Home » Eclipse Projects » Rich Client Platform (RCP) » How to handle dynamic dependencies at run-time?
How to handle dynamic dependencies at run-time? [message #467457] Fri, 04 May 2007 02:07 Go to next message
I have a plugin that has a JDT dependency needed only to support an
isolated Java editor specific function. Would like to use the plugin in
a Ruby development RCP that does not have the JDT installed (the Java
function is not needed in this case).
Is there any resonable way to detect the absence of the JDT and
exclude/disable the dependence at run-time? Any way short of having two
different static versions of the plugin?
What is the best approach to handling this circumstance?
Gerald
Re: How to handle dynamic dependencies at run-time? [message #467465 is a reply to message #467457] Fri, 04 May 2007 04:51 Go to previous messageGo to next message
> Gerald
How about making your dependency optional?
Re: How to handle dynamic dependencies at run-time? [message #467485 is a reply to message #467465] Fri, 04 May 2007 09:30 Go to previous messageGo to next message
In article <f1es71$8sj$1@build.eclipse.org>, nosp@m.please.org says...
> > Thanks,
> > Gerald
How would that be done? An implementation hint would be appreciated.
Re: How to handle dynamic dependencies at run-time? [message #467548 is a reply to message #467485] Sun, 06 May 2007 16:39 Go to previous messageGo to next message
>>> Thanks,
>>> Gerald
No implementation needed here. In the manifest-Editor, under
'Dependencies' right-click the dependency to be made optional. You'll
see a check-box that does the trick.
Hope that helps.
Cheers, Volker
Re: How to handle dynamic dependencies at run-time? [message #467552 is a reply to message #467548] Mon, 07 May 2007 03:33 Go to previous messageGo to next message
You can also do the same thing with:
Require-Bundle: com.example.blah;resolution:=optional
Import-Package: com.example.foo;resolution:=optional
Though the IDE does the same thing when you drive it from the GUI.
Alex.
Re: How to handle dynamic dependencies at run-time? [message #467566 is a reply to message #467457] Mon, 07 May 2007 10:35 Go to previous messageGo to next message
> Gerald
If you do not want two different static plugins, then you will have to
abstract out the difference. This is normally done by using a standard
interface that can be dynamically populated by the dependency if your
tests show the dependency is available.
Re: How to handle dynamic dependencies at run-time? [message #467571 is a reply to message #467552] Mon, 07 May 2007 11:06 Go to previous messageGo to next message
In article <2079759.1178523217398.JavaMail.root@cp1.javalobby.org>,
alex_blewitt@yahoo.com says...
> Alex.
Volker & Alex --
Exactly what I needed. Very much appreciated.
Best,
Gerald
Re: How to handle dynamic dependencies at run-time? [message #467615 is a reply to message #467548] Wed, 09 May 2007 01:56 Go to previous messageGo to next message
In article <f1ledf$p5q$1@build.eclipse.org>, nosp@m.please.org says...
> >>> Thanks,
> >>> Gerald
Ok, I have
1) the JDT plugins marked optional in the manifest
2) all of the JDT dependent code isolated in a single class 'DocUtils'
3) the plugin class contains a single reference to DocUtils:
// check to see if the JDT is installed & obtain reference
DocUtils docUtils = null;
try {
docUtils = new DocUtils();
} catch (RuntimeException e) {
e.printStackTrace();
However, any attempt to load the plugin in an RCP without JDT installed
results in a ClassNotFoundException on the plugin class itself; the
plugin class never even begins execution. When run in Eclipse, the
plugin loads and executes as expected.
So, what am I missing?
Gerald
Re: How to handle dynamic dependencies at run-time? [message #467619 is a reply to message #467615] Wed, 09 May 2007 04:05 Go to previous messageGo to next message
OK, to check out the dependencies, start up your RCP application with -console -noExit and then use 'ss'. Your bundle, if it can't start, will be in INSTALLED status rather than RESOLVED or ACTIVE.
There will be a number next to it; you can do 'diag 123' to find out what dependencies are missing. It won't say which optional ones are missing, but it will show you which mandatory ones are missing if it's INSTALLED.
You can also do 'start 123' to see if you can bring it up; you'll see any exception generated.
Note that if an exception occurs in the Plugin's start() method -- like an unexpected NullPointerException -- then your bundle will automatically stop itself afterwards.
Alex.
Re: How to handle dynamic dependencies at run-time? [message #467632 is a reply to message #467615] Wed, 09 May 2007 06:55 Go to previous messageGo to next message
Correct me if I'm wrong but optional only means that the plugin doesn't
have to be available at runtime in order to resolve a bundel but as soon
as you call a class that uses code from the optional bundel eclipse will
try to load it. Unable to find it it will throw a ClassNotFoundException.
I think what you need to do is check if the JDT Bundle is available and
only call into the bundel if it is. If not don't call into the
optional bundle.
Or as mentioned in this thread put the optional functionaliy in a
separate plugin which is optional and make sure you never call into it
as long as it is not needed.
Stefan
>>>>> Thanks,
>>>>> Gerald
> Ok, I have
> try {
> Gerald
Re: How to handle dynamic dependencies at run-time? [message #467648 is a reply to message #467632] Wed, 09 May 2007 12:01 Go to previous messageGo to next message
In article <16744865.1178697961875.JavaMail.root@cp1.javalobby.org>,
The RCP is the Aptana Web IDE. The console appears to have been co-
opted: it only shows with the title Aptana Scripting Console and does
not show/allow an osgi command line. Appears to hardwire the console
port to Firefox.
In article <f1s9a9$a0u$1@build.eclipse.org>, mailtolanger@googlemail.com
says...
Trying to catch the obvious 'RuntimeException', 'NullPointerException',
'MissingResourceException', 'BundleException' and even just plain
'Exception' exceptions do not work. But, 'NoClassDefFoundError'
*does*!.
Appears all is good.
> optional bundle.
Is there a preferred way to directly check if the JDT Bundle is
available? Is there any reason not to just catch the
NoClassDefFoundError and set a flag?
Gerald
Re: How to handle dynamic dependencies at run-time? [message #467654 is a reply to message #467648] Wed, 09 May 2007 13:51 Go to previous messageGo to next message
If your start method (directly or indirectly) refers to YourDependentClass (and/or you have it as a static reference somewhere) then it won't start up.
NB None of the exceptions you listed will catch NoClassDefFoundError, on account of it being a subclass of Error and not Exception.
You can, with clever coding, set it up such that the code is instantiated at runtime with or without the appropriate utils by providing some kind of Facade. For example:
start()
 helper = helper.instantiate();
abstract class helper
  instantiate = try {
       return Class.forName("dependent.helper").newInstance()
  } catch (Throwable e )
    return null;
dependent.helper extends helper
  doStuff() {
    JDTUTils.doStuff()
But it's much better to separate that out into a separate bundle if you can.
Alex.
Re: How to handle dynamic dependencies at run-time? [message #467696 is a reply to message #467648] Thu, 10 May 2007 03:57 Go to previous message
>> optional bundle.
As far as I am concerned this is ok but I don't like using exception to
handle control flow if there is another way.
I would try to ask the bundle registry directly.
Example code not tested:
Bundle bundle = Platform.getBundler(<id of the plugin for JDT that you
are calling into>)
if(bundle != null) // this means it has been resolved
// do your work her
Stefan
Previous Topic:Changing size of my Workbench
Next Topic:XML TreeViewer - can't get the labels
Current Time: Mon Jun 23 14:41:00 EDT 2025
Powered by FUDForum. Page generated in 0.33182 seconds
