Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to add background Image in a StyledText
How to add background Image in a StyledText [message #466931] Thu, 19 January 2006 14:34 Go to next message
Originally posted by: mengfanjun.gmail.com
I would like to add a background image in StyledText,how to do this.
Thanks!
Re: How to add background Image in a StyledText [message #466950 is a reply to message #466931] Thu, 19 January 2006 19:38 Go to previous messageGo to next message
Adam Kumpf is currently offline Adam KumpfFriend
> Thanks!
I'm not an expert, but I think this should do the trick.
Display d = new Display(); // you probably already have a display
Shell s = new Shell(d); // you probably already have a shell
StyledText st = new StyledText(s,SWT.NONE);
st.setText("some funny text\n to try\t\t Weee!");
st.pack(); // automatically set width and height to fit text,
// you may want to change that.
st.setLocation(10,10); // set the x,y location
Image myImage = new Image(st.getDisplay(),"enter file location here...");
st.setBackgroundImage(myImage);
Hope that helps.
Best Regards,
Adam Kumpf
kumpf@mit.edu
Re: How to add background Image in a StyledText [message #467311 is a reply to message #466950] Sat, 28 January 2006 18:38 Go to previous message
Adam Kumpf wrote:
>> Thanks!
> st.setText("some funny textn to trytt Weee!");
> Hope that helps.
> Best Regards,
> Adam Kumpf
> kumpf@mit.edu
I recently needed to take my own advice and add a background image to
StyledText.. But I ran in to the problem you must have been facing. The
normal ways of setting the background image do not work with the
StyledText object because it has other background painters that paint over
the image. I've been trying to find a way to stop them, but I haven't had
much luck.
Does anyone know how to turn off all of the background painters in a
StyledText object such that the setBackgroundImage(Image) actually sets
the background image? I can see it flicker the image for about a single
frame when I open the window, but then the image is quickly covered by a
white fill of some kind.
Thanks!
-Adam Kumpf
Previous Topic:Preferences Dialog Source Code
Next Topic:Ability to create SWT Font / FontData objects from files or InputStreams
Current Time: Wed Feb 19 23:04:36 GMT 2020
Powered by FUDForum. Page generated in 0.02323 seconds
