Home » Eclipse Projects » Standard Widget Toolkit (SWT) » What components can be inserted in a ToolBar's separator?
What components can be inserted in a ToolBar's separator? [message #467269] Fri, 27 January 2006 13:30 Go to next message
lolo is currently offline loloFriend
Label, Text or List, when inserted in a ToolBar's separator, are not
visibles.
Re: What components can be inserted in a ToolBar's separator? [message #467271 is a reply to message #467269] Fri, 27 January 2006 13:51 Go to previous messageGo to next message
<publicado y enviado>
> visibles.
This only occurs in linux, not in windows
Re: What components can be inserted in a ToolBar's separator? [message #467296 is a reply to message #467271] Fri, 27 January 2006 22:27 Go to previous messageGo to next message
Jeremy Dowdall is currently offline Jeremy DowdallFriend
Member
are you setting the size of the separator? I've been using labels in
ToolItems on GTK for some time without a problem - if you have a snippet
I'd be happy to take a closer look.
ToolItem item = new ToolItem(tb, SWT.SEPARATOR);
CLabel lbl = new CLabel(tb, SWT.CENTER);
lbl.setText("000 of 000");
item.setControl(lbl);
item.setWidth(lbl.computeSize(SWT.DEFAULT, SWT.DEFAULT).x);
(add a listener to resize the item when its content changes)
>>visibles.
Re: What components can be inserted in a ToolBar's separator? [message #467355 is a reply to message #467296] Mon, 30 January 2006 09:02 Go to previous message
I have proven your code, but it does not work for me. I have noticed, that
if I do not set the width of the separator, the label is visible. Here you
have an snippet:
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.ToolBar;
import org.eclipse.swt.widgets.ToolItem;
public class ToolBarSeparator {
Display display = new Display();
Shell shell = new Shell(display);
ToolBar bar = new ToolBar(shell, SWT.BORDER);
for (int i = 0; i < 4; i++) {
ToolItem item = new ToolItem(bar, 0);
item.setText("Item " + i);
Image image = new Image(display, 10, 23);
Color color = display.getSystemColor(SWT.COLOR_RED);
GC gc = new GC(image);
gc.setBackground(color);
gc.fillRectangle(image.getBounds());
gc.dispose();
ToolItem sep = new ToolItem(bar, SWT.SEPARATOR);
int start = bar.getItemCount();
Label c = new Label(bar, SWT.READ_ONLY);
c.setText("Label");
c.pack();
sep.setWidth(c.getSize().x);//comment this line, to view the label
sep.setControl(c);
for (int i = start; i < start + 4; i++) {
item.setImage(image);
bar.pack();
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
image.dispose();
>>>visibles.
Previous Topic:PLAF conflict with SWT?
Next Topic:Problem with SWT.WRAP (GTK2)
Current Time: Fri Feb 21 19:51:06 GMT 2020
Powered by FUDForum. Page generated in 0.05814 seconds
