Home » Eclipse Projects » Rich Client Platform (RCP) » Cheat sheet menu item "not currently available"
Cheat sheet menu item "not currently available" [message #467132] Sat, 28 April 2007 08:05 Go to next message
I have begun adding cheat sheets to my RCP application. I found out how
to add the menu item:
http://www.eclipsezone.com/forums/thread.jspa?messageID=9202 7201&#92027201
I added my cheat sheet but when ever I select the Help | Cheat Sheets...
menu item I get the message "The chosen operation is not currently
available" message.
When I display the Cheat Sheets view from my view menu (using the Show
View dialog box) the cheat sheets view menu comes up and in the view's
menu my cheat sheet appears - and works.
I just do not understand why the menu item does not work.
In my application defining plug-in I have this:
<extension
point="org.eclipse.ui.actionSets">
<actionSet
id="org.eclipse.ui.cheatsheets.actionSet"
label="Cheat Sheats"
visible="true">
<action
class="org.eclipse.ui.cheatsheets.CheatSheetExtensionFactory "
id="org.eclipse.ui.cheatsheets.actions.CheatSheetHelpMenuAction "
label="&amp;Cheat Sheets..."
menubarPath="help/group.tutorials"/>
</actionSet>
</extension>
The menubarPath does exist - I created it in my application's
ActionBarAdvisor and the menu does have the expected "Cheat Sheets..."
menu item.
Any help or advice would be appreciated.
Ian
Re: Cheat sheet menu item "not currently available" [message #467207 is a reply to message #467132] Mon, 30 April 2007 21:07 Go to previous messageGo to next message
I still cannot see why my menu item generates this error - any thoughts?
Ian
Solved Re: Cheat sheet menu item "not currently available" [message #467209 is a reply to message #467132] Mon, 30 April 2007 21:26 Go to previous messageGo to next message
I was reviewing the real code mentioned in the other post (in the sdk
plug-in) and realized I missed the all important ":helpMenuAction" from
the class name.
It should have been:
<extension
<actionSet
visible="true">
<action
class=" org.eclipse.ui.cheatsheets.CheatSheetExtensionFactory:helpMe nuAction "
</actionSet>
</extension>
Re: Solved Re: Cheat sheet menu item "not currently available" [message #467325 is a reply to message #467209] Thu, 03 May 2007 04:07 Go to previous message
I think for getting cheatsheet menu u need to add 3 plugins (go to
Runmenu from there u should select Run).just add the following plugins u
will get the cheetsheet menu
1.org.eclipse.sdk
2.org.eclipse.search
3.org.eclipse.ui.cheatsheet
Here i paste the sample code for getting cheatsheets.
<cheatsheet title=" UI">
<intro >
<description>
This cheat sheet is a demo.
</description>
</intro>
<item title="BUISNESS RULES" >
<description>
Buisness rules makes it easy for developers to display
professional quality charts in their applications.
</description>
</item>
</cheatsheet>
After done the xmlfile just make it as a jar file and paste it in the
eclipse plugin directory.
Muthu
Previous Topic:Help with basic concept!
Next Topic:How to access a view from another view?
Current Time: Sun Jun 22 11:37:58 EDT 2025
Powered by FUDForum. Page generated in 0.04409 seconds
