Images are not properly placed under the plugin folder of product [message #466833] |
Wed, 25 April 2007 08:16  |
Originally posted by: johan_susai.yahoo.com
In rcp application, i used the following code
File logo=new File("D:/Data/Icons/a.gif");
Image imgIcon=new Image(display,logo.getAbsolutePath());
While launching this application it works fine, but after exporting i m getting the following error
Unable to create view : i/o error(java.io.FileNotFoundException).
I think while exporting, the images are not properly placed under the plugin folder of product( i am not sure).
So what i did is, i changed the code to
File logo=new File("Icons/a.gif");
Now it wont get work while launching as an Eclipse Application, but after exporting it as a product i manually place the Icon folder(which contains all images) inside the exported product.so now it gets executed well.
So kindly suggest me how to execute as an product without placing the Icon folder manually inside the exported product.
Joe
Re: Images are not properly placed under the plugin folder of product [message #466937 is a reply to message #466874] |
Thu, 26 April 2007 12:01  |
Hi Joe,
FWIW, the standard way to access resources in your plug-in is to use the
Bundle.getEntry() method.
So if the your Icons folder is in your plug-in root, you would call
Bundle.getEntry("Icons/a.gif") and then use the URL to access the file.
This separates your file access from the physical location and structure
of your plug-in. After all, your plug-in may be deployed as a jar...
Hope this helps,
--- Patrick
patrick@rcpquickstart.com
joesusai wrote:
> Prakesh,
> Thanks for your suggestion, after selecting Icon folder in build.properties
and exporting it i can execute the product from my system. But its not working
while executing the same application from some other system.so give me a
solution to execute the product in any machine.
> Joe
FUDForum. Page generated in 0.06833 seconds
