 51 more
Re: Class WlinkEnd - Error [message #469111 is a reply to message #469108] Wed, 03 December 2008 10:02 Go to previous messageGo to next message
Member
You can remove the dependency to "tcs injector" from the
"org.eclipse.gmt.am3.dsls.km3" plug-in.
Marcos.
Juan Pedro Silva wrote:
> Hi everybody.
> dependencies on it.
> Thanks again.
>> Hi,
>> Marcos.
>> Tim Brömme wrote:
>>> Hi,
>>> extension
>>> Method)
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 67 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 51 more
>>> Method)
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 67 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 51 more
Re: Class WlinkEnd - Error [message #469130 is a reply to message #469111] Wed, 03 December 2008 11:01 Go to previous messageGo to next message
--------------020904050105070703090302
Marcos, I wasn't able to do that. Such dependency does not appear in the
manifest, and although it appears in the Java Build Path, the "remove"
option is grayed out and cannot delete it. I cannot remove from the
project explorer either.
You can take a look at the attached pictures to see what I mean.
Re: Class WlinkEnd - Error [message #469140 is a reply to message #469130] Tue, 09 December 2008 11:15 Go to previous messageGo to next message
Member
I will install one version from scratch, to check if I had some previous
setting that avoided this problem.
Marcos.
>> Hi,
>> Marcos.
>>> Hi everybody.
>>> "org.eclipse.gmt.tcs.injector.TCSRuntime cannot be resolved to a
>>> type", although having checked out org.eclipse.gmt.am3.dsls.km3
>>> (version 0.2.0).
>>> and KM3_ANTLR3Parser in package org.eclipse.gmt.tcs.injector) have
>>> dependencies on it.
>>> Thanks again.
>>>> Hi,
>>>> is available in the AM3 SVN.
>>>> Marcos.
>>>> Tim Brömme wrote:
>>>>> Hi,
>>>>> extension
>>>>> at
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 67 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 51 more
>>>>> at
>>>>> at
>>>>> at
>>>>> Source)
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 67 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 51 more
Re: Class WlinkEnd - Error [message #469147 is a reply to message #469140] Tue, 09 December 2008 11:37 Go to previous messageGo to next message
Thanks a lot.
I'll hold for your feedback.
> Hello,
> previous setting that avoided this problem.
> Marcos.
>> the manifest, and although it appears in the Java Build Path, the
>> "remove" option is grayed out and cannot delete it. I cannot remove
>> from the project explorer either.
>>> Hi,
>>> Marcos.
>>>> Hi everybody.
>>>> (version 0.2.0).
>>>> dependencies on it.
>>>> Thanks again.
>>>>> Hi,
>>>>> which is available in the AM3 SVN.
>>>>> Marcos.
>>>>> Tim Brömme wrote:
>>>>>> Hi,
>>>>>> extension
>>>>>> at
>>>>>> Method)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> ... 67 more
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Class WLinkEnd is not extended
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 51 more
>>>>>> at
>>>>>> Method)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> ... 67 more
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Source)
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 51 more
Re: Class WlinkEnd - Error [message #469151 is a reply to message #469147] Thu, 18 December 2008 15:42 Go to previous message
Member
if you want to use KM3 metamodels as input, it is necessary to have the
tcs injector installed. However, we cannot put it into the code since
TCS is still under review process. A binary version of TCS is available at:
http://www.sciences.univ-nantes.fr/lina/atl/www/tcsdemo/2008 1103/
Marcos.
> Thanks a lot.
>> Hello,
>> Marcos.
>>>> Hi,
>>>> Marcos.
>>>>> Hi everybody.
>>>>> (version 0.2.0).
>>>>> dependencies on it.
>>>>> Thanks again.
>>>>>> Hi,
>>>>>> Marcos.
>>>>>> Tim Brömme wrote:
>>>>>>> Hi,
>>>>>>> extension
>>>>>>> at
>>>>>>> Method)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> at
>>>>>>> ... 67 more
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> ... 51 more
>>>>>>> at
>>>>>>> Method)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> at
>>>>>>> ... 67 more
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Source)
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> ... 51 more
Previous Topic:Export of AMW plugins
Next Topic:Model combination.
Current Time: Tue Aug 04 19:10:20 GMT 2020
Powered by FUDForum. Page generated in 0.02355 seconds
