Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Browser Widget and Proxy Settings
Browser Widget and Proxy Settings [message #467645] Thu, 02 February 2006 20:51 Go to next message
Originally posted by: jbell80.msn.com
This may be a silly question but...
Is it possible to get the proxy settings through the Browser widget?
(i.e Creating a widget to detect the settings then destroying the widget)
If not does anyone know of another way to get the proxy info? So far I
have tried...
System.getProperty("http.proxyHost") //It isn't set
Also is there anyway to use a configuration script (.pac file)?
I was downloading the pac file and executing it using Rhino
(http://www.mozilla.org/rhino/) but there are commands that are not pure
JavaScript so that didn't work out. (shExpMatch -- Shell Command)
If anyone has any great ideas other than having the user input the
information I would like to hear your ideas.
Jon
Re: Browser Widget and Proxy Settings [message #467720 is a reply to message #467645] Sat, 04 February 2006 15:28 Go to previous message
Bernhard Fastenrath is currently offline Bernhard FastenrathFriend
No, this is currently (3.1.1) not possible.
Have a look at http://bugs.eclipse.org/bugs/show_bug.cgi?id=82295.
The JavaScript code example doesn't work from Browser.execute (),
it would need to be executed with appropriate access permission.
The attached source code may solve the problem, I didn't check that.
Previous Topic:Multi-line header on a table
Next Topic:Multiple Column Filtering in a TableCursor
Current Time: Sat Jan 16 01:09:04 GMT 2021
Powered by FUDForum. Page generated in 0.01561 seconds
