Home » Eclipse Projects » Riena » Problem with annotated injection
Re: Problem with annotated injection [message #468154 is a reply to message #468144] |
Tue, 04 August 2009 12:07 |
RRK Messages: 21 Registered: July 2009 |
Junior Member |
Stefan Liebig schrieb:
>>> Hi Rüdiger,
>>> When using annotations for injection something has to interpret those
>>> annotations and perform the necessary actions.
>>> In the case where classes are defined within extension points like
>>> your SubModuleController the ExtensionInjector takes care of the wiring.
>>> I you create a pojo yourself you have the choice of using either:
>>> -Inject.Service().into( pojo ). ..
>>> or
>>> - use annotations and do a Wire.instance( pojo ).andStart()
>>> HTH
>>> Stefan
>>>> Hello,
>>>> in Riena I like to inject services with @InjectService.
>>>> Everything is easy in a SubModuleController class.
>>>> But in pojo's I have the problem, that bind won't be called.
>>>> The following code runs well from Activator.start
>>>> for pojo CurrentUser without annotation:
>>>> currentUser = new CurrentUser();
>>>> Inject.service(ISubjectHolderService.class.getName())
>>>> .into(currentUser)
>>>> .bind("bindSubjectHolderService")
>>>> .unbind("unbindSubjectHolderService")
>>>> .andStart(context);
>>>> Inject.service(IUserService.class.getName())
>>>> .into(currentUser)
>>>> .bind("bindUserService")
>>>> .unbind("unbindUserService")
>>>> .andStart(context);
>>>> If in Activator.start or any other place only
>>>> is called and CurrentUser is annotated like this the services are null.
>>>> public class CurrentUser {
>>>> private ISubjectHolderService subjectHolderService;
>>>> private IUserService userService;
>>>> @InjectService(service= IUserService.class ,unbind =
>>>> public void bindUserService(IUserService srv) {
>>>> this.userService = srv;
>>>> @InjectService(service=ISubjectHolderService.class,unbind="unbindSubjectHolderService ")
>>>> public void bindSubjectHolderService(ISubjectHolderService
>>>> srv) {
>>>> this.subjectHolderService = srv;
>>>> If tried to change @InjectService or use @WireWith but I can't get
>>>> it run.
>>>> What goes wrong.
>>>> Rüdiger
>> Hello Stefan,
>> thanks for your rapide response. I tried Wire.instance and it works
>> well and is more convenient to me.
>> Rüdiger
> Hello Rüdiger,
> You can even simplify your pojo annotations:
> @InjectService()
> @InjectService()
> public void bindSubjectHolderService(ISubjectHolderService srv) {
> The service class is now taken from the parameter type of the annotated
> bind method and the unbind method name is generated by prefixing the
> annotated bind method with with "un".
> Tschüß,
> Stefan
Hello Stefan,
thanks very much for your helpfull usage hint. It would be great to find
such information in a description for Riena. Now I have to learn it
the hard way. Spend hours, that I not really have, by try and error and
greping in inner classes of the framework. But Riena is worth it. Thanks
to the team.
Rüdiger
Re: Problem with annotated injection [message #468168 is a reply to message #468154] |
Tue, 04 August 2009 12:52 |
Stefan Liebig Messages: 124 Registered: July 2009 |
>>>> Hi Rüdiger,
>>>> those annotations and perform the necessary actions.
>>>> wiring.
>>>> or
>>>> HTH
>>>> Stefan
>>>>> Hello,
>>>>> .into(currentUser)
>>>>> .andStart(context);
>>>>> .into(currentUser)
>>>>> .andStart(context); If in Activator.start or any other
>>>>> place only
>>>>> null.
>>>>> srv) {
>>>>> it run.
>>>>> What goes wrong.
>>>>> Rüdiger
>>> Hello Stefan,
>>> Rüdiger
>> Hello Rüdiger,
>> @InjectService()
>> @InjectService()
>> annotated bind method and the unbind method name is generated by
>> prefixing the annotated bind method with with "un".
>> Tschüß,
>> Stefan
> Hello Stefan,
> such information in a description for Riena. Now I have to learn it the
> to the team.
> Rüdiger
Hello Rüdiger,
You are right http://wiki.eclipse.org/Riena_Getting_Started_with_Wiring
needs some polishing. Thanks for the hint!
Keep posting your questions and comments! We will try hard.
Tschüß,
Stefan
Re: Problem with annotated injection [message #478778 is a reply to message #468168] |
Thu, 06 August 2009 19:37 |
Christian Campo Messages: 597 Registered: July 2009 |
>>>>> Hi Rüdiger,
>>>>> wiring.
>>>>> or
>>>>> HTH
>>>>> Stefan
>>>>>> Hello,
>>>>>> .into(currentUser)
>>>>>> .andStart(context);
>>>>>> .into(currentUser)
>>>>>> place only
>>>>>> null.
>>>>>> srv) {
>>>>>> it run.
>>>>>> What goes wrong.
>>>>>> Rüdiger
>>>> Hello Stefan,
>>>> Rüdiger
>>> Hello Rüdiger,
>>> @InjectService()
>>> @InjectService()
>>> Tschüß,
>>> Stefan
>> Hello Stefan,
>> find such information in a description for Riena. Now I have to learn
>> it the hard way. Spend hours, that I not really have, by try and error
>> and greping in inner classes of the framework. But Riena is worth it.
>> Thanks to the team.
>> Rüdiger
> Hello Rüdiger,
> Tschüß,
> Stefan
Hi Rüdiger,
I know you said you had no time but still wanted our documentation in Riena to be better. Help us to help us and write a
little paragraph in the wiki page that Stefan mentioned and add the things you were missing. Add a little documentation,
which I guess you can copy in parts from this thread to help others to be faster in understanding the concepts....
thanks
christian
Re: Problem with annotated injection [message #583150 is a reply to message #468144] |
Junior Member |
>>> Hi Rüdiger,
>>> or
>>> HTH
>>> Stefan
>>>> Hello,
>>>> .into(currentUser)
>>>> .andStart(context);
>>>> .into(currentUser)
>>>> .andStart(context);
>>>> srv) {
>>>> it run.
>>>> What goes wrong.
>>>> Rüdiger
>> Hello Stefan,
>> Rüdiger
> Hello Rüdiger,
> @InjectService()
> @InjectService()
> Tschüß,
> Stefan
Hello Stefan,
to the team.
Rüdiger
Re: Problem with annotated injection [message #583159 is a reply to message #468154] |
>>>> Hi Rüdiger,
>>>> wiring.
>>>> or
>>>> HTH
>>>> Stefan
>>>>> Hello,
>>>>> .into(currentUser)
>>>>> .andStart(context);
>>>>> .into(currentUser)
>>>>> place only
>>>>> null.
>>>>> srv) {
>>>>> it run.
>>>>> What goes wrong.
>>>>> Rüdiger
>>> Hello Stefan,
>>> Rüdiger
>> Hello Rüdiger,
>> @InjectService()
>> @InjectService()
>> Tschüß,
>> Stefan
> Hello Stefan,
> to the team.
> Rüdiger
Hello Rüdiger,
Tschüß,
Stefan
Re: Problem with annotated injection [message #583174 is a reply to message #468168] |
>>>>> Hi Rüdiger,
>>>>> wiring.
>>>>> or
>>>>> HTH
>>>>> Stefan
>>>>>> Hello,
>>>>>> .into(currentUser)
>>>>>> .andStart(context);
>>>>>> .into(currentUser)
>>>>>> place only
>>>>>> null.
>>>>>> srv) {
>>>>>> it run.
>>>>>> What goes wrong.
>>>>>> Rüdiger
>>>> Hello Stefan,
>>>> Rüdiger
>>> Hello Rüdiger,
>>> @InjectService()
>>> @InjectService()
>>> Tschüß,
>>> Stefan
>> Hello Stefan,
>> Thanks to the team.
>> Rüdiger
> Hello Rüdiger,
> Tschüß,
> Stefan
Hi Rüdiger,
thanks
christian
Current Time: Thu Apr 25 08:47:06 GMT 2024
Powered by FUDForum. Page generated in 0.04852 seconds
