Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to add a new Node the Tree Viewer available in Plugin from its Fragment
How to add a new Node the Tree Viewer available in Plugin from its Fragment [message #466855] Wed, 18 January 2006 13:22 Go to next message
Muthu Chellappan is currently offline Muthu ChellappanFriend
Hi All,
I have to access a TreeViewer component available in Plug-in from its
fragment and add a new node to the tree with its own children.
Can any body help me on how to do this
Also, I can able to add a entirely new component say a wizard or Editor from
fragment. I end up in problem while adding a new field or a new node to the
existing component of the plug-in from fragment.
Thanks in Advance
Muthu.
Re: How to add a new Node the Tree Viewer available in Plugin from its Fragment [message #467037 is a reply to message #466855] Mon, 23 January 2006 15:55 Go to previous message
Veronika Irvine is currently offline Veronika IrvineFriend
You should ask this question in the eclipse platform newsgroup:
news://news.eclipse.org/eclipse.platform
"Muthu Chellappan" <muthu.velappan@aspiresys.com> wrote in message
news:dqlfep$ac6$1@utils.eclipse.org...
> Hi All,
> from fragment. I end up in problem while adding a new field or a new node
> to the existing component of the plug-in from fragment.
> Thanks in Advance
> Regards
> Muthu.
Previous Topic:Raising SWT Events
Next Topic:createPartControl
Current Time: Wed Dec 11 19:38:00 GMT 2019
Powered by FUDForum. Page generated in 0.01800 seconds
